Thinking about an SB-400. Thoughts?
Started May 11, 2014 | Discussions
InTheMist
InTheMist Senior Member • Posts: 3,066
Hi everyone,
I'm thinking about getting an SB-400 to throw in my bag for use as a popup-replacement or hair/rim light (with a PocketWizard).
Opinions?
It has to be small as I've become a weight weenie, and anyway, I already have two SB-700s and a SB-900.
I didn't like the SB-300 because it uses AAA batteries and I'm already heavily invested in AA rechargeables.
It's more important how an image looks as a thumbnail than how it looks at 100%.
http://inthemistphoto.com
 InTheMist's gear list:InTheMist's gear list
Leica M Monochrom (Typ 246) Leica M-Monochrom Nikon 1 AW1 Nikon Df Nikon D810 +18 more
Daniel4
Daniel4 Regular Member • Posts: 421
Re: Thinking about an SB-400. Thoughts?
I found my D800 popup flash surprisingly powerful for direct (not bounce) flash, so I skipped the SB-400 and got the SB-700 instead which is great for bouncing (but you already know that).
 Daniel4's gear list:Daniel4's gear list
Nikon D800 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +2 more
romfordbluenose
romfordbluenose Senior Member • Posts: 1,984
Increase your ISO and the popup is very powerful
 romfordbluenose's gear list:romfordbluenose's gear list
Nikon D800 Nikon D5300 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +8 more
Chuck Yadmark
Chuck Yadmark Veteran Member • Posts: 3,564
Can't find  a new one now and even if you could I'd still probably get this one:
http://www.bhphotovideo.com/c/product/603411-REG/Sunpak_RD2000N_RD2000_Digital_TTL_Low_Profile.htm
which is a bit more compact.
www.sportsshooter.com/cyadmark
Ann Arbor, MI USA
Equipment in profile
 Chuck Yadmark's gear list:Chuck Yadmark's gear list
Nikon D3S Nikon D7200 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 600mm f/4D ED-IF II Nikkor AF-S 300mm f/4E PF ED VR +17 more
paulski66
paulski66 Senior Member • Posts: 2,736
I had an sb-400 back in my d90 days. Honestly, I found it really not that worth it. If you could use it as a commander, then yes, maybe, but otherwise it's just too limited.
 paulski66's gear list:paulski66's gear list
Panasonic Lumix DMC-LX5 Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +2 more
InTheMist
InTheMist OP Senior Member • Posts: 3,066
That's pretty interesting. Thanks!
Yeah, that's true, but not all my cameras have popups.
paulski66
D'oh! Of course.
In that case, the d400 makes more sense. Sorry, I hadn't considered this.
Stacey_K
Stacey_K Veteran Member • Posts: 7,766
InTheMist wrote:
Hi everyone,
Opinions?
People ditz this flash but I find it useful. The light quality is much nicer than the popup, especially when you clip a 3rd party diffuser on it. Plus it recyles pretty quick and doesn't drain the camera batter. And it can be tilted up to bounce off a ceiling. I also have a couple of SB700's but this little guy always gets thrown in the bag. I do wish it would work off camera by itself but...
Stacey
 Stacey_K's gear list:Stacey_K's gear list
Nikon D200 Nikon D700 Nikon D7000 Nikon D800 Sony Alpha 7 +14 more
chuhsi
chuhsi Contributing Member • Posts: 958
It's fine for a small lightweight flash with no frills. Get a diffuser for it.
Only real issue is finding one for a decent price. They've increased in price since being discontinued for inferior sb-300.
I ended up buying the 300 because I couldn't get myself to pay so much money for a 400 (I sold my first 400 a couple years ago)
 chuhsi's gear list:chuhsi's gear list
Nikon D3S Nikon Df Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 24-120mm f/4G ED VR +6 more
lickity split
lickity split Senior Member • Posts: 2,481
Ann Arbor, MI USA
Amazon has them,but the price went up since being discontinued..
http://www.amazon.com/Nikon-SB-400-Speedlight-Digital-Cameras/dp/B000KKPN5C
 lickity split's gear list:lickity split's gear list
Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 300mm f/2.8G ED VR II Nikon AF Micro-Nikkor 200mm f/4D ED-IF +7 more
David314
David314 Veteran Member • Posts: 4,790
Solid flash
InTheMist wrote:
Hi everyone,
Opinions?
