RX100 MK3 dimensions
Started May 14, 2014 | Discussions
Tonkotsu Ramen
Tonkotsu Ramen Senior Member • Posts: 1,885
Not wrong...
..in my experience.
I wear jeans that fit, and the canon S90 is easily pocketable, meaning i can literally slip it into one of the front pockets and forget about it.
The RX100M2 on the other hand, needed to be crammed in there, and it was not comfortable with it in the front pocket while trying to walk up a flight of stairs or with any other fast paced movement.
aatom Regular Member • Posts: 215
Re: RX100 MK3 When?
Here in England the 'expected' date (15th May) for the arrival of RX100 M3 is drawing to a close.
But no real info or images or release announcement.
So SONY when will it be?
aatom
(RX100 user fan)
 aatom's gear list:aatom's gear list
Panasonic Lumix DMC-LX3 Sony RX100 Pentax K-x Panasonic Lumix DMC-GF3 Panasonic Lumix DMC-G6 +1 more
technic Veteran Member • Posts: 8,932
Re: It's amazing.
Tonkotsu Ramen wrote:
The pop up EVF appears to be similar to the pop up (non bouncing) built in flashes. It should be just as durable (the one on my S90 never has issues). Except I think there may be an extra step to pull the EVF out a bit.
I hope it is as durable, but there is a difference: the EVF probably needs a flatcable with a huge number of wires, more vulnerable than the few leads for a flash. Will be interesting to see how they are making the connection to the EVF.
Re: RX100 MK3 When?
aatom
(RX100 user fan)
Did you skip most of the posts? The official announcement is expected on May 16th, not today. The info we already have is as solid as can be, I have no doubt these are the real images and specs (with maybe a few typing or translation errors); I don't think there is anything to add.
Re: RX100 MK3 When?
Mea Culpa - thanks Technic tomorrow will prove you right (I hope)
aatom
kwa_photo
kwa_photo Senior Member • Posts: 2,980
Re: RX100 MK3 dimensions
BPD7 wrote:
Funny, I have the x100s. It's not that pocketable. I bought the Rx100 on a sale day for $400. I LOVE this little camera. It's so pocketable. It's the perfect complement to my x100s....
...If I were you I would get the Rx1002 when prices drop some. I wish mine had wifi. I use a wifi SD card so that takes care of that.
Thanks for this perspective! I really appreciate it! However, I don't see big price drops on the horizon.  If the rumors are true that mIII will be the in the $899 range, the current price of the mII is still compelling as is. I think we would see a big clearance on old mI stock though BTW, I do love the wifi on the RX10.
Ken
FujiFilm FinePix Moderator (PM with Q's vs. a public post please)
http://www.kwaphoto.com
 kwa_photo's gear list:kwa_photo's gear list
Panasonic Lumix DMC-LX5 Leica D-Lux (Typ 109) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX8 Panasonic 12-35mm F2.8 +6 more
EinsteinsGhost
Re: It's amazing.
Strips. They don't use individual wires. Same for flash. And LCD. Even if it had tiltable EVF, same issue. Collapsing lenses also need it. So it should be a non issue.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
Re: It's amazing.
I think what you call a 'strip' is what I call a 'flatcable'; still, there is a huge difference in the number of wires which means more vulnerable.
EinsteinsGhost
Re: It's amazing.
Not anymore than a plethora of them inside a digital camera: retractable lens, pop up flash unit, articulating LCD (probably most demanding) and pop up or articulating EVF. They are designed for the purpose, and you only need one.
BertIverson Veteran Member • Posts: 3,451
Jason -- Re flimsy pop-up EVF
Jason Reuschlein wrote:
You have to wonder too how durable a pop-up EVF could be. You'd be pressing against it.
Maybe the Sony engineers thought of this possibility and tested it a million times using a robot.
Sort of like testing a car steering wheel to see if it falls off after a few thousand turns. Most steering wheels do not fall off.
Bert
 BertIverson's gear list:BertIverson's gear list
Sony RX100 Sony Cyber-shot DSC-RX10 +4 more
Sh_la_m
Sh_la_m Contributing Member • Posts: 878
pocketability - size compared to Olympus XA
Baggy pants are the key to pocketability, or maybe a man-bag. Sometimes it is so nice to be of the primary purse-carrying gender.
I was very happy to see that the new RX100 may be very similar in size to my old Olympus XA from the early 80's, when pants were baggier.  It definitely does not fit in my jeans-of-today pockets, but will happily fit in the side pocket of the cargos I hike in, the front waistband pocket of my Clik Elite Cloudspace backpack, a smallish purse, etc.
Olympus XA - 102x64.5x40mm, 225g
RX100iii (rumored) - 101.6×58.1×41.0 mm, 290g
I am not sure how much the "protrusions" add to the RX, but suspect it is enough to make it about the height of the little Oly. Just hope that extra 65g doesn't weigh me down…
ncsakany
ncsakany Senior Member • Posts: 1,652
Re: Wrong…..
DFPanno wrote:
...in my experience.
Unless you tight wear jeans cut to accentuate your rear-end the rx100 is easliy pocketable.
