My review: Fuji X-T1 vs the Nikon Df
Started Jun 16, 2014 | Discussions
stuartgolden
stuartgolden Forum Member • Posts: 57
6
Full frame this, SLR that.  For me what it comes down to is what would you want to lug around all day around your neck.
For me - the left wins!
 stuartgolden's gear list:stuartgolden's gear list
Leica D-Lux (Typ 109) Ricoh GR II
Fujifilm X-T1 Nikon Df
ryan2007 Forum Pro • Posts: 12,001
Re: My review: Fuji X-T1 vs the Nikon Df
I believe the Nikon Df has pretty all AF lenses and maybe some MF lenses that will will on the camera. Nikon is a more complete system as is Canon vs anything mirrorless.
Sensor size does matter a lot and I'd say the same if you were comparing Micro Four Thirds and after shooting Nikon then Panasonic GH-3 with their fast glass and now Fuji each has their place.
I have handled the Nikon Df and regardless of all the guts etc, I did not care for the hand grip, minor but a functional concern.
As far as Fuji goes I need to use an accessory hand grip because I find the Fuji cameras too shallow  when it comes to the camera as is, grip.
The obvious is larger DSLR lenses, they cost more etc..
If Fuji does not do more with the X200 or Xpro-2 rumored getting a DSLR or even micro four thirds again to use in tandem with Fuji may happen. I just won't invest as heavily in Fuji glass, like 4 -5 lenses.
My issue is with lack of accessories for Fuji, if Metz did a flash that would be more than OK. I understand the XT-1 is an improvement but it is not a DSLR killer yet, hope it will be.
sgoldswo
sgoldswo Senior Member • Posts: 5,535
14
Odd choice in lenses don't you think? Try putting the 10-23 on the front of the X-T1 or the 16-85 on the front of the Df. Or even better the 35 on the X-T1 and the 50 F1.8G on the Df.
For me the Df ended up being the replacement for my X-Pro1. It's all about the sensor (not just high ISO, but the way it renders colours).
 sgoldswo's gear list:sgoldswo's gear list
Leica Q Leica M Typ 240 Nikon Df Nikon D810 Nikon D750 +1 more
SaltLakeGuy Forum Pro • Posts: 11,196
I happen to be a huge Nikon fan after years of having their pro gear along with Canon as well. I won't take ANYTHING away from their top cameras. They just WORK. Exceptionally so in the area of focus, build and ergonomics. For me Fuji brought some other things to the table. I happen to really love the overall IQ of the fuji files. I enjoy the color rendition and lack of noise. Sure the focus isn't as instant nor does it track a moving subject as well as a top Nikon, but then fortunately that's not what I shoot. My shoulders and back thank me for the switch. I can't say it's in or not in the cards but I would love to be able to afford another pro Nikon body. Their top Nikkor lenses are certainly a delight. But for the sizes I print (up to 22x17) the Fuji X-T1 is more than meeting my needs. I love their lenses as well. Solid and sharp with excellent OIS. If I were 35 again I could certainly see lusting over another DSLR setup, but at 60 I don't see it happening.
Fuji X-T1 Camera, Fuji 18-55 f2.8-f4 Lens, Fuji 55-200 f4-f5.6 Lens, Fuji 23mm f1.4 Lens, Fuji 56mm f1.2R Lens, waiting for the Fuji mount Nissin i40 Flash, Picturecode PhotoNinja, LightZone, Adobe Lightroom 5.4
 SaltLakeGuy's gear list:SaltLakeGuy's gear list
Sony Alpha 7R II Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-200 F4 Sony FE 24-70mm F2.8 GM +2 more
photoreddi Veteran Member • Posts: 6,386
9
It's a very odd choice and an odd choice of bodies as well. The 14-24mm Nikkor deserves to be used with either the 24mp D3x or the 36mp D800 full frame bodies, shooting high resolution landscapes, not a Df that's better suited for fast sports action photos either the near-kit lens 28-85mm Nikkor or with a faster, larger lens like the 24-70mm f/2.8 Nikkor.
And why would the inexpensive 16-50mm kit lens that's included with the X-A1 be used for the comparison when the X-T1's kit lens is Fuji's 18-55mm? Maybe just to make a more lopsided comparison, putting a thumb on the comparison scale so to speak? Most X-T1 owners would be using Fuji's larger 18-55mm lens, not the 16-50mm kit lens
Both of Fuji's small kit lenses are fine walkabout lenses, while the special purpose extra-wide 14-24mm FX (Nikon's largest, most expensive wide angle zoom lens) isn't. If a point is going to be made about size and weight comparing Fuji vs Nikon, a more appropriate comparison would have been to choose a Nikon DX DSLR which uses a similar size APS-C sensor, and then the comparison might have been the D7100 DSLR (or any of many much smaller DSLRs) with either a large but more flexible kit lens (18-140mm) or to do what the OP did, pick the smallest kit lens that's supplied with some other DSLR, in this case Nikon's 18-55mm kit lens, which happens to be about the same size as Fuji's 16-50mm lens. But that wouldn't tell the same story, "Ooh, the DSLR is so much larger and heavier than my Fuji".
