Leica 15mm
Started May 13, 2014 | Discussions
dv312
dv312 Veteran Member • Posts: 3,267
Leica 15mm
the perfect mate to the GM1
http://www.popco.net/zboard/view.php?id=dica_review&no=932
At least enjoy the photos
Cheers
 dv312's gear list:dv312's gear list
Olympus PEN E-P5 Olympus E-M5 II Olympus PEN-F Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital 45mm F1.8 +9 more
Panasonic Lumix DMC-GM1
C Sean Contributing Member • Posts: 795
Re: Leica 15mm
Looking good.
i don't know if I should cancel my order and get a silver 15mm instead of the black one?
sigala1 Senior Member • Posts: 3,634
Re: Leica 15mm
Cheers
The lens hood is really cute.
The aperture ring is an annoying gimmick. Why not a generic ring that you can set to anything from the camera, so it can be sued for ISO, shutter speed, or whatever you want?
photofan1986 Senior Member • Posts: 2,793
Re: Leica 15mm
Yep, Samsung does that, it would be a neat idea. But as I'm a  AV shooter, I don't really mind.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Canon PowerShot S100 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +7 more
Pic Man Senior Member • Posts: 1,308
Re: Leica 15mm
Cheers
I think it will prove useful on the GM1 because it doesn't have too many external controls. I don't see how it can be annoying. It's better than not having one.
Re: Leica 15mm
The lens is smaller than I'd thought it would be. It looked a fair bit shorter than the oly 12mm and that's a pretty small lens.
uberzone
uberzone Regular Member • Posts: 278
Re: Leica 15mm
I'm quite sure I will buy this and sell off my 14mm and 20mm. I never really warmed up to the 14mm and the 20mm doesn't get much use anymore now that I have the Panasonic 25mm. I think this 15mm lens will be the perfect complement.
Does anyone know if the hood is reversible? Everything I've heard says yes, but I have never seen a picture of it reversed.
 uberzone's gear list:uberzone's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Sony Alpha 7R Panasonic Lumix DMC-GM5 Panasonic Lumix G Vario 7-14mm F4 ASPH +16 more
EGenius007
EGenius007 Regular Member • Posts: 141
Re: Leica 15mm
Photos enjoyed, agree about it being perfect for the GM1. The dedicated cap for fitting with the lens hood is nice, though a little surprised about both caps being badged "Lumix G" instead of Leica. Curious if anyone scrounges up photos of the black 15mm on the silver E-M10.
Believe The Pictures
 EGenius007's gear list:EGenius007's gear list
Olympus OM-D E-M10 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +5 more
rurikw Regular Member • Posts: 481
Re: Leica 15mm
Ouch, I got GAS!
 rurikw's gear list:rurikw's gear list
Nikon Coolpix 5000 Sony Cyber-shot DSC-R1 Sigma DP3 Merrill Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +23 more
tt321 Senior Member • Posts: 7,207
Re: Leica 15mm
Cheers
Even on the GM1, a general control ring with a wide choice of use would still be better.
ericN2
ericN2 Forum Pro • Posts: 16,512
Re: Leica 15mm
No thanks ... at least whilst in UK it's 200 GBP MORE than my lovely Oly 17mm f1.8 from which I just can't believe I can get better results generally..
/eric
Staffordshire, UK
Len_Gee
Len_Gee Veteran Member • Posts: 8,916
Re: Leica 15mm
C Sean wrote:
Looking good.
I showed my girlfriend.
She said that " once you've had black you never go back."
So black it will be for my black GX7.
 Len_Gee's gear list:Len_Gee's gear list
Fujifilm X100T Panasonic Lumix DMC-GX7 Olympus PEN-F Panasonic Leica Summilux DG 25mm F1.4 Panasonic 20mm F1.7 II
bahamot
bahamot Contributing Member • Posts: 533
Re: Leica 15mm
Both PL25/f1.4 and PL 45/f2.8 have "Lumix" written on the lens caps.
 bahamot's gear list:bahamot's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +6 more
Impulses Senior Member • Posts: 4,043
Re: Leica 15mm
Panasonic isn't very consistent with anything, some of their caps say Lumix G ands others just Lumix, and the X series say Lumix X... They've got a bunch of different cap designs too, my 20mm had a slim domed one, the 12-32 had a slim flat one more reminiscent from Oly's, the kit zooms come with the center pinch cap, etc etc. The cap on my 20mm was pretty fiddly, the teeth were ever so slightly more shallow and it was always jumping threads, replaced it with an Olympus cap.
 Impulses's gear list:Impulses's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic 20mm F1.7 II Panasonic Lumix G 42.5mm F1.7 +26 more
Sergey Borachev Senior Member • Posts: 3,303
Re: Leica 15mm
Cheers
Perfect mate, and obviously designed to be small enough to look good on the GM1, and in particular to have a small enough diameter so as not to lift up the camera when mounted. However, that also means some compromise and I just can't help but wonder how much better it could have been if it was not designed to be so small and to fit the GM1 well.
arbuz Senior Member • Posts: 2,247
Re: Leica 15mm
tt321 wrote:
Cheers
It may be better but having one just for aperture cannot be called annoying.
 arbuz's gear list:arbuz's gear list
Nikon D600 Samsung NX300 Panasonic Lumix DMC-G6 Samsung NX30 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +14 more
