D800 USB connection
Started May 11, 2014 | Discussions
starman1969
starman1969 Senior Member • Posts: 3,704
D800 USB connection
I recently upgraded to a D800 but I was disappointed with the supplied usb cable. It doesn't look like any other usb cable I own. Nothing like the popular type for my D600, so it does cause inconvenience when transferring files from different bodies.
Am I missing something, or is there a reason for the dual plug usb??
They are watching us......
 starman1969's gear list:starman1969's gear list
Nikon D800E Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.8G Canon EOS 1000D Nikon D4 +5 more
Nikon D600 Nikon D800
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 10,596
Re: D800 USB connection
The D800 cable is USB 3 for much faster file transfer to a USB 3 computer than older style USB 2.
USB 3 needs a "full size" USB connection with the USB 3 notch at the camera end.
The Nikon cable has an extra plastic part at the camera end to prevent the cable from accidentally being pulled out. At first my cable was not 100% reliable but since using it about 7 times it works perfect every time.
Leonard Shepherd
Producing good quality photographs, or being good at sport or art, involves a little more than buying appropriate equipment. Practice, some learning and perhaps natural talent often play a bigger role than the equipment in your hands.
Nikon Coolpix P7700 Nikon D800 Nikon D7100 Nikon D810 Nikon D750 +24 more
romfordbluenose Senior Member • Posts: 2,082
Its a USB3 connection. All USB3 devices use this cable
 romfordbluenose's gear list:romfordbluenose's gear list
Nikon D800 Nikon D5300 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +8 more
starman1969
starman1969 OP Senior Member • Posts: 3,704
Thanks for the answers. It is very fast, so I won't complain about that.
David314 Veteran Member • Posts: 4,790
USB3
It is the USB3 standard that adds the other connector.  This is not a Nikon specific connector
You can still use USB2 cables - just plug it into the smaller of the two connectors on the camera
USB3 has blue on the computer end inside plastic
Re: USB3
I always thought the other connector on a D800 was an HDMI output port not a USB2 port.
Are you saying the HDMI port can be used for USB2 transfers using a USB2 cable, and have you actually used it in this way? As far as I know the HDMI port can only be used to connect to a display of some sort.
not in HDMI
USB3 micro B has two connectors, - see far right below
one of them is a standard USB micro B connector and any micro B USB 2 cable will work when plugged into that half
so you can use any standard USB 2.0 micro B cable with the D800 by only using half of the USB3 connector
I hope that makes sense.
I too was puzzled by the D800 connectors but now that I have other USB 3 devices I see the logic behind what was done and can understand how it can be confusing.
Re: not in HDMI
Thanks, I have learned something new today.
AlephNull Senior Member • Posts: 1,308
Re: USB3
There IS an HDMI port as well as a USB3 port (the USB3 looks like two connections, but it's one), the HDMI port is separate.
 AlephNull's gear list:AlephNull's gear list
Sony RX100 II Nikon D810 Canon EOS 5DS
starman1969
Re: USB3
That's interesting. So if I was to just plug in the smaller connector that would work?? I understand the transfer would be slower if so.
I just got caught out by the strange looking connection because I've never seen one like it before, although I am aware of USB 3.0
Robin Casady Forum Pro • Posts: 12,898
Yes, it is a USB 3 Micro-B connector and you can find cables of various lengths on Amazon. I bought a 1 ft. cable for use with a CamRanger so there would be less spaghetti around the camera.
Robin Casady
http://www.robincasady.com/Photo/index.html
"Get your facts first, then you can distort them as you please."
—Mark Twain
Cliff Fujii
Cliff Fujii Veteran Member • Posts: 4,697
That's because it's a micro USB 3.0 cable. Most USB 3.0 connectors have a colored insert in the standard-A end denoting that it is USB 3.0. Not all of them do but the micro-B end is a dead giveaway that it is a USB 3.0 cable. The USB 3.0 cable that comes with the Nikon D800 has one standard-A end and a micro-B end.
http://en.wikipedia.org/wiki/USB_3.0
Micro USB 3.0 cable. Notice that it has two areas for conductors.
Cliff
 Cliff Fujii's gear list:Cliff Fujii's gear list
Fujifilm X-E2 Nikon Df Nikon D810 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +46 more
starman1969
Cliff
Thanks for that. I took another look at my cable and it has the blue end. I didn't notice that before.
Robin Casady
—Mark Twain
Be aware that USB3 is far more sensitive to cable length than USB2. Do not try lengths over 2m.
