How to lower sensitivity of the shutter of the E-M1 during continuous shooting modes?
Started May 13, 2014 | Questions
Rob
Rob Regular Member • Posts: 376
I love how fast the continuous shooting is on the E-M1, but it's extremely sensitive, so that if I'm not 100% careful on the amount of pressure I use when pressing on the shutter, it will go off when I only want a single shot. I know I can set the shooting mode to just single shot, but I'm used to the way I shoot with Canon bodies, where the continuous shooting doesn't engage unless I press the shutter a bit harder than normal, so I can choose to do single or multiple shots just by controlling the pressure with my finger.
The E-M1 allows this too, but the shutter sensitivity for activating the continuous shooting is way too sensitive, and I'd like to lower it a bit so I'm not accidentally triggering it all the time, nor do I have to always go into the settings to change it from single shot to continuous shooting.
Rob
Art, music, photography, writings, and blog:
www.ethereality.info
 Rob's gear list:Rob's gear list
Olympus E-M1 Sony Alpha 7R II Sony FE 55mm F1.8 Panasonic Leica D Summilux Asph 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +7 more
Olympus E-M1
Bob657 Senior Member • Posts: 1,999
Re: How to lower sensitivity of the shutter of the E-M1 during continuous shooting modes?
As far as I know, there is no setting for that, but I can tell you virtually everyone adjusts to the more sensitive shutter button.  The upside of this is you have less movement of the camera when pressing the button, meaning more in focus shots.
Bob G
 Bob657's gear list:Bob657's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Panasonic Lumix G X Vario 35-100mm F2.8 OIS Olympus 12-40mm F2.8 +2 more
Martin.au
Martin.au Forum Pro • Posts: 10,318
Just practice. It gets easier. At 4fps single shots are easy.  At 6.5fps it is harder but still manageable.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +6 more
Geo Wharton Senior Member • Posts: 1,054
At the 10 fps setting, I can never get less than three frames on on very quick trigger squeeze.  When I set it at 6.5 fps, I can easily get just one.
 Geo Wharton's gear list:Geo Wharton's gear list
Olympus Tough TG-4 Olympus PEN E-PM1 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +27 more
Rob
Rob OP Regular Member • Posts: 376
Thanks for the replies!
Looks like I'll have to either set it to lower fps, or develop a more gentle touch.
Rob
TheSquid Regular Member • Posts: 238
I know on my E30 if I set it to high I'll end up occasionally having multiple frames but if I set it to low I only have extra frames when I mean to.
Then again, I gew up using a motor drive and setting it to single so I don't do burst very often.  Growing up with film and 36 shots gives a different set of shooting circumstances than with digital's almost unlimited shots.
Skeeterbytes Veteran Member • Posts: 9,656
Rob
It's at least in part a tactile, kinesthetic task--learning the right amount of pressure to apply--and every camera is unique. Another possibility is the shutter action changing as it breaks in. Mine's still pretty new but I know it's at least possible to squeeze a single shot, if not exactly easy. I had a terrible time with my E-5 at first, the shutter was squishy and indistinct, but its action is much better than when it first emerged from the box and I'm pretty immune to unwanted shots.
The other possibility is trying the grip. Got mine only recently, but it's clear the button action is rather different from the camera's.
Rick
"Whiskey is for drinking, digicams are for fighting over."
—Mark Twain
kbouk Regular Member • Posts: 144
check the Custom "C" menu , there is a function called "Release Lag-Time" if [Short] is selected the shutter button is more sensitive.
My 4/3 System : Olympus E-1,E-5, Leica DigiLux 3, EC-2.0X, EC-1.4X, DZ 14-35mm/2, DZ 50-200mm/2.8-3.5 SWD, DZ 25mm/2.8, DZ 50mm/2.0 macro, Samyang 85mm/1.4, DZ SWD 150mm/2.0, Lensbaby 3G, Flash FL50R, MacroFlash STF-22.
My OM system: Olympus OM-2N, OM-4 .
My m4/3 system: Olympus E-M1,E-M10, Panasonic G3, Lumix 7-14mm/4.0, Lumix 12-32mm/3.5-5.6, Lumix 35-100mm/2.8, PLeica 25mm/1.4, mzD 12-40mm/2.8, mZD 60mm/2.8 macro, Sanyang 7.5mm/3.5, Flash FL-20, FL-600R.
 kbouk's gear list:kbouk's gear list
Leica Digilux 3 Olympus E-1 Olympus E-5 Olympus E-M1 Panasonic Lumix DMC-GM1 +17 more
That does help.  I can squeeze off one or two, but not consistently one.
