Canon Rebel EOS. Yes, I know it is older.
Started Jun 20, 2014 | Discussions
quarterbackpryncess
New MemberPosts: 24
Jun 20, 2014
I have had my camera for 3 almost four years now. My camera will stop taking pics, it tries to focus zooming in and out but won't take a picture. Then maybe 1 hr later it is working again. This has done this twice to me now. What could the problem be?
Thank you in advance for any help.
baloo_buc
Veteran MemberPosts: 7,783Gear list
Re: Canon Rebel EOS. Yes, I know it is older.
In reply to quarterbackpryncess, Jun 20, 2014
Perhaps the lens or the connection got oxidized. I would try to detach and attach the lens. Then, if it doesn't solve the problem, you could clean the contacts with a swab and some mild alcohol.
 baloo_buc's gear list:baloo_buc's gear list
Nikon D5100 Olympus PEN E-PL5 Nikon D7200 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Tokina AT-X Pro 12-24mm f/4 DX II +13 more
quarterbackpryncess
New MemberPosts: 24
In reply to baloo_buc, Jun 20, 2014
Thank you!
photosen
Veteran MemberPosts: 3,934Gear list
I would also change the internal "watch" battery, which is cheap and easy to do and would give you some peace of mind.
 photosen's gear list:photosen's gear list
Canon EOS 30D Canon EOS 70D Canon EF 35mm f/2.0 Canon EF 50mm f/1.4 USM Canon EF-S 10-22mm f/3.5-4.5 USM +2 more
TTMartin
Veteran MemberPosts: 7,304Gear list
Could be dusk blocking the auto focus sensor.
Use the mirror lock up or manual sensor cleaning mode and use a bulb blower on the holes at the bottom of the mirror box.
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
beagle1
Veteran MemberPosts: 4,328
In reply to photosen, Jun 21, 2014
not sure that model has the little "watch" battery but if it does go bad that could cause problems
hesbehindyou
Senior MemberPosts: 1,684
To eliminate user error...
In reply to quarterbackpryncess, Jun 21, 2014
Does the problem go away in bright light?
In One Shot focus mode the camera won't take a picture until focus has been achieved. If light is dim (e.g. indoor lighting), and/or the object under the active focus point lacks contrasts, you get the focus 'hunting' you are experiencing.
TTMartin
In reply to TTMartin, Jun 21, 2014
The auto focus sensor is at the bottom of the mirror box. It is easy for dust to accumulate on it and degrade auto focus on an older camera.
You can use a Rocket Blower (bulb blower) alone or one with a flexible straw attached to it to blow out any dust. Do NOT use a can of compressed air! In the picture below you can see the holes under the mirror at the bottom of the mirror box, the auto focus sensor sits below these holes.
This is most likely the problem with your camera.
(Image from Understand How Autofocus Works: Part 2 )
quarterbackpryncess
New MemberPosts: 24
Thank you very much.
quarterbackpryncess
New MemberPosts: 24
In reply to beagle1, Jun 21, 2014
Thank you
quarterbackpryncess
New MemberPosts: 24
Thank you
quarterbackpryncess
New MemberPosts: 24
Re: To eliminate user error...
In reply to hesbehindyou, Jun 21, 2014
I had it happen once during the day outside was taking pictures of the bees in my tree and the other was at night.
