Spot/partial metering while using TTL flash?
Started May 4, 2014 | Discussions
70Der
70Der Regular Member • Posts: 344
I suppose this could be different for different companies but with Canon specifically, when you have your metering set to spot and an eTTL flash, will the ambient exposure be completely ignored in Av mode? In evaluative, the camera meters/sets exposure for ambient while flash meters for subject. But if both the flash and spot are metering the subject, what happens to the ambient?
AlanPezz
AlanPezz Regular Member • Posts: 159
Re: Spot/partial metering while using TTL flash?
On my 6D under the speedlight control menu is the option to set how flash works in Av mode.
1 Auto - Shutter speed will set to include ambient
2 Shutter speed adjusts between 1/60 and 1/180
3 Shutter speed set to 1/180
Option 1 will drag the shutter giving you both an ambient and flash exposure.
Option 2 and 3 will reduce ambinet to black indoors under most lighting
Doug Pardee
Doug Pardee Veteran Member • Posts: 7,851
No, it won't be ignored. Av mode is your "fill flash" mode. It measures ambient (using whatever metering you select) and sets the shutter speed accordingly. It then uses the flash as fill. If you want the flash as the main lighting, you'll need to select another mode — typically M — and dial in a significant underexposure of ambient.
Be aware that in relatively low-light situations, using Evaluative metering on the camera along with E-TTL II flash will cause the camera to reduce the ambient exposure to compensate for the additional light that the flash will be expected to add. This is not true of other metering modes (such as Spot); in those cases it's the photographer's job to determine whether to reduce ambient exposure, flash exposure, or both, and by how much. (FYI, this feature has been informally given the name NEVEC, and you can see your camera's exposure settings change as you switch the flash on and off.)
There are a number of other complexities involved in E-TTL II flash photography. If you're not prepared to get into them, I recommend that you stay with Evaluative metering for both camera and flash, and use Av for fill flash and M (shutter speed set to X-Sync, which I think is 1/250 on the 70D) for "close to pure flash." I believe there's also a Custom Function you can set which will force Av to use X-Sync shutter speed, thereby making it unnecessary to switch to M mode for "close to pure flash" but removing your ability to use fill flash.
The open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Canon EOS 350D VSCO Cam Olympus Stylus 1030 SW Canon EF-S 17-85mm f/4-5.6 IS USM Adobe Photoshop Elements 10 +20 more
