Q7 + FA135
Started Jun 8, 2014 | Discussions
fotoword
fotoword Regular Member • Posts: 152
Q7 + FA135
Shot at F8 in Manual mode 1/500th and -0.3EV with auto iso at 125.  Was surprised that with adapted lenses you can still adjust ev in Manual mode while using Auto ISO. Can't recall if this was available on the Q with adapted lenses.  It's still not available with native Q lenses.
Anyway one shot with the FA135.  Still a lot of purple in the edges but I guess that's the lens/sensor combo.  Couldn't removie it with Capture One Pro 7.
Thanks,
Paul
 fotoword's gear list:fotoword's gear list
Pentax K-5 Pentax Q7 Sony Alpha 7 Panasonic Lumix DMC-GM5
Pentax Q7
MikeSul
MikeSul Regular Member • Posts: 362
Re: Q7 + FA135
Here is your photo after a couple of seconds processing in Lightroom. I removed the chromatic fringe and adjusted the WB plus added a bit of clarity. More could be done with RAW and more time. I hope it is to your taste
Mike S
 MikeSul's gear list:MikeSul's gear list
Pentax K-3 II Pentax K-3 Sony Alpha a6300 Pentax K-1 Samyang 14mm F2.8 IF ED MC Aspherical
drummercam
drummercam Contributing Member • Posts: 763
Re: Q7 + FA135
The purple is gone, but the fringe area is still visible, which is my experience also with the FA 135mm -- it simply has massive fringing.  Nice job correcting it, though, and a pretty good pelican shot to start with.
 drummercam's gear list:drummercam's gear list
Pentax K-01 Pentax K-30 Pentax K-3 Pentax K-S2 HD Pentax-DA 20-40mm F2.8-4 ED Limited DC WR
fotoword
fotoword OP Regular Member • Posts: 152
Re: Q7 + FA135
Hi Drummercam,
Thanks for the reply and the compliment.  I would have to agree about the pf on that lens but I do like the way it renders the image otherwise.
Paul
fotoword
Re: Q7 + FA135
Hi Mike,
Thanks for the reply and the effort you put into correcting the pf.
I think the same can be achieved in Capture One Pro 7 but it seems you have to do more work.
The quick fix is to select the Chrome Ab and Purple Fringing check-boxes (but the pf check didn't really seem to do much). I then tried the colour pallet and selected the purple area and unsaturated it. Unfortunately it also seemed to remove colour from other parts of the image.  I guess LR seems to be more advanced in that area.
To be honest I liked the original colour better, I just felt it suited the subject, but that's just my personal taste. I guess your white balance adjustment gave it a more natural look.
Again, thaniks for the effort.  Appreciated.
Paul
Mike S
