Testing the tracking with the A6000 and 16-70
Started May 11, 2014 | Discussions
LSF Contributing Member • Posts: 573
6
figured I would try the tracking capabilities for my dogs today, have to say pretty pleased.  I used S mode-1/500, AFC and zone focusing.  Still need to work a bit on my technique but the capability is there with the camera at least
focus was on the dog with the ball
Cheers, Lisa
 LSF's gear list:LSF's gear list
Sony Cyber-shot DSC-RX10 III
Sony a6000
PVCdroid
PVCdroid Senior Member • Posts: 3,812
Re: Testing the tracking with the A6000 and 16-70
Nice. The dogs look like they are having a blast and focus looks good to me.
 PVCdroid's gear list:PVCdroid's gear list
Sony Alpha NEX-5N Sony Alpha NEX-7 Sony Alpha 7R Sony Alpha 7R II
José B
José B Forum Pro • Posts: 18,324
Cheers, Lisa
Excellent Lisa! Thanks for sharing your settings and images-----looks like your dogs had a lot of fun!
cheers,
José
 José B's gear list:José B's gear list
Canon EOS-1D Mark III Canon EOS 5D Mark II Sony Alpha NEX-6 Sony a6000 Canon EOS 5DS +11 more
miro3 Senior Member • Posts: 2,396
How did you keep the focus on the dog with the ball?
LSF OP Contributing Member • Posts: 573
I was a good distance away so I aimed at her and focus locked on her and with AFC it followed her..these were cropped as well to highlight the subject and tracking
Thanks everyone else luckily yes they have fun when I am using them for crash test doggies LOL.  I did find that as alot of user have reported the 16-70 really is not that much better than the kit lens, it just does not have the same wow factor sharpness and contrast so it is going back.
Cheers, Lisa
40daystogo Regular Member • Posts: 266
How do you lock the focus on a subject? I was playing with the A6000 in a store, and during AF-C there is no central spot appearing on the screen, so I'm not sure how you indicate to the camera that is the intended main subject? Sure, with one subject there's no issue, but when there are multiple subjects even initially close together - as the dogs were at the start - just how do you indicate to the A6000 what is the main subject?
I focused on her before they all started running and the camera kept the focus on her, except when they are all in the same focus plane then they too were in focus
Cheers, Lisa
dquangt Senior Member • Posts: 1,688
There are multiple settings you can set for the focus field. The default I believe is wide which doesn't show a focus box. Personally I usually use flexible spot, medium.
Timbukto Senior Member • Posts: 4,618
2nd shot is out of focus.
One thing you should really try to take advantage of mirrorless is to shoot extremely low, place the camera low and tilt the LCD up, etc. It will make it so the contrasty grass does not confuse the camera *and* likely make your shots far more interesting as a picture full of contrasty grass is pretty boring too.
This is an advantage you don't get with DSLR unless you lay prone in the grass btw.
 Timbukto's gear list:Timbukto's gear list
Canon EOS M Canon EF 200mm f/2.8L II USM Canon EF-M 22mm f/2 STM
thanks for the tips I will try that!
Cheers, Lisa
jpr2 Forum Pro • Posts: 14,710
re: plenty of DSLRs have fully articulated LCDs now
plenty of DSLRs have fully articulated LCDs now - no need to be so overtly biased !!
jpr2
Foroa Regular Member • Posts: 183
Maybe Sony should sell tracking Sony badges, necklaces and caps, and add a special tracking mode that allows to recognize them.
 Foroa's gear list:Foroa's gear list
Sony a6000 Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS
Re: re: plenty of DSLRs have fully articulated LCDs now
jpr2
Only the Sony DSLT's will perform PDAF well in this situation and maybe the 70D *might* get a sharp shot or two.  The rest you need to lay prone and keep your eyes on the viewfinder to utilize PDAF.
LeicaBOSS
LeicaBOSS Regular Member • Posts: 432
I'm sorry. I have a Boston. I just cannot look at these without laughing.
From time to time, I point my camera at the right things. This is generally when I forget everything I've learned.
 LeicaBOSS's gear list:LeicaBOSS's gear list
Leica M9 Sony SLT-A77 Canon EOS M Sony Alpha 7R Canon EF 50mm f/1.8 II +17 more
EinsteinsGhost
Loom for Lock On setting, assign to a button and when you have the subject in focus, using lock on will try to maintain focus on that subject.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
EinsteinsGhost
jpr2
And they will take an eternity to acquire focus in that mode, much less track... only SLTs can. This is a fact, not a biased opinion.
EinsteinsGhost
When I saw tracking in the subject line and then the first image, the first thing that came to my mind with three of them in the frame: now that is a stress test.
Cute little fellas.
