Image Stabilisation on S120
Started Jun 13, 2014 | Questions
Johnwmorgan New Member • Posts: 6
Dumb question:  I'm sure on my friend's S120, if you move the camera around slowly, the image stays perfectly central on the screen i.e. IS working I assume.  Am I mistaken or is this how IS works i.e. via some small servo motors etc.
The reason I ask is that my new S120 doesn't do this.  If I move it around slowly to simulate shake, it does nothing!
Yet if I switch IS off, my red camera shake warning glows about three shutter speeds faster than when it's switched on.  I guess that means it actually is working, although I'm sure my friend's actually did something mechanical to do this?
Am I going nuts here or is all this stabilization done silently and I was just dreaming previously?  Sorry for the long question
Canon PowerShot S120
brianj Forum Pro • Posts: 14,657
Re: Image Stabilisation on S120
You need the IS set to 'continuous' in the main menu.
Brian
 brianj's gear list:brianj's gear list
Canon PowerShot ELPH 330 HS
Johnwmorgan OP New Member • Posts: 6
Hi Brian
Thanks for your input.  I have tried it on all the different settings.  I guess my question is -- should I be able to see no movement in the viewfinder as the camera is moved around slightly to simulate 'shake'.
John M
Johnwmorgan wrote:
Hi Brian
John M
I don't have a S120, but my superzooms certainly steadied the movement especially at full tele when set to continuous, it was very obvious.  Its not so easy to see at wide angle.
Brian
Ah that's a good point Brian, I'll try and see if it's noticeable on full zoom. Thanks John M
Woody W.
Woody W. Senior Member • Posts: 2,526
I would also suggest that, while reduced, almost any movement large or slow enough to be conscious is probably too much for the system to fully counteract.
- Woody -
Equipment: Enough. For now.
Quote: 'The only thing some people will believe is their own eyes. But in the realm of the quality of a printed image, is there really anything else that can be believed? '
 Woody W.'s gear list:Woody W.'s gear list
Canon EOS 760D Canon EF 50mm f/1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 24-85mm f/3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS STM
- Woody -
Agreed Woody, just wondered why my friend's S120 seemed to do this compensation routine which you could see happening - and mine doesn't.  Thought maybe Canon had changed the sytem between versions perhaps.
J
Woody W.
I would also go back to the full time vs on shutter modes. When you are just holding with the preview on, you can usually see a difference, but it will still usually not fully dampen deliberate movements.
- Woody -
- Woody -
Thanks Woody, I will try that also. JM
