Going to give another a6000 a try
Started May 13, 2014 | Discussions
NeilJones
Veteran MemberPosts: 5,392Gear list
May 13, 2014
I decided to purchase the a6000 kit this time and see if it performs better than the one I sent back because I was very disappointed with the tracking af.
Still also have the zeiss 24mm to try on it.
Wish me luck!
" All you need is love"
Advent1sam
Senior MemberPosts: 2,474
Re: Going to give another a6000 a try
In reply to NeilJones, May 13, 2014
Wish me luck!
Neil,
I think you'll need something better than the 16-50 to realise the better tracking, the 24mm is a bit wide too but will probably work fine. I think the 16-70 is probably the best compact fast option zoom currently and the 50 1.8 should provide comparable results to the 55 1.8. I am ordering mine this week and have pretty much decided on the 16-70 initially and the 35/50 1.8 primes and the 55-210.
Ynos
Regular MemberPosts: 182
Wish me luck!
IMHO (and this all is just my assumptions based on all info I acquired so far). Ironically tracking AF in A6000 IMHO will work best if you will not let the camera decide where to focus or track, but instead keep central focus on object yourself. It basically defeats the purpose of tracking by some margin, but it gets the job done. Basically tracking in this case would be just aiming at target to keep focus on it and panning the camera along. Actually it is most natural way to do tracking - kinda like video shooting. So ironically, despite all this talk about finding better settings (settings are still important of course) and knowing your camera, it turns out that best approach is to treat A6000 like a handycam, rather than just keep object in frame and allow A6k to decide where in the frame it wants to put focus. It is in essence making a camera do just usual AF-S focusing (which it does quickly) and doing tracking yourself - silly and simple, but if it gets better keeper rates, why not? I'm going to try exactly that and will report back my findings soon. (ordered A6k).
Good Luck to you too.
P.S. If my findings turn out true - than Kudos to Sony for making a best family camera (kinda opposite of what some users are saying here). IMHO I still think it is a moms and dads kinda camera, it has iAuto and iAuto+ and possibly it is the best way to track and shoot. Maybe it was initial intention of Sony to make most of work done by camera, with leaving control for user to do the aiming, panning etc. What I mean (and don't get me wrong, it's good to have RAW options and PASM modes and all controls) is that some users here make simple things too complicated by messing the settings and trying for camera to do tracking by itself. Many reviews get dissapointing results just because of that. Anyway, we'll see.
123Mike
Senior MemberPosts: 4,643
I'm starting to get used to things now myself. I came from the A57 so things were a little more simplistic on that.
But now, I'm using three different combinations of modes:
1) Simple static type shots: AF-S, flexible point (centered). Center subject, focus, recompose, shoot.
2) Moving objects on the ground (eg. kids playing): AF-C. Lock on focus start with shutter. Center subject, focus, recompose, shoot.
a) center or flexible spot (center)
b) zone focus, center region (which is really everywhere except with a strip taken off the sides).
3) Fast moving subject away from other subject, eg. bird in the sky. AF-C. Wide area focus. Just burst the crap out of it. Nearest found anything is in focus.
You can use (3) for things in the ground too, but then pick zone, and move the area of whatever-blocks it shows, up a bit, to avoid it seeing ground.
I which I could preset this in programmable modes. Then with a single click I could cycle to my next mode. Does the A6000 have this that I don't yet know about?
creaDVty
Senior MemberPosts: 1,168Gear list
In reply to 123Mike, May 13, 2014
Sorry for the potentially dumb question but what about the MR mode?  Takes a couple of button presses but would that work?
www.BetterFamilyPhotos.com
TTL Flash Tutorial and over 400+ other articles for taking better candid and family photos.
http://betterfamilyphotos.blogspot.com/p/better-family-photos-index.html
 creaDVty's gear list:creaDVty's gear list
Panasonic Lumix DMC-LX5 Fujifilm FinePix F31fd Fujifilm FinePix Real 3D W3 Olympus Stylus 1 Olympus Tough TG-3 +22 more
123Mike
In reply to creaDVty, May 14, 2014
What's MR mode?
