D600 questions
Started May 11, 2014 | Discussions
nobori New Member • Posts: 7
D600 questions
Hi,
I purchased a D600 bundle from craigslist. An upgrade from my D5100 and I have few questions I would like to ask.
1. the shutter count has only 600 when I got it and given that he told me it was sent to Nikon (camera is one yr old) I have to assume it was replaced due to oil & dust. However when test out for oil & dust today, I already notice a spot (currectly @1000 shutter count). Is it normal? should I be worried?
2. thru the eyepiece, I can see a small "dirt" or "line" even without the lens on. Not sure how to describe it but my guess is on the sensor or mirror, although it doesn't show up on picture, I'm just wondering how I can clean that off.
3. any good suggestion for an eye piece for someone with glasses? I feel it this one leave some mark on my glasses, wasn't as noticeable with my d5100.
thanks.
img of oil/dust
Nikon D5100 Nikon D600
The Incredible Hoke
The Incredible Hoke Contributing Member • Posts: 894
Re: D600 questions
I don't want to dismiss your concerns, but if it doesn't show up on the picture, why worry about it?
lickity split
lickity split Senior Member • Posts: 2,637
Re: D600 questions
nobori wrote:
Hi,
thanks.
img of oil/dust
You might have a speck in the viewfinder,I wouldn't be to concerned about it . As far as eyepieces I went with this Nikon #2925,2362,2370 It's soft and folds flat to the body when not in use...
 lickity split's gear list:lickity split's gear list
Nikon D810 Nikon D500 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 600mm f/4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +10 more
clarnibass Senior Member • Posts: 1,904
Re: D600 questions
I wouldn't worry about one spot at f/16 after 400 photos. You can also ask the seller if the camera had the Nikon D600 recall/warranty repair. If not you can always do that. If it did and you find a problem, you can tell them again and hopefully they will do something about it. You can tell them about the viewfinder line too if you do.
I also wear glasses and can't really help, except adding that I've tried Nikon's viewfinder magnifier and it was worse, so I wouldn't get that.
nobori OP New Member • Posts: 7
Re: D600 questions
thank you everyone for your input.
