Leica T portraits please!
Started Jun 24, 2014 | Discussions
Iphoto
Iphoto Regular Member • Posts: 228
Now that the Leica T has been out for about a month there is practically no threads on this forum about the T. Did anyone buy it? I am deciding between a T and the new Sony a7s. Would like to hear from any T owners who are satisfied with their purchase and also those who are not satisfied with their purchase. I will mainly take portraits with indoor lighting. Please post any portraits that you may have taken with the T. Thanks in advance,
Gar
 Iphoto's gear list:Iphoto's gear list
Fujifilm FinePix X100 Leica X Vario Sony Cyber-shot DSC-RX10 Panasonic Lumix DMC-GF1 Panasonic Lumix G 20mm F1.7 ASPH +2 more
Sony Alpha 7S
Wetzlarkid
Wetzlarkid Contributing Member • Posts: 614
Re: Leica T portraits please!
Gar
I was about to ask the very same ?................But went with a XVario,,:-)
 Wetzlarkid's gear list:Wetzlarkid's gear list
Leica X1 Leica V-Lux 40 Leica V-Lux 4 Leica X Vario Nikon D90 +4 more
jmteno76
jmteno76 Regular Member • Posts: 320
Few T pictures - both with fill in flash.
Highschool graduation
One cool dude
Canon D6, Leica T 701, and Sony rx1
www.pbase.com/joanteno
 jmteno76's gear list:jmteno76's gear list
Leica D-Lux (Typ 109) Canon EOS 6D Sony Alpha 7R II
Iphoto
Iphoto OP Regular Member • Posts: 228
Thanks Joan, how do you like.....
your T? Any buyer's remorse. What's the best thing about it?
Gar
Iphoto
How do you like your XVario? Can you share your best pics?
Gar
jmteno76
Re: Thanks Joan, how do you like.....
Gar
No regret
Things that I like - IQ, weight, like the menu and the simplicity of use, flash is good for fill in.
Very happy.
Iphoto
Joan, What lenses.....
do you use with the T? Any full farme leica lenses?
jmteno76 wrote:
Gar
No regret
Very happy.
jmteno76
Re: Joan, What lenses.....
Just 23 f  2.  Barjohn has written great review in this forum
Canon D6, Leica t 701 and Sony rx1
www.pbase.com/joamteno
Wojtek Bialy Junior Member • Posts: 45
Hey,
Last 3 pictures are taken with the T. I wanted to see how it performs in my casual shooting style: portraits & some bokeh. So here it is. I've been testing this camera for about 2-3 hours total and 1) I fell in love (cause it's Leica, cause it's beautiful, cause it's so minimal) but sadly 2) it's definitely not the best camera around overall. Suitable for slow paced photography, but when you want to quickly change between settings, it won't work
http://500px.com/wojti
Joe Lazio New Member • Posts: 9
Totally agree.with Wojtek Bialy. Is wonderful, but if you want to shoot. fast..... It is very slow in everything.
Putting into action is slow (probably the graphics load is the reason)
No has Bulb position
No option to cancel picture review
No screen with an option LEVEL
Not have sensor cleaning
It has no real image stabilizer (not stabilize anything)
Not allowed to use only RAW
Focuses bad in low light (The illuminator does not facilitate anything)
The most important: Very slow writing to SD, if RAW + JPG Fine or Superfine is used with bracketing you must wait several seconds for the next picture.... (Using a SD of 95 Mb s /)
It seems that a big part of these problems are easily solvable with a firware revision (Manual indicates about a new version 1.2 of firmware to today's date nonexistent)
But I'm silly, despite all I love the T
 Joe Lazio's gear list:Joe Lazio's gear list
Leica Vario-Elmar-T 18-56mm f/3.5-5.6 Ricoh Caplio GX200 Sigma DP1 Sigma DP2s Sigma DP2 Merrill +8 more
jeff hladun
jeff hladun Senior Member • Posts: 2,601
Many say the same about the speed of focussing with the M models. It's usually said by those who had cut their photographic teeth on autofocus lenses and cameras.
Unfortunately Leica has decided NOT to add the depth-of-field markings on the 23mm. Zone focussing is still possible using M-mount lenses, so if speed is an important part of your technique, try one of them on the T.
barjohn
barjohn Senior Member • Posts: 1,179
Actually, if you put the camera in MF, and cycle the info button you will find a display showing distance and depth of field.  The negative is the scale is not a fine as it needs to be or should be.  Thus you must interpolate and guestimate some of the values.  Perhaps in the next firmware version they can address and fix this as it should be a relatively easy fix.
John
Honest criticism and feedback should be welcomed. It helps the buyer and it helps the manufacturer improve.
Iphoto
Barjohn, how do you like....
...the T over the X-vario? Been contemplating both as well as the Sony A7s. Thanks for your input.
Gar
kithytom
kithytom New Member • Posts: 7
order mine at B&H late April but still waiting. Leica T is in global backorder, they must be tweaking something...
 kithytom's gear list:kithytom's gear list
Panasonic Lumix DMC-LX7 Canon EOS 5D Mark II Canon EF 14mm f/2.8L II USM Canon EF 50mm f/1.2L USM