Bah, humbug!
km25
km25 Contributing Member • Posts: 601
Advantage to Nikon FF vs APS-C @ 16mp. The lens for the Fujion on an average are better then Nikon. The Nikon has an 85mm F/1.4 or even the F/1.8, great lens. But then the Fuji has the 56mm F1.2. The Fuji has the 23mm F1.4, better get the Sigma. Lens are a very good, but the edge would have to go to Fuji. No vertical grip for the Nikon, MF, no interchangable focusing screens, I owned Nikons, there should bring back the P screen. Trouble with low light AF. And biggest, to me fault with the Nikon, it has a AA filter. Bottom line the Df makes good pictures, it's operation can stand improvement. Correct all the above, then I may think about it.
kam
 km25's gear list:km25's gear list
Fujifilm X-T1 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Leica Summilux-M 35mm f/1.4 ASPH Leica Elmarit-M 24mm f/2.8 ASPH +3 more
shigzeo
shigzeo Senior Member • Posts: 1,722
5
kam
I don't understand where Fujifilm lenses get the 'edge' vs equivalent Nikons. They are very nice, and operationally, can be somewhat more straightforward. But in terms of raw performance, there isn't a hair's width between them when compared to equivalents.
Nikon 85/1,8 and the Fujfilm 56/1,2 perform roughly equally, both giving ground in certain areas. The only area Fujifilm are ahead is in the 14/2,8 vs the ancient Nikon 20/2,8 lens. But then again, 14 gives the look of a 21/4, which on FF, should be smaller and equally as optically corrected as the 14/2,8.
Fujifilm have to put a lot more resources into building lenses to match FF because each effectively is a wider angle. It must be faster in order to achieve close to the same equivalent look, and in 100% of the cases, is more expensive than its FF equivalent.
I love the 35/1,4. Sharp, good OOF rendering, and on the X-T1, handsome. But it's doing the same basic thing as the 50/1,8 despite being effectively an ~f2 lens.
It's not about 'better', it's about better for you or for someone else.
I think Nikon are doing a disservice to their customers by continuing to build massive dSLR cameras when they could use the traditional size of the FE/FM as the base and build out from there. Using staple lenses (and building out classic focal lengths), they would have an enviable FF system if only they got away from the idea that dSLRs have to be massive. The Df is a great idea, but in practice is way too big.
The X-T1, being the size of an FE, is perfect. I just wish Fujifilm would design truly compact lenses in addition to their moderately fast (in equivalent terms) options.
 shigzeo's gear list:shigzeo's gear list
Nikon D200 Nikon D800 Fujifilm X-Pro1 Sony Alpha 7R Fujifilm X-T1 +9 more
Beat Traveller Contributing Member • Posts: 744
I'm slowly growing to despise Compact Camera Meter. It's gradually achieving DXO levels of screen-grabbing to make pointless judgements void of context about the superiority of one camera over another.
 Beat Traveller's gear list:Beat Traveller's gear list
Fujifilm X-E1 Nikon D60 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro
There are so many other ways to make pointless, incorrect and sometimes silly judgements, many of them making up a large portion of some of DPR's forum threads. The Compact Camera Meter can be useful if it's used appropriately and not used to support personal preferences with misleading comparisons.
shigzeo
It's biggest problem is that it doesn't show 'equivalence'. You get a smaller camera or a larger camera, but the effect of the lenses you put on the sensors inside those don't show up at all. Yes, you can get great compact interchangeable lens cameras now. But you cannot get the same look you can get with the larger formats and even modest speed lenses.
Nikon do have a problem though: their dSLRs are too big. Their lenses are what they are. By and large, equivalents in m43 and APS-C do not exist when mated to native sensors; if they do, they prove to be just as large as the FF lenses to which they are most closely compared.
Dorkington Regular Member • Posts: 355
The Nikon Df is a better camera, I think that much can be agreed on. It has better image quality, and faster focusing even with the compromised AF sensor.
That being said, for me, is it better enough to sacrifice size? Nope. That's why I moved on from my Canon DSLR set many years ago.
I wanted to find something that was a good compromise in quality and size, and I came away with the Fuji system.
There are smaller systems out there, definitely (MFT, and some Sony setups). There are better quality systems (Canikon, Sony FE). But I'm comfortable with a little bit of both.
It's a great time for photographers, loads of high quality choices.
 Dorkington's gear list:Dorkington's gear list
Fujifilm X-E2 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R +2 more
For those complaining about selections, here's a few more... not every situation does the Fuji win outright, but like I said, it's all about compromise.
Again, not saying Fuji is the "winner" here. It's all about what you value most. Want the highest of high quality? There's better options than Fuji, for sure. Want the smallest of the small? Again, there's better options. (though not seen here)
Please note, for the zooms, there isn't really a direct comparison for each camera, so I tried to choose what was the closest and available on Camerasize.com's website. Don't shoot the messenger.
