New Dp2 Quattro (beta) samples~~~~ Locked
Started Jun 17, 2014 | Discussions
This thread is locked.
michaeli Regular Member • Posts: 196
 michaeli's gear list:michaeli's gear list
Sigma DP2s Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp2 Quattro Sigma SD14 +5 more
Sigma dp2 Quattro
SigmaChrome Veteran Member • Posts: 8,036
Re: New Dp2 Quattro (beta) samples~~~~
The website seems to have fallen down a hole...
Ahhhhhhggggg!
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sony RX100 Sigma DP3 Merrill Sigma SD14 +14 more
Kendall Helmstetter Gelner MOD Forum Pro • Posts: 19,403
If there was any doubt the Quattro had some interest, this should dispel that notion...
Even the Google cached version will not load:
http://webcache.googleusercontent.com/search?q=cache:http://digitalcamera.jp/html/HotNews/image/2014-06/17/sigma_dp2Q_beta/
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
cquarksnow Contributing Member • Posts: 519
This is a sample table entry in the Websphere generated web page :
<A href="SDIM0320.JPG"><img class="thum" src="thumbs/SDIM0320_s.JPG" width="640" height="427" alt="SDIM0320"></A></td>
So we have six pictures pointers, namely SDIM0320.jpg, SDIM0096.jpg, SDIM0072.jpg, SDIM0016.jpg, SDIM0534.jpg and SDIM0431.jpg
I tried from NY ; these are the last hops in traceroute :
14 87 ms 85 ms 86 ms 38.104.84.42
15 194 ms 195 ms 194 ms gi11-0-0.cr1.nrt1.asianetcom.net [202.147.61.170]
16 193 ms 191 ms 206 ms gi1-0-0.gw1.nrt5.asianetcom.net [202.147.0.178]
17 195 ms 196 ms 210 ms YHJ-0001.gw1.nrt5.asianetcom.net [203.192.150.178]
18 187 ms 187 ms 189 ms 203.141.47.226
19 186 ms 203 ms 201 ms ae1.tnhcr01.idc.jp [158.205.134.6]
20 199 ms 185 ms 185 ms po14.ta1ag01.idc.jp [158.205.192.102]
21 179 ms 178 ms 180 ms lag1.l308.ta1.eg.idc.jp [158.205.188.210]
22 193 ms 194 ms 208 ms 158.205.189.14
23 212 ms 215 ms 214 ms sv.digitalcamera.jp [210.239.47.69]
The I set a proxy in Tokyo and got the following :
1 199 ms 201 ms 204 ms 10.8.4.1
2 200 ms 215 ms 201 ms osk2-kopti.noc.kk-net.ad.jp [121.83.238.1]
3 206 ms 200 ms 208 ms 121.83.233.29
4 203 ms 202 ms 204 ms 58.191.151.1
5 205 ms 203 ms 206 ms 180.145.255.137
6 203 ms 217 ms 205 ms 219.122.245.37
7 216 ms 225 ms 210 ms 60.56.5.130
8 210 ms 215 ms 213 ms as4694.ix.jpix.ad.jp [210.171.224.49]
9 213 ms 210 ms 210 ms po14.ta1ag02.idc.jp [158.205.192.106]
10 212 ms 213 ms 216 ms lag2.l308.ta1.eg.idc.jp [158.205.188.206]
11 236 ms 210 ms 228 ms 158.205.189.14
12 232 ms 237 ms 246 ms sv.digitalcamera.jp [210.239.47.69]
Also I searched google cache for SDIM0320.jpg in the past 24 hours and the parent directory appears as 12 hours old, but still no luck.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CBwQFjAA&url=http%3A%2F%2Fdigitalcamera.jp%2Fhtml%2FHotNews%2Fimage%2F2014-06%2F17%2Fsigma_dp2Q_beta%2F&ei=HcGfU9n8N9axsASluYCoBQ&usg=AFQjCNG6VlhZ69qYhwJvJVTz4ahfffgCNQ&sig2=eZjl9EkeyFGbEeQucprjGg&bvm=bv.68911936,d.cWc
Maybe after lunch is over in Japan ?
Chris
 cquarksnow's gear list:cquarksnow's gear list
Sigma DP1 Merrill Sigma SD10 +4 more
Just managed to get a glimpse of two thumbnails from google cache, so you know the pointers might be right.
Screenshot of partially retrieved thumbnails
Chris
OMG! Are we desperate for photos or what!?
Just in case I would need to grab a DP3M before they disappear !
Here is a third thumbnail that took about 30 minutes to load even though I am using a proxy from U.S. directly into Tokyo :
DP2Q thumbnail
Chris
Chris
Chris
Here's the link to the top left image (a tall building), I was also able to get the google cache to cough up about half the content as well as the translated text about the images:
http://digitalcamera.jp/html/HotNews/image/2014-06/17/sigma_dp2Q_beta/SDIM0320.JPG
The text for the leftmost image you are showing:
"Daylight I realize the descriptive power to surpass or comparable to medium-format camera or 35mm full-size machine. The show power in landscape photography you want to stick to the depiction of details. Gradient evening also pretty."
The link is now loading after a few tries, though at 300 baud speeds it would seem.  Sure wish they had used S3 or some other image distribution network to host those...
L Tippett Senior Member • Posts: 1,933
They look good on my iPhone at work!
Kind regards Lea.
jennyrae Senior Member • Posts: 2,690
take forever to load but if these pictures come from Quattro, initial impression is very very positive.
These are the other tumbnails :
Other ones in my prior post
Chris
thank you Chris but uploading pictures to dp only degrades quality of pictures.
Rufu Regular Member • Posts: 103
The thumbnails look fine. Too bad there isn't a second website to host the files.
I try to host it when finished loading. so far I have seen building part. gray/silver looks good and resolution looks good. very sharp even from far.
Thanks, some comments.
michaeli wrote:
I uploaded the samples to my Onedrive cloud, hope it doesn't break the law:
Very nice of you, thanks for doing that. You can probably remove them tomorrow when the site recovers...
These all are looking really good. I can see some faint noise in the sky of the night image but not much in shadows with good light.
Also the ISO 200 (green leaf closeup) looks fantastic as far as noise and color.
cas3 Regular Member • Posts: 470
Slowest download I've seen in 10 years.  Cityscape looks very sharp. Sky a little noisy.
 cas3's gear list:cas3's gear list
Sigma DP2 Merrill Fujifilm FinePix S5 Pro Pentax K-5 IIs Olympus E-M5 II
michaeli OP Regular Member • Posts: 196
OK,I will delete them after 24 hours.(nt)
Johan Borg Senior Member • Posts: 2,324
Re: Thanks, some comments.
+1
The leaf and bridge photos are taken with a newer firmware. All shots appear to be OOC JPEGs since "Software" in the EXIF doesn't say SPP version but just a camera/firmware edition (assuming that the Quattro EXIF behaves the same as Merrill).
Looking forward to the first RAW samples...
Great news if so since that usually means better noise handling, and it also means better dynamic range.
Also in some areas I saw what looked like JPG compression artifacts, I was wondering what Q level those were saved at.
Oh yes!
