Aperture 3.5 not compatible with Yosemite
Started Jun 5, 2014 | Discussions
Filippo Ventura New Member • Posts: 4
Hi.
Just one more information about speculation on the future of Aperture.
The latest version, 3.5, can't run on MacOS X 10.10 Yosemite.
I found it out while testing the new OS on a USB drive where I had, last fall, installed OS X Mavericks before making the final installation on my internal drive. So I had all my software installed on that disk and upgrading to Yosemite I couldn't run Aperture anymore. The icon itself is greyed out and launching it a message popup saying: "You can't use this version of the application "Aperture" with this version of OS X".
So now we have three scenario:
1) A minor update to make it compatible
2) A new major release
3) Aperture is dead
Ww will know in next months.
Bye,
Filippo
Dave Braun Contributing Member • Posts: 588
Re: Aperture 3.5 not compatible with Yosemite
Filippo Ventura wrote:
Hi.
This means nothing ! Yosemite has not been released yet ! No software will be compatible before release !
3) Aperture is dead
Bye,
Filippo
OP Filippo Ventura New Member • Posts: 4
True.
But many softwares run anyway, Aperture and some others don't.
Mustafa Senior Member • Posts: 1,327
6
3) Aperture is dead
Or 4) Apple will buy Adobe out of its petty cash drawer, and will resolve the 'LR v. Aperture' squabbles overnight.
Chad Hardy
Chad Hardy Senior Member • Posts: 1,192
Hi.
3) Aperture is dead
Bye,
Filippo
Im going with 1, although they would really need to overhaul the UI to make it look nice with Yosemite.  Interesting to see what they do.
 Chad Hardy's gear list:Chad Hardy's gear list
Fujifilm X-T1 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 56mm F1.2 R Sony RX100 III Olympus E-M1 +16 more
Chad Hardy
Hi.
3) Aperture is dead
Bye,
Filippo
The purpose of a beta is to allow all developers to check compatibility with their software.  That is exactly what it is for.  However Apple probably just has some work to do on Aperture.
I see no reason why Apple wouldn't want to allow Aperture to work, unless they already know they are going to need to update it for compatibility.
Walter Contributing Member • Posts: 503
Anybody use Aperture?
Walter
 Walter's gear list:Walter's gear list
Canon EF 70-200mm F4L IS USM Sigma 50mm F1.4 DG HSM | A Fujifilm X100S Canon EOS 7D Mark II Canon EOS 5DS +5 more
Chad Hardy
Walter
With Yosemite or with current OSX variants?
I was thinking any variant... I tried it and was underwhelmed....just curious how many use it and like it.
Walter
PeterGuyton.com
PeterGuyton.com Senior Member • Posts: 2,330
Walter
I use it and find it superior to LR in most respects (not all).  I believe you need to use it more than try it to appreciate it.  I myself have been using LR and Aperture in parallel for about a year and have been "underwhelmed" consistently by LR.  I actually WANT to like LR more, it's just not happening.
 PeterGuyton.com's gear list:PeterGuyton.com's gear list
Sony a9 Sony a7R III Sony FE 55mm F1.8 Zeiss Batis 25mm F2 Sony FE 70-200mm F2.8 GM OSS +13 more
Chad Hardy
Walter
Oh I have used it a bunch.  I actually love it for a few things:
1.  Actually quicker to post process images, because browsing and editing is done seamlessly in the same window.  No swapping between Library and develop mode.
2.  You can brush every adjustment into the image.
3.  filters and finding images that have metadata is just easier and quicker.  I understand LR quick collections and the metadata filter bar at the top, but Aperture just does it better.
4.  Better sharing/integration options if you use other Apple devices.
If I had some assurance from Apple they were committed to continual development and not just life support I would use Aperture exclusively.  However it seems to have been all but abandoned.
At this point I have been on LR for the past 8 months and won't change back unless Apple commits.  LR is just fine, and I know Adobe will continue to improve it.
Brewse Regular Member • Posts: 102
Hi.
Runs fine under OS X 10.10 beta on my Retina MacBook Pro.