Following images from: http://camerasize.com/compact/#520.408,487.395,495.353,ga,t
~50mm equiv
~35mm equiv (edit, just noticed that the Nikon lens is a DX lens, whoops)
Base zoom. Chose the "consumer" grade Sony, and the smallest of the available full frame options on Camerasize, for the Nikon. The Nikon options were much larger than the Tamron option.
"Vacation lenses". Fuji's new 18-135. Sony's crop mount 18-200 PZ (no full sensor "vacation lens"), Nikon 28-300.
Caerolle
Caerolle Senior Member • Posts: 3,097
The Df is the ugliest camera I have ever seen
Especially the silver one. It reminds me of the thing the optometrists use to determine prescriptions. And it isn't even small. Plus has a franken-control system, apparently they couldn't decide if they wanted it to be old-school or modern, so just threw in both systems. Well, except no video. And then marketed it with ads that seem to have been made by the same people who make those 'wise, competent, self-assured old-dude' ads for Viagra.
I am not fond of the retro stuff, but Fuji did it as right at it can get, pretty much, with the X-T1.
Not because I think they are good, but because I would like to improve (feel free to provide me with feedback):
http://500px.com/carolteater
 Caerolle's gear list:Caerolle's gear list
Olympus OM-D E-M10 Olympus E-M1 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro +3 more
shigzeo
~50mm equiv
The FF options are hard to decide upon, but there does exist an older Nikon 28-200 lens, which roughly coincides to the Fujifilm one, though in equivalent terms, is faster. It is smaller and much less expensive but AFD, rather than AFS.
To coincide with the 18-55 Fujifilm, Nikon offer the 24-85, which is both wider, and in equivalent terms, offers a different image. It is not much larger than the Fujifilm lens.
Essentially, when put in as equivalent terms as possible, FF will generally be the same size, and often, much less expensive.
photo perzon
photo perzon Veteran Member • Posts: 4,207
they look about the same size to me
i have a keen eye
 photo perzon's gear list:photo perzon's gear list
Sony Cyber-shot DSC-RX100 III Panasonic Lumix DMC-GM1 Olympus PEN E-PL5 Fujifilm X-A1
Dheorl Veteran Member • Posts: 3,211
Although if you don't care about razer thin DoF then all of this is largely just hot air and I definitely don't see what use there is displaying it along with camera size.
shigzeo
The reason is that fast FF lenses get compared unfairly to lenses that deliver images that produce completely different images. It isn't all about DOF, but if the idea is that a crop sensor lens is smaller, then it should be compared to an equivalent lens that gives an equivalent look.
Thus, an 18-55/2,8 APS-C lens should be compared to a 28-70/4 or 28-85/4 not an f/2,8 lens, which gives a totally different result. All things equal, lenses giving equivalent focal lengths AND DOF will be roughly the same size. Sometimes, they will be much larger in APS-C or m43 simply because in order to achieve the same look, you have to have much much faster glass/more expensive glass.
I prefer slower lenses. On FF, I own f/1,8/85mm at fastest. It is roughly the same size as the Fujifilm 56/1,2 and gives pretty much the same look. If Fujifilm made a 56/2, then its equivalent FF lens would be an 85/2,8.
Lenses that give more DOF at widest aperture usually are smaller and cheaper. With mirrorless, since lenses are made to mimic FF standards, they have to use much more expensive designs in order to keep up with rather meagre lenses.
The real coup would be if Nikon designed an FE/FM style mirrorless F mount camera. Apart from a longer flange distance, the camera and system would be the same size as the X-T1, but would feature cheaper lenses, many of which are at least as good as the Fujifilm lenses. What doesn't match up is the zooms. You get printable, great results from any zoom on the market today, but Fujifilm's 18-55/2,8-4 is overall a better lens than the 24-85/3,5-4,5 which is its closest competitor. Of course, DOF/FOV is off between those two. If Nikon made a 28-85/4-5,6 lens, it would be the same size as the Fujifilm.
Why should it? Because you care about it? I'm sorry but to me it just doesn't make any logical sense. I would have said it's fair to compare a f2.8 lens to an f2.8 lens, no matter what format they're made for. I'd rather not have a nice simple layout like camerasize cluttered but irrelevant info.
If you care then your welcome to go find a DoF calculator.
As far as I'm concerned size of camera and cleanliness of image are paramount. Should they also include a range of test shots below each camera at all ISO to make a wonderfully complete but horrible to use interface?
slimandy Forum Pro • Posts: 16,267
Re: they look about the same size to me
They do? Try picking them up.
www.andrewsandersphotography.co.uk
 slimandy's gear list:slimandy's gear list
Sony RX100 II Fujifilm X-T1 Fujifilm X-E1 Nikon D700 Nikon D200
I would have thought the most logical comparison was the Fuji 18~55 vs the Nikon 24~70, and he'd still have made his point. Small primes even it out to an extent, but are you only going to use small primes? Are you going to carry just one lens all the time?
If the bigger sensor is what matters most to you then you made the right choice. Personally I was shooting a Nikon D700 FF camera and have switched to Fuji X-T1. In fact I still have both but I rarely use the Nikon. I did try the X-T1 and a Nikon Df at the Photghraphy Show at the NEC before making my choice.