I think it is a solid flash  and actually puts out a fair amount of light
it does work with the pocket wizard. Ttl5
that sunpak looks pretty intriguing
Prairie Pal
Prairie Pal Senior Member • Posts: 2,460
You mention pocketwizard so I'm assuming you mean off camera and in manual mode?
I had an SB400 only briefly but if I remember correctly there are no controls on the flash. It's meant to be used on the hot shoe and controlled by the camera.
Seeing that you will be using it in manual mode (I'm assuming), there are a tons of used flashes to be had, small one with low profiles, and most with some degree of output control. You could probably buy 20 or more of these pre-digital flashes for what an sb400 costs.  I think the sunpack has the same limitations as the sb400.
Ivan
David314
Pocket wizard ttl
Ivan
With the new pocket wizard ttl controls, like the ttl5 you can use the sb400 and remotely set the power manually or  use ttl
in that regard it is a pretty awesome flash
there is no way to remotely trigger the sb400 from a dumb trigger
it has to communicate with what it thinks is a camera
Shotcents
Shotcents Senior Member • Posts: 4,472
InTheMist wrote:
Hi everyone,
Opinions?
If you already have a big flash or two, the Sb400 is absolutely wonderful and this is one of those occasions where Ken Rockwell is correct.
Flip the little head up and you get a very nice soft bounce flash, especially if you order the little plastic diffuser with it. When I pack a small bag with my Df or Coolpix P7700, this little flash does so much better than the direct flash that is built in to some of my other camera bodies. If I strip down my D800 (grip off and small prime) the SB400 does a nice enough job, though it's not nearly as versatile as the full size flashes. You're not going to get the type of power of a full sized flash, so don't expect miracles. If you're trying to light up a big scene you'll need to crank the ISO more than with an SB800 or 910.
I bought mine at the last minute for 110.00 bucks. I would not have it as my only flash, but it's nice to have for certain situations and not the heavy counterweight that my big guns are.
I also tried the Sb300 recently and it's really about the same, a bit less powerful, but the head tilts better. The Sb300 also uses AAA batteries instead of AA like the SB400....not a big deal unless you have OCD with battery matching.
Robert
 Shotcents's gear list:Shotcents's gear list
Nikon Coolpix P7700 Nikon D800 Nikon D5200 Nikon D5300 Nikon Df +11 more
bocajrs
bocajrs Senior Member • Posts: 1,555
Ditto... The SB-700 is a very nice flash
 bocajrs's gear list:bocajrs's gear list
Nikon 1 J4 Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Teleconverter TC-20E III Nikon AF-S Nikkor 24-120mm f/4G ED VR +2 more
seahawk
seahawk Senior Member • Posts: 2,619
I love this tiny flash. Batteries last forever, it puts out quite some light, it can bounce, it is fully camera controlled, with a softbox it works very well. And it is small and weights nothing.
I use it more often than my bigger Metz SB700 alternative.
hobby aviation photographer
Paul P K
Paul P K Regular Member • Posts: 407
Highly recommended
Small, quite powerfull and works like a charm with the TT5, and with a AC-3 or SU800 will have its power reduced similar to eg the SB800 and SB910 (was a surprise for me when I found that one one, since it standard has no CLS functions)
I also always have it with me together with the DF, nice small volume package which still allows plenty of possibilties
all in a day's work
http://www.pbase.com/paul_k/
 Paul P K's gear list:Paul P K's gear list
Nikon D70s Nikon D1H +12 more
Chas J
Chas J Regular Member • Posts: 415
I have the SB - 400 and SB-800 and other large flashes.   It is the 400 that I use the most.
A trick I use much of the time is to tilt the flash head upwards and then insert a business card in the slot that opens up behind the rotated head (if you look at one - you will see what I mean).  This not only gives bounce flash but soft fill flash at the same time ... and it costs nothing !.
Great flash that always gets thrown in my bag when I am using my Nikon kit.
Chas.
Doha, Qatar.
Do Not Listen to What I Say ... Listen to What I Mean !.
 Chas J's gear list:Chas J's gear list
Nikon D3200 Nikon D610 Canon PowerShot S95 Nikon D70s Olympus PEN E-P2 +19 more
tommiejeep
tommiejeep Veteran Member • Posts: 4,458
I love it on the Df for fill but I am seriously looking at the Nissin i40 which is even smaller and more functional (Focus Assist for one )
this was a quick snap at a recent Charity function with the SB400 and 85 1.4D
Anticipate the Light and wing it when you get it wrong
Tom
http://taja.smugmug.com/
Chas J
Great Shot.
Doha, Qatar.