Eduard E
Regular MemberPosts: 107Gear list
In reply to NeilJones, May 14, 2014
Did you update the firmware of your lenses?
 Eduard E's gear list:Eduard E's gear list
Sony a6000 Sony Alpha NEX-3 Sony E 16mm F2.8 Pancake Sony E 16-50mm F3.5-5.6 PZ OSS Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA +7 more
Walie
Contributing MemberPosts: 557Gear list
In reply to 123Mike, May 14, 2014
What's MR mode?
Have a look on the mode dial...
 Walie's gear list:Walie's gear list
Sony a6000 Fujifilm X-T1 Sony E 35mm F1.8 OSS Fujifilm XF 35mm F2 R WR
123Mike
In reply to Walie, May 14, 2014
Walie wrote:
What's MR mode?
I don't get it.
cSimon
New MemberPosts: 2
123Mike wrote:
Walie wrote:
What's MR mode?
I don't get it.
I think MR is the Memory Recall mode which can be selected with the mode dial. It's possible to program three custom-settings under MR and they can be recalled fairly fast any time you need one of them (don't own a A6000 yet, so I don't know the details).
Helen
Veteran MemberPosts: 3,976Gear list
Walie wrote:
What's MR mode?
I don't get it.
Memory recall mode. You can have several different setups of your choice saved there.
123Mike
Thanks!
In reply to cSimon, May 14, 2014
Awesome !
123Mike
Thanks !
In reply to Helen, May 14, 2014
Awesome !
zackiedawg
Forum ProPosts: 24,736Gear list
In reply to Ynos, May 14, 2014
Unfortunately, through all the threads on the topic, you've come away with some wrong information.  Tracking AF does NOT work best by using central focus and trying to keep it on the target.  I have not yet shot a single moving subject using this technique.  Tracking a moving subject is best done using the camera's continuous focus abilities by choosing the best focus area or lock-on AF capability for the given situation.
Bird in sky flying around - AF-C, wide area focus.
Bird flying against busy background - AF-C and wide focus
Bird flying and there are any things in the foreground - AF-C, lock-on AF, spot or center focus area, acquire bird through lock-on AF, it will then track anywhere in the frame.
Bird sitting but anticipating it will fly soon - AF-C, lock-on AF, lock on the target with medium spot focus, it will track when the bird moves.
Same for sports, dogs, people, etc.  Just about the ONLY motion situation where a central focus spot and AF-C would be best would be for a non-erratic subject moving directly towards you - a car, bike, or person running who is coming in a straight line and would be easy to keep the center point on.  Otherwise, using different focus areas for different subjects will yield the best results, and knowing when lock-on AF might be advantageous.
Of course, the ability to keep the moving target within the frame is key - so learning good panning technique will help greatly.
Hope that helps when you get your camera.  Just practice with the different modes.
Justin
galleries: www.pbase.com/zackiedawg
 zackiedawg's gear list:zackiedawg's gear list
Sony Alpha DSLR-A580 Sony Alpha NEX-5N Sony a6000 Sony DT 18-250mm F3.5-6.3 Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) +25 more
wb2trf
Senior MemberPosts: 1,967
Thanks, zackiedawg,
In reply to zackiedawg, May 14, 2014
Thanks, zackiedawg,
Your diligent posting in the forum on this topic has been very helpful.
Marti58
Marti58 MOD
Forum ProPosts: 19,744Gear list
Hi Justin thanks
for the constructive and helpfull information.
rgds Marti
*All my Post Processing is done with Capture NX2*
Flickr Photo's
Galleries on DPR
 Marti58's gear list:Marti58's gear list
Nikon 1 Nikkor 10mm f/2.8 Olympus M.Zuiko Digital 45mm F1.8 Samsung HZ35W Nikon Coolpix P500 Canon PowerShot S95 +33 more
José B
Forum ProPosts: 18,319Gear list
Wish me luck!
You still have the Sonnar 55? It's awesome with A6000 !
 José B's gear list:José B's gear list
Sony Alpha NEX-6 Canon EOS 5D Mark II Canon EOS-1D Mark III Sony a6000 Canon EOS 5DS +11 more
