I've been shooting RAW for years... not any more! X-T1
Started May 14, 2014 | Discussions
ScottP123
ScottP123 Junior Member • Posts: 27
9
I can't help but think that I will resume shooting in RAW again sometime... Right!?!?
I switched to JPEG fine only over the weekend to shoot action shots at my son's Lacrosse Tournament. I forgot to go back to RAW and shot more photos in JPEG.
The image file quality from the X-T1 is simply amazing to me. Are others finding the same thing.
For those of you that are shooting RAW what is the distinct advantage that you are experiencing by doing so?
The following images were capture in JPEG and processed with Capture NX... Thanks, Scott
The cleanliness of theory... is no match for the clutter of reality.
 ScottP123's gear list:ScottP123's gear list
Nikon D800 Fujifilm X-T1 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF Nikkor 50mm f/1.4D +7 more
Fujifilm X-T1
jl_smith
jl_smith Veteran Member • Posts: 3,669
Nice shots -- I still shoot RAW though
First, nice shots, and Fuji has the best JPEGs in the business IMO
That said, I still shoot RAW+JPEG.  Why you ask?  Easy - sometimes I like to edit the photo in a heavy fashion, and RAW lets me do that.
Plus, when I'm rushed, sometimes I like having the RAW as a backup because I can shoot which film simulation I want to start with later
And, if we must pixel peep - I can get more IQ from a properly processed RAW file.
Those things said, I'm certainly comfortable with JPEG-only, as long as I have the time to set up the camera appropriately between each shot.
JL Smith
www.smithclicks.com
www.flickr.com/photos/jl_smith
 jl_smith's gear list:jl_smith's gear list
Fujifilm X-T10 Samyang 85mm F1.4 Aspherical IF Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
jm10 Senior Member • Posts: 1,771
Re: I've been shooting RAW for years... not any more! X-T1
RAW + JPEG for me; the ability to pull out more details from a RAW file when appropriate and a better chance to deal with highlight recovery (happens to me alot...).
Nice shots! I like the #5 most of all but curious about the processing - when examining 100% you can see a fine square pattern like a mesh - is this intentional or possibly artifacts from Capture NX processing?
Thanks for posting!
jacob
 jm10's gear list:jm10's gear list
Ricoh GR II Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS
(unknown member) Senior Member • Posts: 1,321
7
"For those of you that are shooting RAW what is the distinct advantage that you are experiencing by doing so?"
Your fine, attractive examples are not lit by light with different color temperatures. Also, the exposure and dynamic range are not particularly challenging. I say this with absolutely no negative connotation or implication whatsoever. It's just the nature of the scenes you shared. And, they are lovely scenes.
t turns out the information destroyed during JPEG compression is redundant when:
  • The exposure is perfect
  • The dynamic range does not exceed the camera's data stream dynamic range
  • The white balance is perfect
Otherwise the discarded information during JPEG compression is required to the render the best possible image.
The more the above deviates from perfection, using all the data recorded when the shutter was open brings more benefit.
The scenes in my work typically have mixed color temperature and challenge the camera's dynamic range and signal-to-noise ratio (especially for shadow regions.I can expose for highlight detail or for optimum shadow region detail,,, but not for both.
Even when the scene is not that difficult, I can make exposure mistakes.
For my work in-camera JPEG compression is too risky for the benefit
There are the distinct reasons why I never rely on in-camera JPEGs,
 wchutt's gear list:wchutt's gear list
Fujifilm X-Pro1 Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +20 more
mmckeller Forum Member • Posts: 92
Still RAW + Fine JPEG for me, too; I guess I just like feeling I have more options in post.  Really nice looking shots, though - except #5 looks way overcooked compared to the others; much more noise, sharpening artifacts, and a very pronounced halo around the top edges of the rocks - like maybe the sky was replaced with one from another image.  It also looks sort of HDR-ish; was DR set to 400 on this one, or maybe shadows and highlights pushed and pulled a lot in post?
Mike
Ollie 2 Senior Member • Posts: 1,530
White balance.
Highlight recovery.
Both of which your otherwise fine images could do with attention to.
 Ollie 2's gear list:Ollie 2's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Olympus PEN E-P2 Fujifilm X-Pro1 +19 more
Miki Nemeth
Miki Nemeth Contributing Member • Posts: 992
William Chutton's excellent summary of why use RAW
wchutt wrote:
It turns out the information destroyed during JPEG compression is redundant when:
The scenes in my work typically have mixed color temperature and challenge the camera's dynamic range and signal-to-noise ratio (especially for shadow regions.I can expose for highlight detail or for optimum shadow region detail, but not for both.
Excellent summary. Thank You very much, William. All the best, Miki
 Miki Nemeth's gear list:Miki Nemeth's gear list
Nikon 1 V1 Nikon Df Sony a5100 Nikon 1 J5 Nikon AF-S Nikkor 50mm f/1.4G +27 more
howardfuhrman Veteran Member • Posts: 3,577
Very nice photos.
clockface Regular Member • Posts: 171
Oooh oooh a RAW vs JPG thread; my favourite. Let's add in a little filter vs no-filter touch and it will be the start of a perfect day.
Anyone detect the sarcasm?
seukel Regular Member • Posts: 496
Oh, no! Not again! How many threads on raw vs jpg have we had?
Peter
Education is an admirable thing, but it is well to remember from time to time that nothing that is worth knowing can be taught.
