Help: what 20mm or less for A7 (slow, sharp and cheap)?
Started May 10, 2014 | Discussions
darkdirtydwarf
darkdirtydwarf Senior Member • Posts: 1,019
Hi everyone, I need your help
As the title says, I need a 20mm or less lens (for interior photography, so no fish-eye or lenses with a lot of weird distortions) for the A7.
It can be slow (I use flash), but it must be decently sharp (at least at F5.6-8). It can be a legacy MF lens (cheaper).
Any idea? I plan to use it until I get the 16-35 FE, therefore I don't want to invest too much.
I have adapters for Minolta (MC/MD/AF), Nikon, Hexanon, M42.
Thanks for any input you can give me!
 darkdirtydwarf's gear list:darkdirtydwarf's gear list
Sony Alpha 7 Sony Alpha NEX-5N Sony SLT-A55 Sony Alpha NEX-5 Sony E 18-200mm F3.5-6.3 OSS +8 more
Sony Alpha 7
azalea Regular Member • Posts: 180
Re: Help: what 20mm or less for A7 (slow, sharp and cheap)?
What about VM12/15?
I myself am quite interested in VM12 since I use APSC, and should I want to run to fuji i can still use it.
 azalea's gear list:azalea's gear list
Sony RX1 +1 more
maurus_e Senior Member • Posts: 1,657
If you have an A-mount adapter I recommend the old Minolta 20/2.8 AF lens. There are two versions and a Sony version. Quite decent lens imho.
darkdirtydwarf
darkdirtydwarf OP Senior Member • Posts: 1,019
What's the price range?
darkdirtydwarf
Yes, the Minolta in Version RS was my first choice, but it goes for over 300 Euro. I was hoping to spend a little less than that (I let one escape for 200, I'm still biting my fingers..).
http://www.flickr.com/photos/8321403@N03/
tammons Veteran Member • Posts: 5,866
I would say a 20mm Nikon off this list with a 5 rating then sell it when you buy your other lens.
Should be easy to sell.
http://www.photosynthesis.co.nz/nikon/serialno.html
KEH has 1 bargain and 1 ugly 20mm lenses that are pretty cheap.
One F4 and one F3.5, otherwise you will be paying $300-400.
www.troyammons.com
www.pbase.com/tammons
Tim Devine
Tim Devine Senior Member • Posts: 1,173
Canon FDn 20mm f/2.8
Don't have one personally, but some nice examples on FM.
http://www.fredmiranda.com/forum/topic/1278114/0#12185103
-Tim
 Tim Devine's gear list:Tim Devine's gear list
Sony Alpha 7R Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sigma DP1 Merrill Canon EOS 5D +17 more
darkdirtydwarf
Re: Canon FDn 20mm f/2.8
Thanks for the tip but I don't have the adapter and I'm trying to go el-cheapo (and adapters don't sell well).
Nice quality though!
darkdirtydwarf
I live in Europe, so KEH is not an option unfortunately, only evilBay
I wish I didn't let that Minolta AF slip away, there's not another in available right now for a fair price (in good conditions and with lens hood)...
I'm having a look at some zooms, there seem to be some cheap option (about 100 Euro) in that range.
Just to make it clear, I'm trying to find a FF solution to substitute, at least in part, for my Sigma 8-16 on APS-C (I sold my A55 to finance the A7 and my second body, a NEX5N doesn't have an hot shoe nor can trigger an external flash).
I don't need to go as wide as 12mm on FF (way too expensive) and 20mm is still acceptable.
tomtom50 Veteran Member • Posts: 3,244
azalea wrote:
What about VM12/15?
Luminous Landscape has an article on WA on the a7r. The VM symmetrical designs do not work well on FF.
http://www.luminous-landscape.com/essays/lenses/sony_a7r_wishful_thinking.shtml
 tomtom50's gear list:tomtom50's gear list
Sony RX100 Sony Alpha NEX-3N Canon EOS M Sony a6000
darkdirtydwarf
Great link, thanks!
In the end I decided to pull the trigger on a Tokina AF 20-35, the price was very good and the reviews are good.
Let's see if I'm lucky
Tim Devine
I had the Tokina 20-35 MK II (EF mount), worked well on film and crop. Far corners went downhill quick on my original 5D though. Post your thoughts after you have a chance to try it, i'm curious how it performs.
-Tim
Great link, thanks!
darkdirtydwarf
Hi Tim, thanks for the input!
As far as I can see, MK I and II have the same optical formula, the updates are minor, so MK I should perform similarly (and I prefer the smaller size). I need to use it stopped down, with a bit of luck it'll perform well enough.
Once I get it I'll compare it to my Sigma 8-16 and post the results.
viking79
viking79 Forum Pro • Posts: 14,135
Most legacy 20mm lenses (zoom or otherwise) will have a lot of field curvature.  Focus a bit out from the center to get better corner performance.
I use a Canon 20mm f/2.8 and think it is fine at f/8 or something, as long as you balance focus between edges and center.
Eric
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Aasmund G Contributing Member • Posts: 853
Sigma 21-35
 Aasmund G's gear list:Aasmund G's gear list
Sony Alpha 7 Sony FE 35mm F2.8 Sony 70-400mm F4-5.6 G SSM
Jeffrey Behr
Jeffrey Behr Veteran Member • Posts: 3,338
"...and adapters don't sell well." Maybe so, but this all-manual adapter...
...will cost you only a few bucks. Search for FD to Sony e on eBay. I ordered mine for about US$10. The Canon FD 20 sells for as little as about $200. Don't have 'mine' yet, so can't say how they work...but I just bought one.
Damned amateur fotografer trying to get a little more active again.
http://community.webshots.com/user/jeffreybehr
 Jeffrey Behr's gear list:Jeffrey Behr's gear list
Sony Alpha 7R II +4 more
dunders Regular Member • Posts: 115
My Tokina 3.5/17 in Pentax mount works well. A little CA easily fixed in LR.  The distortions you would expect, similarly easily fixed if necessary.  Fits all three criteria.
A cheap Pentax K-> Sony E adapter from eBay will suffice.
Paul
... lost in the Irish Sea.
http://flickr.com/photos/dunders
 dunders's gear list:dunders's gear list
Sony Alpha 7R
Rokinon/Bower/Samyang 14mm f2.8.
Not slow, extraordinarily sharp, about $300 new.
http://www.photozone.de/canon_eos_ff/532-samyang14f28eosff
Will hold its value, resell when you get another lens.
Aasmund G wrote:
Sigma 21-35
OP - You know I just ordered one of these from KEH to try out on an A6000 so I can give you a report when I get it if you are interested.
www.troyammons.com
abortabort Senior Member • Posts: 1,682
This. Also get in EF mount to hold the best value, buy a $10 dumb EF adapter.
 abortabort's gear list:abortabort's gear list
Sony RX100 Fujifilm X100S Sony Alpha 7 Panasonic Lumix DMC-GH2 Konica Minolta Maxxum 7D +54 more
