NP-FW50 Weight - varies
Started May 11, 2014 | Discussions
Jawed Regular Member • Posts: 120
Recently I bought an a6000, which came with an NP-FW50 battery. Separately I bought two NP-FW50 batteries:
http://www.amazon.co.uk/gp/product/B003NJVY14
I noticed that the battery that came with the camera is lighter than the two batteries I bought from Amazon (each of which came in what appears to be authentic Sony packaging which is extremely annoying to open).
Sony batteries are often "fakes" and one factor that people report is that the fake is lighter than the battery that came with the camera.
Well, in this case, it's the other way around:
  • battery that came with a6000 = 42g
  • batteries ordered from Amazon = 57g
The two spare batteries that I bought have a "light grey" InfoLITHIUM logo on the side. The battery that came with the camera has a "shiny embossed" logo instead.
The battery that came with a friend's NEX-6 (bought shortly after it launched) has the same style of "light grey" logo. It weighs 58g.
I have no idea if there's a difference in performance between these batteries. I don't intend to find out, either.
a6000
a6000
Spare
Spare
NEX-6
NEX-6
 Jawed's gear list:Jawed's gear list
Sony a6000
Sony a6000 Sony Alpha NEX-6
seachicken2000
seachicken2000 Veteran Member • Posts: 3,164
Re: NP-FW50 Weight - varies
Hi, I reckon weight is a good way to tell. The life of the battery is likely to be less than the real Sony battery (around 60% or so), and there may be compatibility issues between it and current/future bodies.
Some of the fakes come in very convincing "Sony" packaging, including an instruction leaflet. I got sold one of these, and was able to tell by the weight and battery life that the battery wasn't right. The seller refunded the money without a quibble when this was pointed out.
My guess is that the 42g battery is most likely a fake. The other 2 are I guess OK.
A rose by any other name is still a chicken.
http://500px.com/seachicken
 seachicken2000's gear list:seachicken2000's gear list
Sony Cyber-shot DSC-R1 Sony Alpha NEX-5 Sony Alpha NEX-7 Fujifilm FinePix S2 Pro Sony Alpha 7R +21 more
Ynos Regular Member • Posts: 182
I have 5 batteries (1 from 5N, 1 from 5R and 3 from Wasabi form amazon). Sony batteries are a bit heavier. However, from my experience difference in operation is not noticeable. All batteries last same amount of time. Maybe there are some fake ones that are really bad. I haven't encountered them luckily.
bugeyed
bugeyed Senior Member • Posts: 1,336
I just think that things should work the way I expect them to.
spacemn Senior Member • Posts: 1,566
Don't worry, the embossed look shows it is the new FW50 battery from Sony.
Watch this video from 4:10. Same battery as yours. As long as the rating is 1080mAh then you're fine:
https://www.youtube.com/watch?v=SZB4ARYCOl0
Perhaps they have optimized the Li material so that not as much is needed or they save the weight by making the plastic thinner, or who knows. Good thing if it's still 1080mAh as you save a bit more weight while capacity remains and on top of that the camera is probably even more efficient than the NEX-6
EDIT: I can see from your pictures that the rating has gone from 1080 to 1020 mAh. No big deal I suppose, but I definitely don't think it is fake. If someone would make a fake than they would go with the light grey marking as that one is how the FW50 has always looked.
Jawed OP Regular Member • Posts: 120
The battery that came with the camera is a fake, you reckon?
Sony a6000
I definitely don't think so. as you can see from your own pictures the rating has gone from 1080 to 1020 mAh, thus the slightly lighter weight and also watch the video (from 4:10) I linked in the post above.
seachicken2000
Hmmm, in the light of all the new evidence, nope I reckon not, and especially if you bought the camera new. Looks like the 57g batteries are the older models.
If you look carefully you will see that the older style batteries both have two capacity ratings on them: "typical" and "minimum", being 7.7Wh and 7.3Wh, corresponding with 1080 and 1020mAh.
The new battery merely has the minimum rating shown.
So the older batteries might be heavier for the reason you stated.
Sony a6000
eriknphoto Regular Member • Posts: 110
I have noticed the exact same thing. I bought everything from Sony Store online though, so I'm pretty sure they're genuine.
forpetessake
forpetessake Senior Member • Posts: 4,795
It's practically impossible to distinguish real batteries visually taking into account several styles of batteries Sony used themselves. The only way of knowing for sure is to open them up and examine the content. Counterfeiters know very well the difference in weight, so they learned to add some metal stuff inside. The other thing you can do is to run a battery capacity test.