Oscar Wilde
 seukel's gear list:seukel's gear list
Leica D-Lux (Typ 109)
uniball Senior Member • Posts: 1,617
I use RAW when I need it. Night shooting, high light contrast shots. Otherwise is just about all jpeg.
Fuji is the first camera I've taken this approach with and I find it senseless to simply put the camera in raw only anymore. I use Custon Settings to toggle between what I want to shoot with.
Nice shots.
ScottP123
ScottP123 OP Junior Member • Posts: 27
Good morning!
This is the first thread that I have read on "jpeg vs raw". I'm new to the forum.
Just curious, if you have read so many... why are you reading another one!
Happy shooting!!!
ScottP123
Nice shots.
I can relate to what you say. As a Nikon shooter I shot only in RAW because I didn't want the image processing "baked" into the image file of a jpeg.
Now, shooting a Fuji camera the "in camera" processing is so attractive for everyday snapshots that I don't want to fool with RAW fliles for everyday stuff.
Makes total sense to utilize custom settings to toggle back and forth as desired.
Thanks for the comment.
Happy shooting!!!
SaltLakeGuy
SaltLakeGuy Forum Pro • Posts: 11,441
Knowing all too well how shots posted on the internet tend to degrade in the first place, I won't comment too harshly on what I'm seeing. I DO agree the Jpeg performance of the X-T1 is above most all I've used to date and that includes top pro DSLR's. HOWEVER as they say "with that said", in cases where there is considerable dynamci range (light to dark differences such as sunsets) shooting in RAW CAN indeed render at least 2 full stops advantage over Jpeg shots. It's just a electro mechanical reality. In many (dare I say most) instances when properly exposed, a Jpeg shot for all intents and purposes can render a file that when printed will be either indistinguishable to possibly even better (due to the wonderful in camera processing) to a RAW shot. Some of your shots show some very odd intense noise pattern, so I'll just chalk that up to the internet compression issues. What I've said stands. If you are not dealing with a truly demanding scene Jpeg is perfectly fine indeed and certainly does make for an easier work flow. With this camera I'd even say shooting both large Jpegs AND RAW is a possible advantage as you can file the RAW file away and just use the Jpegs for ease of processing. if you run across a difficult scene you can tweak the RAW file more. It's a Win Win scenario for sure.
Fuji X-T1 Camera, Fuji 18-55 f2.8-f4 Lens, Fuji 55-200 f4-f5.6 Lens, Fuji 23mm f1.4 Lens, Fuji 56mm f1.2R Lens, waiting for the Fuji mount Nissin i40 Flash, Picturecode PhotoNinja, Adobe Lightroom 5.4
 SaltLakeGuy's gear list:SaltLakeGuy's gear list
Sony Alpha 7R II Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-200 F4 Zeiss Batis 85mm F1.8 +4 more
ryan2007 Forum Pro • Posts: 12,001
That is what I have said.  With a few exceptions to include time lapse, RAW is not necessary because the JPEGs are that good here with Fuji X.
fluxism Contributing Member • Posts: 512
as long as you don't ever shoot at high iso
 fluxism's gear list:fluxism's gear list
Fujifilm X-Pro1 Fujifilm X-E2 Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +2 more
kwa_photo
kwa_photo Senior Member • Posts: 2,996
I agree, I rarely (if ever) shoot RAW with my X100 or X-E1...I'm careful with my exposure and I keep the in camera NR to -2.  Other than that, I'm thrilled with the JPG's.  I do have a Sony RX10 (something where Fuji just doesn't have a competitor, especially with video) and to get the best IQ I find myself using RAW again. The jpg are fine, but nothing like I get from Fuji jpg, even compared to the ones from my little X10.  Fuji just knows in camera processing VERY well.
Ken
FujiFilm FinePix Moderator (PM with Q's vs. a public post please)
http://www.kwaphoto.com
 kwa_photo's gear list:kwa_photo's gear list
Panasonic Lumix DMC-LX5 Leica D-Lux (Typ 109) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX8 Panasonic 12-35mm F2.8 +6 more
Sal Baker Veteran Member • Posts: 9,455
It depends.  I like to pull the most DR out of the sensor.  8-bit RAWS just can't be pushed as far as 14-bit RAW files.  JPEG is not necessary for me, but I'm glad there's an option for both.
Sal
 Sal Baker's gear list:Sal Baker's gear list
Ricoh GR Canon EOS 5D Mark II Fujifilm X-E2 Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM +7 more
Well Peter, all I did was answer Scott's question as specifically as possible.
I went out of my way to describe the basis for my choice in a non-confrontational, non-judgmental way. I made no attempt to influence or convince others. I did not demean, or defame those who have different priorities.
Scott asked a specific question and I provided a specific answer.
I found your comment to be hypocritical.
spatz New Member • Posts: 19
First of all, these are nice images as they are.
However, if the sunset image had been shot in raw, it would have allowed you to experiment with the shadow areas - I'm not saying that would necessarily result in a better image, but a different one.
Yes, you're getting nice images from Jpg alone, but I see no harm in shooting Raw+Jpg, since disk space (even properly backed up space) really isn't an issue for still images. That way, you can have the quick jpg workflow if you want quick results, but for the few shots where Raw would give you something extra, you retain that option.
Also, with the increased processing speed, it will take absolutely no effort to automatically develop all your old raw images in five years time, with the latest demosaicing and noise reduction algorithms, and color profiles. Not shooting Raw now denies you that possibility.
