>>>Monday Macro/Closeup June 16 - 22<<<
Started Jun 16, 2014 | Discussions
djddpr Veteran Member • Posts: 5,381
Re: Surface Tension
Sergei,
A splendid composition with complementary background.  Well titled.
David Dollevoet
Re: The long-legged fly, ~9 mm body length.
Henry,
That is very close -- difficult.  But you pulled it off.
David Dollevoet
Briansdad1
Briansdad1 Senior Member • Posts: 2,968
Focus Stacking Freeware, Camera and Macro filter Comparisons
I've been experimenting with focus stacking software. A couple of commercial ones "expired" on me but yesterday I found some freeware, CombineZP. (More on the software later). I took macros of the same subject and with identical lighting (somewhat different angles though) using my FZ-70 and Nikon D3100, each paired with an Olympus B-Macro and then a Opteka 10x. Each camera was set to full manual. Multiple images at slightly different focus depths were taken.
The Nikon was first and I had difficulty keeping alignment when I rotated the focus ring. Regular incremental focusing was even more difficult. The FZ-70 was, in contrast, much easier. The  "clicks" of the thumb focus wheel made increments a breeze., and more steady. Therefore, I got fewer usable samples for stacking for the Nikon than I did for the Panny. (In fairness to the Nikon, it was first and I think practice made me better by the time I got to the Panny.) Below are both results for the Panny but the Nikon only has the B-macro image because of too few usable samples from the Nikon-Opteka combo to make a good stack.
Exposure settings and distance from subject to background foliage might account for some differences in color and bokah for the sets. The two cameras shoots were on separate days so the fruit might have changed dolor too.
There was no PP done on any of these images except with CombineZP, as indicated. All frames were JPGs.
These are, I believe, a wild rose hips about 2.5 mm across.
First, A single frame from the FZ-70 + B-Macro
FZ-70 + B-Macro, 13 frames, merged with CombineZP:
A single frame from the FZ-70 + Optecka 10x:
FZ-70 + Opteka 10x, 21 frames, merged with CombineZP:
Nikon D3100 + Olympus B-Macro, 1 of 23 frames:
Nikon D3100 + Olympus B-Macro, Stack of 23 frames with CombineZP:
CombineZP is Windows freeware with a mild learning curve. It crashed my computer a couple of times until I set the .exe compatibility to XP SP3. (It appears development ended in the Vista era and I avoid Vista). Stable after that. It is a memory and resource hog, though, so don't plan to multitask if you decide to try it. It can be set for any one of or all six stacking algorithms. All six takes time but it's worth it as results vary a lot. Here are relevant links:
A blog discussed CombineZP, where there is a link for a Yahoo group dedicated to CombineZP on this page.
What passes as a home page for CombineZP
Download link for CombineZP
BTW, Tripod is a must.
I'm not a pro. Images I post are unrestricted. Copy, edit, re-post here as part of the tread or elsewhere. C&C always welcome and encouraged - I'm not touchy about the negatives.
 Briansdad1's gear list:Briansdad1's gear list
Panasonic Lumix DMC-FZ70 Panasonic Lumix DMC-FZ1000 +6 more
Briansdad1
Re: Flower close up
Nice composition, fireworks-likeĀ
Bill
Briansdad1
Re: Hoverfly (FZ200 + 250D)
Well done. Great color.
Bill
Briansdad1
Re: Lunch!
YES!
Bill
Briansdad1
Re: Poppy..
I think the collection of seed pods contrasted by the poppy make this image.
Bill
Briansdad1
Re: So darned prickly...
Good title! Well done.
Bill
Briansdad1
Re: May Flower
May flowers look a lot different around here! (Little blue ground flowers) Those are spectacular.
Bill
Briansdad1
Re: Surface Tension
Well done. Very professional image.
Bill
sherman_levine
sherman_levine Forum Pro • Posts: 10,037
Re: Focus Stacking Freeware, Camera and Macro filter Comparisons
Bill,
Why do you change the camera focus? It seems to me that you want to keep focus constant (i.e. use manual focus and set it once) and change the focal plane using a focusing rail
 sherman_levine's gear list:sherman_levine's gear list
Panasonic Lumix DMC-FZ1000 Nikon Coolpix P900
Briansdad1
I'll have to try it again to confirm but as I recall using the rail changed the image size which made the accurate alignment in the stack impossible. Well, I didn't actually try the stack with image size differences. I just assume that would be a problem.
Bill
Robiro Veteran Member • Posts: 6,023
Fluid exchange
Ants exchanging fluids...
I believe one of the ants is actually feeding the other with honeydew collected from the aphid colony both are taking care of.
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DMC-GX8 Panasonic 12-35mm F2.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S Panasonic Leica 100-400mm F4.0-6.3 ASPH
Briansdad1
Re: Fluid exchange
That's a really great image, Robiro.
Bill
Re: Flower close up
Beautiful picture! I may never see this flower in my own eyes, so thanks for sharing!
What? It has eyes? I guess there are no hoverflies in caves...
Nice picture!
Re: Lunch!
You mean all those multitudes of microorganisms living on the surface?
Re: Poppy..
Bruno, it must have been taken in Austria. I am sure. It never rains on the Sunny Side...
Nice image you got!
Both are truly beautiful! Nice work!
Re: May Flower
Love the light. Love the composition. Very good!
