E-M10 anti shock
Started May 14, 2014 | Questions
Oldroadster
Oldroadster Junior Member • Posts: 47
E-M10 anti shock
I am considering buying an E-M10 but I have a question about the anti shock setting. Does it have the 0 second setting that Olympus is adding to other models by firmware update or should we expect a similar update for the E-M10? I have read a copy of the manual but have been unable to find the answer elsewhere. Thank you in anticipation.
Olympus OM-D E-M10
sigala1
sigala1 Senior Member • Posts: 3,634
Re: E-M10 anti shock
The E-M10 does NOT have the zero-second anti-shock, and there's no indication that Olympus is planning to add it.
It's possible (just speculation, I could be wrong), that it's something that the shutter mechanism in the E-P5 and E-M1 are capable of and the E-M10 is not.
I would highly recommend that you buy an E-P5 instead of an E-M10. Once you know about shutter shock, you WILL find it in your photos and it will be a constant source of aggravation.
LarsLeibgott
LarsLeibgott Regular Member • Posts: 363
In the 43rumors comment chain about a leaked E-M1 firmware update, a guy posted a link to a (now removed) page showing that Olympus was planning to add 0 second anti-shock to the 1.1 firmware update for the E-M10. I wish I had had the sense to screen cap it.
So, at the very least it's been rumored. For whatever that's worth.
tinpusher
tinpusher Senior Member • Posts: 1,345
It does have a 1/8 sec setting that is virtually undetectable.
At first I thought that I was getting shutter shock from the EM10 but I'm not so sure now.
I think that the lack-lustre IQ was due to other causes.
 tinpusher's gear list:tinpusher's gear list
Sony RX100 Sigma DP3 Merrill Nikon D3 Sony Alpha 7 Olympus OM-D E-M10
Andre Bomhof
Andre Bomhof Veteran Member • Posts: 4,561
Hi Oldroadster,
Seems like there is an E-M10 firmware update on the way which has the 0 second anti-shock setting:
http://www.43rumors.com/ft5-e-m1-firmware-gets-leaked/#disqus_thread
André
http://mcpint.zenfolio.com
'Keep on rockin' in the free world'
Mr Neil Young
Michael M Fliegel
Michael M Fliegel Senior Member • Posts: 2,950
If the EM10 shows evidence of shutter shock, Olympus will issue the firmware update for it which will fix the problem.  It is a great camera.
 Michael M Fliegel's gear list:Michael M Fliegel's gear list
Olympus E-520 Olympus PEN E-PL2 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 +11 more
Oldroadster
Oldroadster OP Junior Member • Posts: 47
Thankyou for the prompt replies. I have a G3 and a 45-175 which suffers from shutter shock noticeably and hope to up grade later this year. Looks like I need to save up a little more for the E-M1.
Andre Bomhof
I meant this bit from the 43rumors article:
"UPDATE: There should be a new E-M10 fw update too with following improvements:
1) Improved image stabilization during movie recording
2) 0-second value is added to the “Anti-Shock” mode"
André
Glen Barrington
Glen Barrington Forum Pro • Posts: 16,251
I have seen no evidence of shutter shock in the E-M10
I can't swear is never happens, but I can swear I haven't seen it.
 Glen Barrington's gear list:Glen Barrington's gear list
Olympus OM-D E-M10 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +11 more
baxters
baxters Veteran Member • Posts: 4,961
Re: I have seen no evidence of shutter shock in the E-M10
From the DPR EM10 review - last paragraph on Image Quality.
We were also pleased to find that, in our testing, the E-M10 did not prove to be susceptible to the shutter shock we saw from the PEN E-P5 - so the image quality is more consistently available.
Here's the Link
Nonetheless, of a FW update helps the EP5, it's welcome on other cameras too.
 baxters's gear list:baxters's gear list
Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6
Henry Richardson
Henry Richardson Forum Pro • Posts: 15,347
E-M5 firmware update too
Hope it gets added to an E-M5 firmware update too.
Henry Richardson
http://www.bakubo.com
Lyle From Canada
Lyle From Canada Senior Member • Posts: 1,509
Re: E-M5 firmware update too
What the heck is shutter shock? I have had no issue with my em10
Fuji x-pro1 with 14, 18, 23, 35, 60, 55-200, fuji x100s and WA adapter, fuji x10
 Lyle From Canada's gear list:Lyle From Canada's gear list
Ricoh GR Olympus OM-D E-M10 II Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 Olympus 14-150 F4-5.6 II
jkrumm
jkrumm Veteran Member • Posts: 8,928
I know it's weird, but you might not notice it until you don't have it. That's how it was with my EM-1. Suddenly a lot of my photos got a little sharper, but they always seemed sharp before. It's like having 20/20 vision and then moving to slightly better than 20/20.
John Krumm
Juneau, AK
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,040
1/8s anti-shock is not "virtually undetectable". It adds a very noticeable "sluggishness" to the feel of the camera. (At least on my E-M5 it does, and I assume the E-M10 with the same shutter is the same.) I have always felt that perhaps a shorter delay would be sufficient to battle shutter shock without causing a noticeable delay. So I would definitely welcome a 0s setting on the E-M5 and E-M10.
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +5 more
fevan
fevan Regular Member • Posts: 124
does the 1/8s anti-shock degrade IQ?
DimLS
DimLS Forum Member • Posts: 86
We must say bravo to oly for these firmware updates. I love my em 10 and if we get efc then it will be perfect for me.
newellj
newellj Senior Member • Posts: 1,048
Henry Richardson
I understand what you're saying, but I've never experienced shutter shock with my E-M5.  The E-M5 shutter doesn't seem to be particularly prone to shutter shock, possibly because of its lower top speed.
 newellj's gear list:newellj's gear list
Sony RX100 II Olympus OM-D E-M5 Panasonic Lumix DMC-G5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH +5 more
Henry Richardson
Doesn't the E-M10 also have the slower shutter like the E-M5?  This thread we are posting in is about the E-M10.  Also, I found at least one E-M10 shutter shock report:
http://www.dpreview.com/forums/post/53491861
I haven't been concerned with shutter shock with my E-M5, but recently as I was going through a bunch of photos from my trip to Turkey that ended not long ago I found several taken around 1/100 and 1/125 at short focal lengths that I would normally have expected to be sharp, but they sort of looked like the shutter shock examples I have seen.  I haven't bothered investigating and they may look that way for another reason, but it got shutter shock on my radar.   Would be nice if Olympus had a firmware update for the E-M10 and E-M5 with the new setting.
Henry Richardson
sigala1
Henry Richardson
While I agree the E-M5 is better than all other Olympus cameras without EFCS, evidence that it has shutter shock was posted to the internet back when it first came out.
If you've been using the camera without anti-shock turned on, I am SURE that some of your photos are a little blurrier than they otherwise would have been, you just haven't noticed it.
Like some other poster said about his E-M1, he didn't know he had shutter shock until after he installed the updated and turned on the 0-sec anti-shock and he reaiized his photos got sharper.
Paul De Bra
anti-shock does not degrade IQ, only improves it
Anti-shock just delays the shot being taken. This means the shot is taken after shutter vibrations have died down. IQ is not affected in any way except that blur due to the vibration is (partly or fully) eliminated.
