Another night, another fashion show with the a6000
Started Jun 18, 2014 | Photos
Wordsmith9091 Regular Member • Posts: 345
I've posted some images from this weekly fashion show at the Skyroom NYC lounge before. This one's a little different. It had been advertised as having "glow in the dark" fashions. I was picturing neon tubes or electric lights or a blacklight — something that would really pop. So I was originally planning to forgo the flash, and took the widest lens I've got, a Canon FD 50/1.4.
As it turns out, the "glow in the dark" bit was just these little balls sewn onto the clothing. Not particularly bright, even when right on top of them. So I was back to flash, but used that manual-focus lens for most of the night, including during the "runway" walk (it's really just he main area of the bar). Manual focus. In the dark. With moving models. At DOFs from F2 and wider (mostly).
Came away thinking I'd missed more than I got. And I've noticed that with my a6000, zooming in when reviewing pictures is a LOT less forgiving than I'm used to -- must be the 24mp sensor. Because at normal viewable sizes, plenty came out acceptably sharp. Of all of these, only the last (the b&w one) was taken with an autofocus lens — a Minolta "mini-beercan" 35-70/4.
This is all using a YN560-II flash (on an L-Bracket, with one of those dinky cowboystudio remote triggers just to provide a sync cable socket).
Comment & critique:
Sony a6000
morgjc Regular Member • Posts: 235
Re: Another night, another fashion show with the a6000
That looks like hard work for you and your camera better finding some ducks.
 morgjc's gear list:morgjc's gear list
Nikon D40 Sony a5000 Olympus OM-D E-M10
osv Veteran Member • Posts: 4,250
ducks or black lab, lol
seriously, those shots look pretty good, although a bit bright for my taste.
usually the model comes to a brief halt at the end of the runway, so you can prefocus a bit there, and hope for the best.
dan
DezM
DezM Forum Pro • Posts: 34,281
Check this
Not bad, but what's going with these two photos? There's another set of fingers on the right thigh of the model in the 1st shot
The 2nd shot, there's a smudge of red on the left thigh of the model with the red bathing suit.
Wordsmith9091 OP Regular Member • Posts: 345
Re: Check this
Oops! I'd copied some Lightroom adjustments from one image to a few others taken in similar conditions to use as a base ... I must have copied over some cloned/healed stuff too! Time to go through the batch and look for others!
Re: Check this
Yep, similar goofs hit a bunch of them ... though none were so creepy as the arm-legs!
RCWensley Forum Member • Posts: 83
Re: Check this
Pic 4 has it also. Not really my cup of tea (the first was OK) but very good none the less
 RCWensley's gear list:RCWensley's gear list
Sony a6000 Sigma 50-500mm F4.5-6.3 DG OS HSM Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 50mm F1.8 OSS Sony E 16-50mm F3.5-5.6 PZ OSS
Re: Check this
Yep. That's what I get for editing to 5 a.m.
But fine, you guys want ducks, have a duck!
Re: Check this
Now that I love!
Pass the pancakes & hoisin sauce please!
