Saturn With EXIF Data
Started Jun 5, 2014 | Discussions
Frizzen
Regular MemberPosts: 193
Jun 5, 2014
Straight from the camera NO post processing
Frizzen
Frizzen OP
Re: Saturn With EXIF Data
In reply to Frizzen, Jun 5, 2014
Sorry, I don't see it here. It is on the picture, but when I posted it here it is gone. Sorry. I thought
I had it.
Frizzen
Frizzen OP
The EXIF data is on the picture, I can see it while still in the camera, and in the program I use
to view it. I took a picture of what I see in the program, Saturn has NOT been post procssed
in any way.
brianj
Forum ProPosts: 14,657Gear list
in any way.
Maybe when your editing program saves the final image it strips the exif, it could be a setting, for example, in paint shop pro 9 that I use, in the jpg save as box, the option to save EXIF can be turned ON or OFF.
Brian
 brianj's gear list:brianj's gear list
Canon PowerShot ELPH 330 HS
Frizzen
Frizzen OP
OK, this has not been in the program.
Frizzen
Frizzen OP
Didn't work. I give up?
brianj
That's interesting, do you upload your images through the usual dpreview process that uses the adobe flash plugin, http://www.dpreview.com/galleries/upload
What browser?  Maybe you have discovered a bug somewhere.
Brian
Frizzen
Frizzen OP
This one I cropped in the camera. If it still don't have the data mebby the I-Pad is stripping it
somehow, I will try the computer
brianj
It may be a fault with the i-pad upload that dpreview don't know about.  If you can confirm that it can be reported in the Site Feedback and Help forum.
Brian
Frizzen
Frizzen OP
OK I'm trying from the computer
Frizzen
Frizzen OP
That worked!    So the I-Pad strips the data.    Now we all know.
brianj
It might not be the i-pad, it could still be dpreviews upload software which might be different for different device types.
Glad to see you succeeded though.
Brian
Frizzen
Frizzen OP
OK,, I tranfsferd two from the I-Pad to the computer, now lets see if the data is here
Frizzen
Frizzen OP
OK mystery solved.  Don't post from a I-Pad if you want to save the EXIF data.
Now you all can see my data
Augustin Man
Veteran MemberPosts: 6,387Gear list
I always thought your images are OUTSTANDING, simply awesome ! Of course I believe they are genuine SX50 shots, but if you're anxious about showing EXIF, I advise you simply read the card on the laptop, or put it in an USB card reader. The EXIF information should be there.
All the best,
Augustin
P.S. OK, I see now you fixed the problem Happy shooting!
 Augustin Man's gear list:Augustin Man's gear list
Canon PowerShot SX50 HS Nikon Coolpix P900
unknown member
(unknown member)
In reply to Frizzen, Jun 6, 2014
All I can say is, I wish I could do that.
Thanks for posting and showing what great work can be accomplished with the equipment, have a great day.
http://www.dpreview.com/galleries/tags/22314
John
 j2l3m7's gear list:j2l3m7's gear list
Canon EOS 70D Canon EF 100mm f/2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM Canon PowerShot SX60 HS Canon EF 85mm f/1.8 USM +10 more
KJaay
Senior MemberPosts: 4,997Gear list
Very skilled shots, I always enjoy!
KJ
 KJaay's gear list:KJaay's gear list
Canon PowerShot S3 IS Fujifilm X-S1 Nikon Coolpix P600 Nikon Coolpix P900 Canon EOS 450D
