What are you going with? 10-18mm or New FE 16-35 for A7/R
Started May 15, 2014 | Questions
rsurya23
rsurya23 Regular Member • Posts: 121
I was wondering how many of you who own a Sony A7/r are buying/bought the 10-18mm or  decided to wait for the FE 16-35mm from Zeiss. I am aware the 10-18 can be used between 12-16mm with little PP correction.
I have the 35 F2.8 and Kit lens and need an Wide Angle. Also with corporate discounts i can buy the 10-18 directly from Sony for around $660.
Would be great to hear what made you decide! Thanks for the participation!
 rsurya23's gear list:rsurya23's gear list
Sony Alpha 7 Sony FE 35mm F2.8 Sony FE 28-70mm F3.5-5.6 OSS +1 more
Sony Alpha 7
EinsteinsGhost
Re: What are you going with? 10-18mm or New FE 16-35 for A7/R
If I had a7/7r/7s, I would pick 16-35/4. If I had an APSc body as well, 10-18 would be more logical (used on APSc and useable on FF).
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
nandbytes Senior Member • Posts: 5,565
there are suppose to be some new zeiss primes coming out for e-mount. I wonder what these are?
But anyway, I have a 16-35/2.8 and I am replacing it with FE35 and some other wide angle prime. Currently I have minolta 24mm/2.8 which is not ideal coming from 16-35 but hopefully I will be able to replace it with a nicer and wider prime.
So I guess neither lens is my answer.
Focus on what you have, not on what you don't.
https://www.flickr.com/photos/nandbytes/
 nandbytes's gear list:nandbytes's gear list
Sony Alpha NEX-7 Sony a6000 Samyang 8mm F2.8 UMC Fisheye Sony E 10-18mm F4 OSS Sony E 16-50mm F3.5-5.6 PZ OSS +3 more
Aasmund G Contributing Member • Posts: 883
I will buy the 16-35 when I have the budget for it. I currently have the 24mm and it is quite wide already so I think 16 will be fine on the wide end. the other option for me would be the 14-24 nikon. But getting native mount, OSS, probably lighter, and AF is worth something. Hopefully it will come in around the 1k mark.
 Aasmund G's gear list:Aasmund G's gear list
Sony Alpha 7 Sony 70-400mm F4-5.6 G SSM Sony FE 35mm F2.8
rsurya23
rsurya23 OP Regular Member • Posts: 121
Great inputs! keep them coming
I am not sure how much PP is needed in Lightroom to make the 10-18mm usable. I have seen some shots and they look great.
tex Veteran Member • Posts: 6,832
I have the 10-18
It does work in the middle ranges, better than i expected (A7R).  I also have the A mount 16-35.
Because I may be changing up my camera systems, I'm on hold for anymore E or A mount lenses for now.
tex_andrews, co-founder and webmaster of The LightZone Project, an all-volunteer group providing the free and open source LightZone photo editing software. Personal website: www.texandrewsart.com
"Photography is the product of complete alienation" Marcel Proust
"I would like to see photography make people despise painting until something else will make photography unbearable." Marcel Duchamp
 tex's gear list:tex's gear list
Sony Alpha 7R Pentax 645Z Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Rokinon T-S 24mm 1:3.5 ED AS UMC +15 more
dave
dave Senior Member • Posts: 1,310
I would wait for the 16-35/4 to come out. The full frame lenses have been getting twice the employee discount of the asp-c lenses, except the 70-200/4. The 16-35 should have better performance in the corners and less distortion then the 10-18. If the above holds up, it will be cheaper too.
Sony A7 Pentax K5ii Canon 5D
 dave's gear list:dave's gear list
Pentax K-5 II Sony Alpha 7 II Canon Pixma Pro-100
viking79
viking79 Forum Pro • Posts: 14,136
From what I have seen the distortion is obscene, and remember the 10-18mm is really only corrected within reason for APS-C sized sensor.  Things like astigmatism and other aberrations will be very large near the edges of the frame.  However, this might be fine if you have the lens already and/or don't mind this (say use it casually).
Otherwise I would buy the full frame lens, the corrections will be better near the edge of the frame, even if it follows trend of other recent ZEISS branded standard zooms and is mediocre, it will still be better than the APS-C lens used on FE.
If you aren't in a hurry I would wait for the new lens.
Eric
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
viking79
one more thing, if a person didn't already have the 10-18mm, and wanted it for 14 or 15mm use on A7R, you might look at a manual focus lens in that range.  I have seen good reports on Samyang 14mm f/2.8 (but also seen reports of centering issues), which is like a $300 or $400 US lens.
Eric
Grafix Inredning Forum Member • Posts: 62
If the new FE 16-35 has the same performance as the E 10-18 in the corners and edges on FF, I'd be very dissapointed. Low contrast and soft outside aps-c and the distortion is crazy. But its's a great lens on NEX/Ax000.
 Grafix Inredning's gear list:Grafix Inredning's gear list
Nikon Coolpix S33 Samsung NX200 Sony Alpha 7 Sony a6000 Canon EF 50mm f/1.4 USM +9 more
Dandrewk Senior Member • Posts: 1,094
Yes, agreed, there are perfectly great legacy glass options if you are willing to accept (for the time being) using an adapter and possibly not having AF.
The nice thing about legacy lenses is they hold value.  You can buy and use one for a few months until the 16-35mm is available, the choose to resell it at little or no loss.
 Dandrewk's gear list:Dandrewk's gear list
Sony RX1R II Sony Alpha 7R II Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony FE 90mm F2.8 macro +7 more
rsurya23
Today on Ebay i found a good copy of the RMC Tokina 17mm F3.8 for FD mount. I already have the adapters. It was good price so i bought it. I know the VC Heliar 15mm is pretty good but it was around $400 used. Once i get it i will post some pictures. Good thing is i can return it if i dont like it so im covered.
PVCdroid
PVCdroid Senior Member • Posts: 3,729
Show me a Wide/Ultra wide that doesn't have corner issues. You stop down and work with it.
 PVCdroid's gear list:PVCdroid's gear list
Sony Alpha NEX-5N Sony Alpha NEX-7 Sony Alpha 7R Sony Alpha 7R II
captura Forum Pro • Posts: 21,710
A UWA from the 16/28 on a Pana. 14/2.5 on any M43 camera that I've ever tried it on is rectilinear and shows zero corner or side issues. It's about 10 degrees equivalent and much sharper than on the 16/2.8.
