Anyone here have the Panasonic GH4 and 100-300mm lens?
Started Jun 17, 2014 | Discussions
Sgt_Strider Senior Member • Posts: 2,203
In theory the GH4 should AF really well with any Panasonic lens as a result of the new DFD technology. Yet, I've read somewhere that the GH4 is a bit sluggish with the 100-300mm lens. Anyone here experiencing such problem with this set up?
Nikon Df Panasonic Lumix DMC-GH4
Jorginho Forum Pro • Posts: 10,416
Re: Anyone here have the Panasonic GH4 and 100-300mm lens?
Depends. It is not sluggish in AF-s. When you want to use it for action, BIF or speedy animals or sports, you cannot rely on the AF-c system at all. It loses focus, it slows down the system a lot. If you expected good performance, like with the 35-100, it will be a frustrating experience I think.
You could find ways to work around this with MF and FP, far from ideal I think but some seem to be really good at it.
 Jorginho's gear list:Jorginho's gear list
Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GH2 Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +9 more
axlotl Senior Member • Posts: 1,514
Re: Lots of posts about this subject on this forum
http://www.dpreview.com/forums/post/53857516
Try this one and read through the responses, I think most of your answers are there.
Andrew
Fredrik Glckner Veteran Member • Posts: 3,332
In my experience, the GH4 in combination with the 100-300mm lens is slower to focus than with the GH3, especially in the long end around 300mm.
With the GH4, this lens is downright frustrating to use.
http://m43photo.blogspot.com
guybie Contributing Member • Posts: 795
 guybie's gear list:guybie's gear list
Olympus XZ-2 iHS Panasonic Lumix DMC-FZ1000 Canon EOS 7D Mark II Canon EF 70-200mm f/2.8L IS II USM Canon Extender EF 1.4x III +5 more
Chris R-UK Forum Pro • Posts: 15,203
A summary
After starting the thread that other people have linked to, I wrote a summary of the current situation on this post in the Wildlife Forum.
Chris R
 Chris R-UK's gear list:Chris R-UK's gear list
Panasonic Lumix DMC-GH2 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
PC Wheeler
PC Wheeler Forum Pro • Posts: 15,935
Fredrik,
That's a surprise. Mine works a bit better with the GH4 than the GH3 -- not great with either one but so far never frustrating. I'll use my 100-300 without hesitation when the distance warrants.
I seem to get about 4 fps with Medium burst mode. 14-140 II and 35-100 are both able operate at full medium rate.
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot SX50 HS Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-ZS100 Sony Alpha a6300 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA +7 more
amtberg Veteran Member • Posts: 5,532
Fredrik,
Phil
I haven't done a back-to-back comparison (sold my GH3) but I don't notice any difference.  The lens is fine using AF-S.  It just doesn't work well with AF-C.
georgec Regular Member • Posts: 478
It is slow to auto-focus when shooting 4k Video
Other than that , it is the similar as GH3. I love this lens for video, especially for  the price.
 georgec's gear list:georgec's gear list
Canon EOS 5D Mark II Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GH4 Canon EF 135mm f/2.0L USM Canon EF 400mm f/5.6L USM +8 more
Sgt_Strider OP Senior Member • Posts: 2,203
Re: A summary
Chris R
That's really disappointing news. Hopefully Panasonic will come out with an updated lens in the near future.
Vesku Senior Member • Posts: 2,033
I have shooted sports with GH3 and 100-300 and now with GH4. 100-300mm is kind of slow and with AFC I get about 3 fps when using f 6.3 (GH4). It is a bit faster than with GH3. Most importantly the new DFD AF gives much better succes rate. 100-300 focuses more accurately in video too with GH4.
Airjeff Junior Member • Posts: 32
I would recommend checking the lens firmware version.  The most recent version is 1.2 (1/25/2012). Mine seems good on the GH-4.
Have you tried using the 100-300mm in AF-C mode?  Can you get an FPS rate over 4fps in AF-C mode (1) with the lens wide opened and (2) stopped down to, say, f/8?
Different users seem to get different results with this lens on the GH4 and E-M1 and I am trying to collect information.
Chris R
Chris R
I have used and tested 100-300mm with GH4. I can get 3-4 fps at f5.6 and it slows down gradually when stopping down. Fps is not constant, sometimes if subject moves very little the objective speeds up a little and if there is difficult movement the lens slows down.
I have found in sports events the best combination is f 6.3, iso 250-320 and shutter about 1250-1600. it needs a lot of light, there must be some sunshine. It it is cloudy I must rise iso.
Chris R
Thank you for the information.  Your results seem to be consistent with other GH4 users.  The results on the E-M1 seem to be more variable.
Chris R
Chris R-UK wrote:
Chris R
Chris R
I ran a test and match Vesku's findings.  I also tried various focus modes and RAW vs JPEG.  Stabilization was switched off.  But...manual focus is ~11 fps!  Oh well.
Jeff L.
