Sigma 30 and 19... which one to keep as a general purpose / portability lens ?
Started Jun 25, 2014 | Discussions
Amamba
Amamba Senior Member • Posts: 1,812
So, after much trial & error, I finally settled on 18-105 as my walkabout lens.
I feel that I have too many lenses now. They don't burn a hole in my pocket, but I'd rather not have lenses I use little.
What I have in E-mount is Sony 18-105/4, 18-55, 50/1.8, Sigma 30 and Sigma 19. Plus, a few A-mount and manual lenses.
With the purchase of 18-105, the 18-55 will go. It's a black version and very good as long as the kit lenses go, but it's outclassed by 18-105 and the portability factor can be relegated to one of the primes.
I will not sell 50/1.8 as it's probably the best IQ lens on Sony E-mount, plus the only other lens that's as good in low light is a much more expensive and less sharp 35/1.8.
So, I now need to figure which of the Sigmas to keep. I don't think I need both.
30/2.8 is a tad sharper (not drastically) and a bit better for portraits, plus just a tiny bit smaller. However, too long for landscapes.
19/2.8 is good for walking around in a city, still usable for portraits (full body), not noticeably longer, less of a universal lens but I feel it would complement 50 better.
So, 18-105, 19 and 50 less 30 ?
What would you do ?
 Amamba's gear list:Amamba's gear list
Sony Alpha NEX-6 Sony Alpha NEX-F3 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony E 50mm F1.8 OSS +8 more
captura Forum Pro • Posts: 21,787
Re: Sigma 30 and 19... which one to keep as a general purpose / portability lens ?
What would you do ?
I have both. And sometimes I do wides, but mostly not. So for general purposes, such as street shooting, I would choose to keep the 30.
RUwithME? Regular Member • Posts: 460
I would keep 18-105 and 50/1.8. You'll be covered from 18 to 105 with 50 for portrets. If you still want something really small, than 30 is more versatile.
 RUwithME?'s gear list:RUwithME?'s gear list
Sony Cyber-shot DSC-V1 Sony Alpha NEX-3 Sony a6000 Sony E 18-55mm F3.5-5.6 OSS Sony E 55-210mm F4.5-6.3 OSS +5 more
wb2trf Senior Member • Posts: 2,216
What would you do ?
You don't say what you like to shoot, but here goes.  I have both and would keep both, if forced into a choice, I'd keep the 30.  My reasoning would be that I tend to use the 19mm mostly for landscape, where I appreciate its sharpness but generally don't need the 2.8 advantage over the f4 of your zoom.  (If you don't actually want to carry the zoom because of bulk, that's a different story.)  At 30, I'm more likely to be shooting indoors in modest light and want the f2.8 that the zoom can't give me.  I know you have the 50mm but in some moderately tight situations for informal portraits the 30mm works better and you want that faster f stop.  The 30 is fully up to this role as it remains quite sharp even at its full aperture.  That would be my reasoning.
rogjil Junior Member • Posts: 44
What would you do ?
When I checked lens usage in lightroom, I found 43℅of my images shot with the Sigma 19 and about 30% with the Sigma 30. So for me I would keep the 19. However I have just spent two weeks using a Samyang 12 mm just about exclusively, so my preference is for wider angle lenses.
Also checking images I really like I have way more from the 19, so rather than think about which lens is sharper or maybe a better focal length, which of the two lenses for you has provided the better result. Pick that one.
 rogjil's gear list:rogjil's gear list
Sony a6000 Sigma 30mm F2.8 EX DN Sigma 19mm F2.8 EX DN Samyang 8mm F2.8 UMC Fisheye Sony E 35mm F1.8 OSS +2 more
007peter
007peter Forum Pro • Posts: 10,367
I had both, end up keeping the 19mm, because of Landscape
I have both, and I loved them both.  But between the two, I endup keeping the S19:
1. There is no Good Landscape Prime for Sony aside from CZ-24mm, and that is $1200
2. Sony 16mm is extremely soft, not worth its money
3. the same can be said for 16-50 soft corners and extreme vignetting
4. Sony 50mm f/1.8 make a better Portrait prime than Sigma 30/2.8
5. 30mm is too tight for decent landscape, yet kind of too wide for portrait too
Anyhow, I think a Sigma 19mm + Sony 50mm f/1.8 is the ultimate "DUAL LENS" setup.
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 25mm F1.7 ASPH
GaryW Veteran Member • Posts: 8,202
Re: I had both, end up keeping the 19mm, because of Landscape
Yeah, people don't seem too excited about the 20mm, but the wide-angle zoom seems popular as another option.
It's the cheapest Sony lens!  I think it's pretty sharp overall, just in the extreme corners, it suffers.  Needs stopping down for best results, and CA is a bit of a problem, but I found this lens better than some say.
I'd rather use the 16mm prime than the 16-50.  The 16-50 also has soft corners, but seems worse than the 16mm when stopped down, but maybe it's just me.
True.  It's a better focal length plus wider aperture.
It's a bit tight for my preference, but if you were forced to use one lens, it might be OK as a general purpose lens.
I'd say that a 19/20 and 30/35 combo would be more practical unless you did a lot of portraits.
Gary W.
 GaryW's gear list:GaryW's gear list
Sony Alpha NEX-6 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS Sony Cyber-shot DSC-V3 Sony Alpha DSLR-A100 +9 more
Amamba
Amamba OP Senior Member • Posts: 1,812
but pricey... $800 or so is hard to justify unless you do many wide angle photos. I wish someone came out with a cheaper alternative, even if it's manual. I am currently using Sigma 12-24 and LA-EA2, but it's a large combination for just an occasional use.
That's what the 18-105 is for. If I need a general purpose compact lens for when I don't want to carry it, I am leaning more towards 19/2.8.
Gary W.
I do lots of portraits... which is one of the main reasons to go with 18-105, as it has very nice bokeh in tele range.
I think I will keep the 19, as a "portable walkabout" it would be useful in more situations than 30. Just need to wait for the current sale to end before putting it on the market.
Amamba
Gary W.
Well, as I always do when deciding to sell a lens, I took both 19 and 30 for a week long spin. I decided to keep the 30,  it is a more useful FL but equally importantly, it's the most portable lens I have.