Not everybody wears mom jeans you know
 ncsakany's gear list:ncsakany's gear list
Olympus Tough TG-4 Sony Cyber-shot DSC-RX100 IV Sony Alpha 7R II Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +2 more
Re: It's amazing.
yes, but most of those move very little. I have a lot of experience with the inside from cameras, and flatcables that bend/turn repeatedly break down relatively often after prolonged use.
Re: pocketability - size compared to Olympus XA
I used an XA for a long time when I was young, alongside my Olympus OM gear. I never had baggy pants, so probably it was stored in a coat pocket; can't remember the size ever was a problem, so the RX100-3 should do fine
elliottnewcomb Forum Pro • Posts: 10,489
Hope everyone has seen the real pics and specs on other threads.
I always clarify between a pants pocketable, and a jacket pocketable. Categorical difference to me.
I have a favorite winter coat, 4 big outside pockets, exist rx100 & new m3 will fit fine as it has for 2 winters, every day.
I have a favorite spring/fall jacket with 4 big outside pockets, same, both will fit, every day.
Which takes us to Summer, the active outdoor season without a jacket.
I have summer pants, baggy linen pants, loose jeans, shorts, most fit the rx100, (in or out of my pocket shaped dustproof case).
Pants pockets will be more of a challenge for the m3 when I get it, the extra depth 3/16" is the thickness of the control ring, easy to visualize that way.
My point is, you/we should think about pockets that make taking it with us everyday when buying a jacket for 3 seasons, and a few pairs of loose pocket pants and/or shorts for summer. Think of them as camera accessories.
At +20% weight, it probably will go over the comfortable weight even if it fits in a pants pocket. It may also pull your lightweight jacket awkwardly off to one side, I now often put my wallet, (always heavy with money of course), in the opposite jacket pocket for some balance. I can see m3 not being as easy for sure,
But, it will still be in the pants pocketable category (for some), certainly in the jacket pocket category for everyone, and nothing with a fixed lens it's size comes anywhere close to it's ability.
What I try to do is think how it would be if the m3 was the original miniature marvel? There would be lots of talk about how AMAZING the little wonder is.
The original, or m2 certainly are viable choices, used or new, and the price of those is getting down to a very appealing level, rather that their initial, 'what choice do I have' prices.
This sunglasses case has an ugly logo, (I like it, who would bother stealing it?) but the shape, size and material are wonderful for slipping in/out of a pants or jacket pocket.
It's not obvious, but you leave the wrist strap out of the zipped end of the case, it hangs at the ready for a quick draw, like a mouse tail, so you don't ever have to jam your hand in your pocket to get it out. It is natural to put it on your wrist, never to drop the slippery devil. The hook hangs on a pants loop or arm of a beach umbrella (above sand, water, and children. M3 will fit.
btw, looking at the pics, I think the lens is a bit smaller diameter, lowered in order to allow the flash behind so EVF could fit in flash original position.
Soooo, will existing filter adapters fit the new lens? MagFilter gives you a spare adhesive metal ring, I believe it will fit either size lens, not sure about Lensmate or Sony's adapters, never handled one.
My home-made extension tube might be too big, what a loss, hah. Well, there is duct tape.
Elliott
 elliottnewcomb's gear list:elliottnewcomb's gear list
Sony RX100 Sony RX1R Olympus Stylus 1 Sony Cyber-shot DSC-RX100 III +1 more
Sh_la_m
Re: pocketability - size compared to Olympus XA (OT)
Let's hope that the rx100 III is just a good a photographic companion, and as much fun, as the XA was. Funny, I just a few weeks ago saw a guy using his XA and flash for street shooting in Manhattan. He was having a great time. And took a photo of my 20-something daughter. LOL.
EinsteinsGhost
Re: It's amazing.
Retractable lens does so every time you turn camera on/off. I actually opened my Sony F828 out of curiosity a while ago, and noticed flatcables that are bent every time I use the swivel for LCD articulation... which is every time (now for more than ten years). Think laptop... everytime you lift the screen... and so on.
newellj Senior Member • Posts: 1,048
Robert Deutsch wrote:
0lf wrote:
The RX100 is already borderline pants pocketable. This one is simply not pocketable at all.
It was the main advantage of RX100 serie against GM1...
I routinely carry the RX100 in my shirt pocket. The Mk,II's additional weight and thickness put it in the questionable category for shirt-pocketability, which is one of the reasons for my staying with the Mk.I. The Mk. III ups the ante with some very worthwhile improvements--and an additional 2mm thickness. (An extra 9 g. is inconsequential.) If I want a small-but-not-shirtpocketable camera, I already have a GM-1. I'll have to see how it plays out.
Bob
Not sure what you're wearing for shirts, but I have no trouble getting the MkII into dress shirt pockets of various makes.  There's not a lot of room left over, but it works easily.  I had a MkI originally and nothing changed for me when I got the MkII.
YPMV...
John
 newellj's gear list:newellj's gear list
Sony RX100 II Olympus OM-D E-M5 Panasonic Lumix DMC-G5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH +5 more
Follow-up thought - the difference I did notice between the MkI and the MkII was not the extra millimeter or two of depth but the weight increase.  Not a deal-killer but in the shirt pocket the difference was noticeable.  The MkIII seems to have added relatively little additional weight, which is nice.
Robert Garcia NYC Senior Member • Posts: 1,716
