Flash for A6000?
Started Jun 17, 2014 | Discussions
AHM Regular Member • Posts: 441
Flash for A6000?
I'm interested in an external flash for the A6000 that is a little better than the built in flash. I don't want to spend a lot of money and I don't need a great flash. Any recommendations? What I would use it for as to take pictures of groups of people at some event.
 AHM's gear list:AHM's gear list
Sony a6000 Sony E 55-210mm F4.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Sony E 35mm F1.8 OSS Samyang 12mm 1:2.0 NCS CS
Sony a6000
RonFrank
RonFrank Senior Member • Posts: 2,130
Re: Flash for A6000?
Here is a list based on what BH sells. I like Metz...
http://www.bhphotovideo.com/c/search?Ns=p_OVER_ALL_RATE|1&ci=647&setNs=p_OVER_ALL_RATE|1&N=4168864822+4062787792+4043133129+4062787793&srtclk=sort
 RonFrank's gear list:RonFrank's gear list
Nikon D1X Nikon D200 Nikon D300S Sony a6000 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +7 more
kmd0501 Regular Member • Posts: 148
AFAIK (NEX 6 owner), the 6000 has the new MIS hot shoe, and is not compatible with many of the flashes on the above list - unless you want to shoot manual flash.
If you want TTL, the Sony HVL-F20M, HVL-F43M or HVL-F60M will work - see this link:
http://www.bhphotovideo.com/c/search?atclk=TTL+System_Sony+NEX+3%2f5&Ns=p_OVER_ALL_RATE|1&ci=647&N=4168864822+4043133129
However, rumor has it that Nissin is releasing a version of their i40 for the MIS hot shoe at the end of July.
My personal take is that the F20M is an awkward design, the F43 looks OK and the F60 is huge on a mirrorless camera. I am waiting for the i40.
Mike
 kmd0501's gear list:kmd0501's gear list
Sony Alpha NEX-6 Tamron AF 70-300mm F/4-5.6 Di LD Macro Sony E 55-210mm F4.5-6.3 OSS +1 more
SQLGuy Veteran Member • Posts: 4,172
The F20M is a bit awkward, especially since Sony seems to have added an adapter to the shoe of it instead of just changing the connector... on the other hand, that also makes it sit up a little higher, which can be helpful.
Anyway, awkwardness aside, it works well and is nice and small. Easy to carry anywhere.
A7 with kit lens and a number of legacy lenses (mostly Canon FD)
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Nikon D200 Sony Alpha NEX-7 Sony Alpha 7 II Nikon AF-S DX Nikkor 35mm f/1.8G +2 more
AHM OP Regular Member • Posts: 441
Thanks. this is helpful. I have to say, I don't want to spend more than $100, and I can see that several satisfy that. The issue is, which of these are compatible with A6000. It is somewhat confusing.
RonFrank
The Sony cameras are all compatible with flashes designed for Sony but you will need a converter. Sony does a great job of making the flash options confusing and difficult, but that is life on planet Sony, there flash system IMO really stinks as do their flashes.
http://www.bhphotovideo.com/c/product/913654-REG/sony_adpmaa_multi_interface_shoe_adapter.html
Reading the Q&A on the BH website is generally very helpful.
It is best to ask the store selling the flash if you have doubts.
Itamath Regular Member • Posts: 206
Can Nikon SB800 be used ?
No TTL ofcourse.
 Itamath's gear list:Itamath's gear list
Sony a6000 Sony E 16-50mm F3.5-5.6 PZ OSS Carl Zeiss Touit 1.8/32 +1 more
I contacted B&H, and they said no compatible flash for <$100 is available. They said the Sony HVL-F20M is compatible without adapter. But Sony does not list it as compatible.
I also contacted Sony (chat) and they also said the HVL-F20M is compatible with A6000. That seems really the only option then.
Davi7d777
Davi7d777 Regular Member • Posts: 155
Well the HVL-F20M would seem on the surface to be a good fit.   But watch out.  As a first time Sony camera user, I did buy the HVL-F20M when my A6000 was pre-ordered from what turned out to be inadequate information. After researching the Sony variety of hot shoes and compatibilities at depth which I see as a mini nightmare, then contacting Sony customer service, I regret buying that model.  My intent as someone that does considerable nature close-ups was to get a flash I could use off camera in order to not be limited to a flat view without shadowing, a camera mounted flash is stuck with.  I found it odd the Sony system for the camera did not actually have something to fill that niche.   And how confused the user community seemed to be with all these shoe types and adaptors needed.  The two adaptors and cable to get a person to that point cost almost as much as the flash itself.
Mounted atop the camera the flash works fine. And bounce flash is excellent.   However when my flash is mounted on a cable, it intermittently gets into an illegal mode where it turns itself off and will not immediately turn back on whether mounted on the camera or off, cable disconnected.   Oddly to get it to turn back on, I have to unbend and bend the power on switch OFF ON OFF from 8 to 12 times after which it usually turns on and charges.   That is possibly why Sony did not offer an accessory for that purpose because during Engineering they belatedly found the flash did not work well off the camera so quietly decided to discourage that use.  Supporting that speculation is the fact the Sony store website is strangely quite absent of any information about adaptors or cables for doing so and their sales people don't even have any information which is how I got into trouble.
David
 Davi7d777's gear list:Davi7d777's gear list
Canon PowerShot G10 Canon PowerShot SX130 IS Nikon Coolpix S3100 Sony a6000 Sony E 30mm F3.5 Macro +9 more
