Sony vs Sigma blue and gray resolution measurements
Started May 14, 2014 | Discussions
docmaas Veteran Member • Posts: 4,950
For methodology please read these posts first for background on what kind of testing I am doing: http://www.dpreview.com/forums/thread/3669097#forum-post-53665179 and http://www.dpreview.com/forums/post/53653391
Sony Sigma civil war the Blue and the Gray
Well, here's blue from the Koren chart provided by Erik.
conditions: aperture f5.6 sigma 18-35 f1.8 at 18mm.
Camera further away from the target than yesterday.
SPP used to develop Sigma with sharp -7. Sony IDC used to develop sony with all neutral settings. Iridium Developer used to develop both with all neutral settings.
Note while you might be able to assess relative mtf it still has nothing to do with any other mtf measurement.
First the blue:
Sony A7r response to the blue chart. f5.6 18mm sigma 18-35 f1,8 iso 100
Sigma SD1 response to the blue chart. f5.6 18mm sigma 18-35 f1,8 iso 100
The sony response to the blue is surprisingly fat. It makes me wonder if the IDC is boosting the blue. Let's take a look at the same chart via iridient developer:
Indeed, Iridient shows a much more neutral response. However note that Iridient seems to find more detail in the sony image than sony does. Interesting.
I wonder how iridient compares to spp for the blue:
Sigma SD1 blue response as developed by Iridium -- nearly identical to spp
Note that while spp sharp is set to -7 no sharpening at all on Iridium. Looks like -7 is very close to 0 sharpening in actuality.
Now the gray:
Sony a7r aps-c mode response to the gray chart. f5.6 18mm sigma 18-35 f1,8 iso 100
Sigma SD1 response to the gray chart. f5.6 18mm sigma 18-35 f1,8 iso 100
Now the crops of the charts:
Sony
Notes:
In both cases the Sigma outperforms the sony.
The sony response to both the blue and the gray is surprisingly much more plump from sony Image Data Converter than that from Iridient indicating that IDC may be boosting response during processing.
Sigma spp results match those from iridient almost perfectly. In particular the sharpness setting of -7 seems to match the no sharp setting on Iridient.
Mike
Sigma SD1 Sony Alpha 7R
Aku Ankka
Aku Ankka Contributing Member • Posts: 591
Per pixel? Per image?
In a hurry now, so not really reading about your methodology. Are you measuring "per pixel"? By this I mean SD1 vs. 15Mp crop of A7r? If so, I don't see what is the point as the results don't tell anything about how much either camera resolved details.
Anyhow, if I have the time, I hope to repeat your test on my camera and to post the result. Terribly busy now though and my printer is broken so can't print the test target at the moment.
Cheers, Aku
Quack!
rjjr Veteran Member • Posts: 9,933
How do the images look at ISO 400, 800, 1600...?
No text.
xpatUSA
xpatUSA Senior Member • Posts: 7,139
Re: Sony vs Sigma blue and gray resolution measurements
docmaas wrote:
First the blue:
Thanks for taking the time to publish the results of what is obviously a lot of work. In the Sony above the rise of amplitude with frequency does mean that IDC is messing with the image data. That would put me off if I were a Sony candidate. The Sigma response is much 'better' from my POV.
Sony
Compared to slant-edge testing, the results gained from this method do seem to be easier to assess and more visually representative.
For camera performance analysis, I try to exclude as much converter processing as possible and have lately been using output from RawDigger and such. It's surprising how soft and noisy 'raw' images can be! Less surprising is how much 'pre-processing' goes into crap like Adobe Camera Raw which is guaranteed to destroy any X3F fed into it
Ted
Sigma DP2s Panasonic Lumix DMC-G1 Sigma SD10 Sigma SD14 Sigma SD1 Merrill +8 more
mike earussi Veteran Member • Posts: 5,732
I assume by your use of the Sigma 18-35 on both cameras you're using only The APS-C portion of the A7r.
But if you have the time I'd be interested in seeing the color response of the A7r FF compared to the Sigma.
Thanks again for your effort.
Erik Magnuson Forum Pro • Posts: 12,237
Gradient assumptions
While it's hard to be sure from these crops, the Sony looks almost black in the center of the thinner blue lines.  This may have to do with the demosiacking algorithm IDC uses making assumptions how the image is changing over the "gaps" in the blue pixels for certain gradients.  Then again, it could also be due to JPEG chroma subsampling.
I doubt you would use ever Sony IDC at default settings.
Erik
 Erik Magnuson's gear list:Erik Magnuson's gear list
Canon EOS 5D Mark II Canon EOS 450D Sigma SD10 Sony Alpha NEX-5 Nikon D3200 +28 more
docmaas OP Veteran Member • Posts: 4,950
Re: How do the images look at ISO 400, 800, 1600...?
Good question.  I'll test it today.
Mike
Re: Per pixel? Per image?
FF or aps-c on A7r is irrelevant because the pixels don't change size. The only thing that changes are the 2d dimensions. The center section and the target will be exactly the same size regardless of the setting on the camera.
It's an indicator of how well similar size pixels (4.9 micron sigma and 5 micron sony) resolve.  It's particularly interesting because the a7r has no aa filter so we can see what the absence of the aa filter does for the bayer image.  Of course a Nikon D800 (not D800e) in the mix would make things even more intersesting but incompatible mounts make that very difficult.
The whole point is see how much difference there is in resolution.  You do need to read the links I posted to get informed as to the theory behind the experiments.
Mike
Cheers, Aku
Quack!
Roland Karlsson Forum Pro • Posts: 24,303
And ... we already know that, given the same amount of MP, the Foveon will resolve more. And we already know that an AA less camera, with a sharp enough lens, will have color artefacts when doing aliasing.
Nice to get it quantified though.
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony Cyber-shot DSC-RX100 III Pentax K-3 Pentax K-1 +12 more
