Small walk around bag for D800 + 50mm f1.8g
Started May 9, 2014 | Questions
SnappyS Forum Member • Posts: 57
Hi,
Any recommendations on a very small lightweight bag but with sufficient padding to carry my D800 with 50m f1.8g lens for walking around the city for a day? The camera will be carried in the bag most of the time and only taken out while visiting various tourist sites. The smaller the better. Other than a spare EL15 battery, no other equipment will need to fit.
Thanks in advance.
Nikon D800
Photofunster
Photofunster Senior Member • Posts: 1,548
Re: Small walk around bag for D800 + 50mm f1.8g
You may get better response to this sort of question, in the Accessories Talk forum.
A Lowepro Toploader Pro AW 70 will hold it nicely...
http://www.lowepro.com/toploaderpro
Love all of my Lowepro gear...
Chas
D800, AF-S NIKKOR 80-400mm f/4.5-5.6 G ED VR, B+W Clear MRC 77mm, AF-S NIKKOR 24-120mm f/4 G ED VR, Sigma DG UV 77mm,
SB-910, WG-AS3, ME-1, Lexar Professional 600x 64GB SDXC UHS-I 90MB/s*, 400x 32GB SDHC UHS-l 60MB/s*
Vanguard ALTA PRO 263AT, GH-300T, SBH-250, SBH-100, PH-22,
Lowepro S&F Deluxe Technical Belt and Harness~Pouch 60 AW 50 AW & 10, S&F Toploader 70 AW, LC 11x26cm
FE, NIKKOR 2-20mm f/1.8, OPTEX UV 52mm, Viivitar Zoom 285,
Kodacolor VR 1000 CF 135-24 EXP DX 35mm, rePLAY XD 1080P
 Photofunster's gear list:Photofunster's gear list
Nikon D800 Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR Apple iPad 3G +WiFi +2 more
Chuck Lantz Veteran Member • Posts: 4,316
SnappyS wrote:
Hi,
Thanks in advance.
Check the Case Logic bags, too.  They are not too expensive, high quality, and come in lots of sizes and shapes.  I have five of their bags, including their large and small SLR bags, and a sling bag. The large SLR bag will carry a D800 with a 300mm lens and a battery grip attached, plus batteries and a flash unit, with room to spare.  the outside bottom is semi-hard plastic, so setting it down on wet surfaces is not a problem.
One great feature is their camera suspension system, which holds the camera and lens suspended in the bag so that they aren't in contact with the bottom of the bag. If you drop the bag or set it down hard, there's an inch or two of space between the hard bottom and your gear.
"I'm hooked on The Look"
"If they're not screaming at you to get out of the way, you're not close enough" - I thought this was original, but it's very close to what someone else said. Oh, well.
... "Not to compete whole-heartedly, with a will to win, degrades the sport and insults the competition" - anonymous Olympic long-distance runner ...
"Mongo not know ... Mongo just pawn in game of life." - Mongo ... "Speed kills" - No, it doesn't. Speed has never killed anyone. It's the sudden stop that does it. - Me ... http://www.ChuckLantz.com ... Confessions from the middle of the pack: What I lacked in skill and courage I made up for in enthusiasm. As a result, I was enthusiastic beyond belief.
 Chuck Lantz's gear list:Chuck Lantz's gear list
Nikon D2X Nikon D700 Sigma SD9 Sigma SD14 Sigma SD15 +22 more
Janoch
Janoch Senior Member • Posts: 2,397
I used to take camera and lens to work in the little Tamrac Rally 4 bag.
Some good bags may be found at CamBags.com, here's the list of shoulderbags for 1 camera and one lens: http://www.cambags.com/by-bag-size/by-bag-size-shoulder-bags/by-size-shoulder-1-body-1-lens.html
 Janoch's gear list:Janoch's gear list
Nikon D800 Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 70-200mm f/4G ED VR +2 more
SnappyS OP Forum Member • Posts: 57
Thanks everyone.  I went with the Lowepro Nova Sport 7L AW.  Its a tad bit bigger than what I was looking for, but what sold me is that it includes a weather cover.  It also matches my Sport 200 AW backpack.
Photofunster
Lowepro, way to go...
Good choice, it will serve you well.
Ah yes, any Lowepro bag with that designated AW means that a weather cover is present.
Enjoy your awesome camera bag... I know you will!
Chas
ARB1
ARB1 Veteran Member • Posts: 3,082
Re: Lowepro, way to go...
I use a Billingham Digital Hadley bag which will fit a lens larger than a 50mm also.
Allen
___________
"It's easier to build strong children than to repair broken men."
-- Frederick Douglass
 ARB1's gear list:ARB1's gear list
Olympus OM-D E-M5 Nikon AF Nikkor 50mm f/1.4D Nikon AF Nikkor 85mm f/1.8D Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Nikon AF-S Nikkor 24-120mm f/4G ED VR +6 more
igzy Regular Member • Posts: 141
That is my most frequent body lens combination and I use Lowepro Topload Zoom TZ1, new bag code is AW 50 I think...
 igzy's gear list:igzy's gear list
Canon PowerShot G12 Nikon Coolpix S31 Nikon D700 Nikon D800 Fujifilm X-A1 +1 more
Very good choice.  Lowepro makes a great product, and their customer service is astounding.  I use one of their AW slingbags, which is perfect for carrying and quickly retrieving your cameras.
They may not like publicizing this story, but I'll tell it anyway.  After owning the Lowepro slingbag for a few months, one of the zippers jammed.  I called them about the warranty, and they not only sent me a new bag, but insisted that I keep the old bag, too, even though I was able to get the zipper to work - with a bit of a struggle.  Maybe I'm too easily impressed, but that amazed me.
Photofunster
Zipper Repair
Try rubbing some paraffin wax on that sticky zipper and work it in. May help alleviate the stickiness.
Good for you, they solved the problem the easy way... Renew!
Chas
Re: Zipper Repair
Chas
Thanks!