Son Of Mustang Ford Contributing Member • Posts: 577
No, they really don't. The original (Sony) battery that was supplied with my Nex-3 is still able to hold enough charge to take about 100 pictures. The next summer I bought a cheap (ebay) spare - it was fine for about a year but nowadays holds it's charge for about 10 (yes, ten) pictures if I am lucky. The following summer I bought a more expensive copy on Amazon (it had a German name), this one was 'good' for longer, but now I am lucky if I get 30 shots out of it.
ZTJ Regular Member • Posts: 271
What in the world are you doing to abuse these batteries buddy? I have a NP-FW50 I have had since NEX launched, used across nearly every model released, probably 50,000 exposures on it, and I still get a couple hundred before it dies.
Lithium Ion batteries require specific treatment to remain in top condition over time, perhaps you're doing... the opposite of that special treatment?
Whatever the case, it seems strange to me based on my own experiences.
 ZTJ's gear list:ZTJ's gear list
Sony Cyber-shot DSC-RX100 IV Fujifilm X-T10 Fujifilm XF 14mm F2.8 R Fujifilm XF 18mm F2 R Fujifilm XF 23mm F1.4 R +5 more
Well, I was specifically talking about my batteries Wasabi vs Sony - those last about same. Should have been more specific. As for ebay cheap batteries I agree there are some really bad ones.
PVCdroid
PVCdroid Senior Member • Posts: 3,635
My two Wasabi batteries don't hold a charge like my original Sony batteries and a few other Power 2000 batteries I bought. I was surprised because the Wasabi batteries are the third party option usually recommended here. I'll charge them to 100% and a week later they will lose up to 15% without use. One is worse than the other. The the Sony batteries I have that came with my cameras are solid. I hate to hear there may be fake Sony batteries around.
 PVCdroid's gear list:PVCdroid's gear list
Sony Alpha NEX-7 Sony Alpha NEX-5N Sony Alpha 7R Sony Alpha 7R II
BlackBirdSR New Member • Posts: 17
I have noticed the weight difference as well.
My nex5n Battery is heavier than the new one from the alpha 6000. Both are genuine of course. I fully expect sony to have different suppliers (Internal or external) and maybe even different materials and hence internal structure.
Use it -charge it, use it -charge it. The normal thing. The Nex 3 instruction manual has this to say "Battery life is limited. Battery capacity decreases over time and through repeated use". Kid gloves? Again all the Nex manual tells is not to leave the battery in a hot car, and to remove the battery from the charger as soon as it is ready. I was just saying don't expect too much from a budget copy - the Sony still works, the copies - with the same treatment, only newer, are absolutely finished (mind you, if you do the math they are probably still just about worth it).
And one of the supposed advantages (we are told) of Lithium Ion batteries is that they are far more tolerant of 'charging abuse' than some earlier types - none of the part-charge-memory-effect
Oh, and I'm not American, so please don't call me 'buddy' (it just makes me think of Napoleon in 'Bill and Ted')
actually, to be fair 'a couple of hundred' is plenty less than the 330 quoted in the DPR test from 2010 so maybe yours isn't really in much better condition than mine, and doing a count of my last big day out - the (Sony) battery did at least 180 pics. We are not that different.
Cheers
I've heard good things about Wasabi, cost-wise they seem to be between the genuine article and the cheap ebay copies. I don't mind a copy as long as it is 'honest' i.e. doesn't have Sony written all over it - I think if someone is putting their name on it then you stand half a chance of getting something good (hence I was more disappointed with the 'German-named' copy than I was with the really cheap copy)
cheers
I know Mel Snyder has Wasabi and loves it. I had only good experience with them as well. Maybe there are fake Wasabi batteries already?
marc petzold
marc petzold Contributing Member • Posts: 706
It looks clearly to me that your 1st Battery which came with your A6000 is fake - mine looking like your other examples, the Sony ones. Apart from this, i'm using 3rd Party batteries from the brand "PATONA" nearly for all my cameras & DSLR, and i can say that these ones are really great, for half or 1/3 of the original Sony price.
marc
 marc petzold's gear list:marc petzold's gear list
Sigma DP2 Merrill A3000 Nikon D7000 Nikon D90 Nikon 1 V1 +69 more
