A7, Minolta 50 1.7, and a BMW
Started Jun 23, 2014 | Photos
beardedspoooon Regular Member • Posts: 139
Was out shooting in a parking garage and a guy with a nice car drove by.  Very spur of the moment.
All handheld, kind of rushed.  I have shots from the rear, but I don't want to throw his license plate out there (though I suppose it doesn't really matter).
Use this one if selling the car.
Use this one if showing it off.
Needs cleaning
Comment & critique:
Sony Alpha 7
forpetessake
forpetessake Senior Member • Posts: 4,892
what happened to the colors?
Did the AWB screw up colors? or you did it in PP?
beardedspoooon OP Regular Member • Posts: 139
Re: what happened to the colors?
The first shot is pretty close to reality as far as colors.  Was a bit past twilight + yellow light.  The remaining shots were PP.
Chrisd999
Chrisd999 Contributing Member • Posts: 884
Actually, I don't mind the WB. I like the PP  treatment. Well composed shots. I would have like to have seen a little bit more subject isolation. Was it wide open f1.7?
And it would be nice if the original image opened up at a higher resolution.
 Chrisd999's gear list:Chrisd999's gear list
Sony RX1 Sony Alpha 7R II Sony 70-300mm F4.5-5.6 G SSM Sony FE 55mm F1.8 Sony FE 24-70mm F4 OSS +6 more
It was wide open.  I probably could have gone with a smaller aperture, but hand holding at night, just goofing around, I wasn't too particular.
Here's a larger one of the first:
joe6pack Senior Member • Posts: 1,570
Wide open at 1.7? You must be standing far away! I have a 50mm 1.7 that I thought was very good but I don't think I have taken image that sharp at wide open.
 joe6pack's gear list:joe6pack's gear list
Olympus XZ-1 Sony Alpha NEX-3N Corel Aftershot Pro IrfanView DxO Optics Pro Elite
Oops! Double checked. Was at 2.2!
paul1508 Regular Member • Posts: 402
It's still very little background blur for FF f/2.2 and the apparent distance to the background. Are you sure you didn't shoot in APS-C Mode?
Definitely not. Perhaps the smaller image sizes are creating that effect?
In the first picture, the rail is a car length or less away. In the full size image, the sharpness decreases behind the wheel well.
Which Minolta 50mm 1.7 are you using? It is not the Rokkor is it? My Rokkor does not have a F-stop at 2.2.
Maxxum with LA-EA4. Should have clarified in original.
