Canon EOS EF Lens to SONY NEX E Mount Adapter
Started Jun 6, 2014 | Discussions
FastUno Regular Member • Posts: 110
What do you guys think of this adapter, any good?
I want to add a Canon 100mm Macro lens to a Sony A6000.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270947685922&ssPageName=ADME:X:RTQ:US:1123
Sony a6000
HaroldC3 Senior Member • Posts: 1,568
Re: Canon EOS EF Lens to SONY NEX E Mount Adapter
As long as you don't care about AF, because that adapter does not have electronic contacts.
 HaroldC3's gear list:HaroldC3's gear list
Canon EOS 7D Canon EOS M Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +1 more
Grassfed Forum Member • Posts: 57
Or aperture, which would probably be the bigger issue if he planned to use that lens for macro pics.
 Grassfed's gear list:Grassfed's gear list
Sony Alpha NEX-5 Canon EOS 60D Sony a6000 Canon EF 50mm f/1.8 II Canon EF 85mm f/1.8 USM +9 more
FastUno OP Regular Member • Posts: 110
When doing this specific macro photography I always set the f=8.o or 11.0, shutter speed to 1/125 & I always set the ISO to auto and always flash on.
Will I be able to at least put cam in M (full manual), fix f=8.0, 1/124, & have AUTO ISO with manual focus?
JeffGo Contributing Member • Posts: 832
You need an adapter with electronic coupling to control the aperture and IS on EF lenses, not just AF (which is slow). I haven't tried a cheap adapter with a manual diaphragm so I don't know if that solves your problem. Setting an aperture on the cheap adapter, using M + fixed shutter speed + Auto ISO should work OK.
 JeffGo's gear list:JeffGo's gear list
Panasonic Lumix DMC-TS20 Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-7 Sony E 18-55mm F3.5-5.6 OSS Voigtlander 28mm F2 Ultron +11 more
OK, it sounds like it will do what I want it to do & it saves me from buying a used Canon 60D to use with my Canon 100mm 2.8 macro lens that I have & LOVE!!!!
I wish Sony had an equivalent lens at the similar price range.
Thanks.
Once I get it, I will post my review & comments.
Does your lens have an aperture ring?  If not, you'll still need a canon body to set your aperture to 8 before you take it off the body so that the aperture stays at 8.
Except it has an aperture ring/iris built into the adapter.
You could always get a Canon FD 50mm f1.4 lens and FD->Nex Adapter and then a Vivitar 2x/macro teleconverter. It's both a 2x teleconverter and 1:1 macro converter in one.
Total for all of this would be $150.
Here's a post a made a while ago about it.
http://www.dpreview.com/forums/post/53600871
Yep, you're right. My bad.
