HIGH ISO Star Photos, K5 does good!
Started May 4, 2014 | Photos
UtahManSir
UtahManSir Veteran Member • Posts: 4,645
9
Spent a night deep in the desert in the Grand Staircase-Escalante National Monument. Took a few star pictures late at night, lighting the ground with my Metz AF 50 handheld. I used my Sigma 10-20 wide open at 10mm f4. Kinda getting interested in the Samyang 10mm f2.8 for these kinds of things!!!
ISO 3200, f4, 10mm 30s.
Thanks for looking,
Lloyd
“For every problem there is a solution which is simple, clean and wrong.” Henry Louis Mencken
http://lloydshell.blogspot.com/
http://lloydshell.zenfolio.com/
WSSA #354
http://lloydshell.zenfolio.com/img/s3/v41/p234497562-3.jpg
Comment & critique:
Pentax K-5 Sigma 10-20mm F4-5.6 EX DC HSM
Younes B
Younes B Contributing Member • Posts: 805
Re: HIGH ISO Star Photos, K5 does good!
K5 does good indeed. And so is your technique.
Can you expand on how you used your flash ? did it fire more than once for the first pic? It seems it covered a lot ...
 Younes B's gear list:Younes B's gear list
Pentax K10D Pentax K-30 Pentax K-5 II Pentax K-5 IIs Pentax smc DA 16-45mm F4 ED AL +6 more
ozdean
ozdean Forum Pro • Posts: 22,861
Great work Loyd, you did well with the lighting.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-50 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 70mm F2.4 AL Limited Pentax smc DA* 60-250mm F4.0 ED (IF) SDM +9 more
Brooke Meyer
Brooke Meyer Contributing Member • Posts: 604
Adding light makes the image.  Well done.
Roland Karlsson
Roland Karlsson Forum Pro • Posts: 24,151
Nice!
Care to tell us something about the lighting technique?
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sony Cyber-shot DSC-RX100 III Sigma DP3 Merrill Sigma dp2 Quattro Pentax K-3 Pentax K-1 +12 more
robbo d
robbo d Senior Member • Posts: 1,731
Very nice images.........there is a constellation challenge going on right now.
 robbo d's gear list:robbo d's gear list
Pentax K-5 IIs Pentax K-x Pentax K-01 Sigma 17-50mm F2.8 EX DC OS HSM Sigma 50mm F1.4 EX DG HSM +13 more
sfa1966
sfa1966 Veteran Member • Posts: 3,316
Well done. Very nice shots indeed.
sfa
 sfa1966's gear list:sfa1966's gear list
Sigma DP1 Sigma DP2 Merrill Pentax K-5 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 10-17mm F3.5-4.5 ED (IF) Fisheye +9 more
philzucker
philzucker Veteran Member • Posts: 7,424
Just fantastic, Lloyd. Great effort and fascinating results.
Congrats!
And thanks very much for sharing.
Phil
johnami
johnami Contributing Member • Posts: 808
Lucky man to have a black zone near you.
 johnami's gear list:johnami's gear list
Sigma DP2 Panasonic Lumix DMC-LF1 Pentax K-3 Pentax K-5 Pentax K10D +11 more
Michael Piziak
Michael Piziak Regular Member • Posts: 408
Awesome photos !
 Michael Piziak's gear list:Michael Piziak's gear list
Pentax K-r Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA 18-55mm F3.5-5.6 AL +1 more
UtahManSir
UtahManSir OP Veteran Member • Posts: 4,645
Thanks Younes,
I only fired it once, from off camera right, held it up as high as I could, and backed it down to 1/8 or so for the first one, maybe less for the second one. I just kept staggering back and forth in the dark to check the LCD untill it looked right. That is the most important technique is to review the LCD after EVERY shot, helps to have an assistant.
Lloyd
WSSA #354
UtahManSir
Thanks Dean, Got about 1 in 10 right, always a learning curve.
Lloyd
WSSA #354
UtahManSir
Thanks Brooke, I was hoping to achieve something interesting. Just wish the Milky Way would have been up!
Lloyd
WSSA #354
UtahManSir
Roland Karlsson wrote:
Nice!
Thanks Roland, All I did for lighting was walk off to the side or around an object where I could flash the rocks to give them texture, then go back and look at the LCD. Then adjust my flash intensity and position accordingly. Once you have played with it a little it is easy!
Lloyd
WSSA #354
UtahManSir
Thanks Robbo, May have to look into that.
Lloyd
WSSA #354
UtahManSir
sfa
Thanks! I had a blast getting them, I think I finally have my settings worked out for astrophotography now!
Lloyd
WSSA #354
UtahManSir
Thank you Phil, I suppose I could have done a panorama just for grins...
Lloyd
WSSA #354
UtahManSir
Thanks, I actually have a LOT of black sky near me. http://www.jshine.net/astronomy/dark_sky/
Just have to find the time to get out there!
Lloyd
WSSA #354
UtahManSir
Thanks Michael!!! Appreciate your commenting.
Lloyd
WSSA #354
Jim Beverlin
Jim Beverlin Veteran Member • Posts: 3,224
Excellent images.  Not certain I completely understand how you did the lighting.  Something I have to try first hand.
Thanks for posting.
JRB