 Brewse's gear list:Brewse's gear list
Sony a6500 Nikon D850 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Micro-Nikkor 60mm F2.8G ED Nikon AF-S Nikkor 50mm f/1.4G +8 more
ixfinito New Member • Posts: 1
It seems to work ok, but when trying to view newly imported images, it will become distorted or corrupted after loading or sometimes even after a couple of seconds. This is only in appearance, the file is ok if you view it elsewhere. Read somewhere else that it happens when editing or using plugins. Tried repairing and rebuilding database without luck.
In case you are wondering, iMovie and Final Cut Pro and Photo Booth are not available for you to run, yet, but there's a workaround which seems to work fine. All and all, I think this is just all a consequence of being such an early release and will these issues will most likely get fixed as weeks go by.
Hi.
Yep, after reinstall it runs even on may old Mac Book late 2008.
It didn't run after upgrade to Yosemite but, after downloading and installing it through App Sore, it works. I didn't test how it works, but at least it launches.
bye,
Filippo
robgendreau Veteran Member • Posts: 6,070
It depends on your needs, but as an asset manager I find Aperture is harder to use than LR, and I have both. I really wanted to continue using Aperture, but as I got more photos and had to do more management of them (I reference them, BTW) I found myself ignoring Aperture more and more. LR works with your existing folder structure much more easily IMHO. I move photos off my SSD frequently now, and just dragging the folder in LR works fine. With Aperture I have to open a file dialog to "move masters," which is just that little bit annoying such that I stop doing that and started using LR instead. And the structure is just what the folder structure is in the Finder; I don't really see why Apple went with the whole project/album/folder thing; I just don't find it as intuitive as LR.
I liked the search function in Aperture, but I've come to appreciate the interface LR uses. Maybe it's because I have a bigger monitor now; Aperture seems more into floating boxes, which worked when I used a laptop more. Now not so much. And I prefer how LR lets me keyword, since I think it handles hierarchy better.
I think that the changes that will come in Yosemite will be in two main areas, organization of photos over all Apple devices and iCloud (Photostream was NOT that solution), and image editing. People here tend to organize photos far more efficiently than the average Apple user, who is randomly taking shots with iPhones, iPads and cameras constantly, and who is also receiving photos and videos constantly. None of which are "projects" or "shoots" or organized in any way shape or form. I think Apple's goal will be to get that under control, which has got to be something much harder than what LR or Aperture currently does. Both these applications assume someone who already has photos organized much more rationally.
Rob
Chad Hardy wrote:
Walter
 robgendreau's gear list:robgendreau's gear list
Pentax K-1 II Pentax FA* 50mm F1.4 SDM AW
noirdesir Forum Pro • Posts: 13,632
I don't know what started the idea that Photo Stream is for organising photos. Photo Stream has one purpose and one purpose only: automatically transport/spread all images from one device to all other devices.
lumigraphics Veteran Member • Posts: 3,320
Aperture is dead, although there will be a compatibility update. RIP.
Sonny500 New Member • Posts: 2
This information is incorrect. Please look at this video and read the latest news:
https://www.youtube.com/watch?v=IibYc0ee7g0
http://www.aperture-presets.com/apple-aperture-on-os-x-10-10-yosemite
Following these updates and since I am an Apple developer, I installed DP3 (OS X 10.10) and Aperture 3.5....I have no issues running my daily routines with Aperture.
DP3 is pretty stable and Apple already announced an update to Aperture to further increase its compatibility to OS X 10.10.
Meer
Meer New Member • Posts: 23
The bug of garbled images has been resolved, apparently not by modifying Aperture but by some fixes in Yosemite (developer preview 4). However there is another bug  - if you zoom in (either by the z key or by command-shift-=) the imagewindow turn medium grey. This doesn't happen if you load the same library in iPhoto. It also doesn't happen if you switch on quick previews.
 Meer's gear list:Meer's gear list
Panasonic Lumix DMC-GM5 Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 Olympus M.Zuiko Digital 45mm F1.8 +9 more
Calxoddity Regular Member • Posts: 391
When I downloaded the public beta of Yosemite, Aperture also downloaded an update.  It's version 3.5.1 45109900000000.1
I did the zooming as described above and it all worked as per normal, so might have been fixed or is machine-specific.
Calxoddity
'Turning up in the oddest places...'
 Calxoddity's gear list:Calxoddity's gear list
Nikon D5100 Nikon D7500
