Front filter for lens-UV or clear glass?
Started May 3, 2014 | Questions
Normo New Member • Posts: 9
I am getting the kit 18-55mm lens and want to put a filter on the front.  I have been looking at B&W filters and have probably been reading too much.  Do most of you use a UV / haze reducing filter or just plain clear glass.  B&W makes some expensive and high quality filters and wondered what most of you Fuji users employ.  I am getting a XE1 with the kit lens at a good price ( thanks to members of the forum for a heads up) and want to protect the lens and images as best as I can.  Thanks  Norm
Fujifilm X-E1
Cadder Senior Member • Posts: 1,608
Re: Front filter for lens-UV or clear glass?
I have B&W Nano clear, on all my lenses.I don't find that they cause any problems.
Cadder
You can get them for about $45 on eBay. (Best eastern has them.)
Bill Robb Senior Member • Posts: 3,332
I don't use filters at all except for when I need them for a particular effect (polarizer, for example). If I was going to be shooting in a steel mill, I might consider a protective filter, but for day to day use, no, the lens hood provides more protection.
I don't think you will see much difference, if any, between a UV filter and a clear glass one.
Peter Jonas Senior Member • Posts: 2,674
Use the front filter judiciously. You may not need it all the time, in fact you may find that you don't need it most of the time. However, if it gives you peace of mind, use it by all means.
All that said, if you do want to use a filter, it's best to use a neatral colour filter, as UV filtering is not necessary for digital sensors.
And use a high quality one in order to minimise any detrimental effect on image quality. In most circumstances you will not be able to tell appart images taken with or without the filter. You will want to take some care when photographing into the light with a filter on, as the additional glass surfaces could be the source of internal reflections.
I use Nikon NC filters of the appropriate size (in this case 58mm) or Hoya Super HMC Pro1 UV(0) grade filters. They are both top quality items. There may be others, but I never needed to use anything else, so I have no first hand expereience with any of those.
You cannot get confused with the Nikon filter as they only make the one grade of NC filters. Hoya on the other hand, make many different grades. Super HMC Pro1 is their top model, and I would not consider buying the lesser grades from them. Super HMC is the name of the multi coating they use on the glass, and Pro1 is the designation for the thin metal ring they use.
Good luck with your new camera.
Peter Jonas
 Peter Jonas's gear list:Peter Jonas's gear list
Fujifilm X-E2 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +1 more
OldPhil Regular Member • Posts: 114
I've been using the UV-haze B+W Nano MRC filters; the coating is extremely scratch resistant. Many people trade in lens with the filters, which are then sold separately by the store. I've been able to buy like new filters for 1/2 to 2/3 of the price of new filters from the larger online sources.
 OldPhil's gear list:OldPhil's gear list
Nikon D800 Fujifilm X-T1 Nikon D750 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +11 more
Tom Schum
Tom Schum Veteran Member • Posts: 5,179
Hoya HD and HD2 are good.  Supposedly very tough.
Sigma makes filters also.   Sigma DG filters have a very good coating but not as much a selection as you might like..  If you can see the filter the coatings are not good enough.  Sigmas are good, and priced reasonably.
I prefer UV filters but I really don't have any good reasons why.  One possible reason is that less UV into the lens is less light refracting differently through the lens.
I think B+W makes UV+IR filters too, which restrict the spectrum to the visible range.  They are quite pricey, so I haven't tried any.  IR blocking is good, because it improves on the existing IR blocking taking place just in front of the sensor.  Any IR reaching the sensor will become visible in the image.  It's hard to say if UV will be visible or not but my guess is the image will be better without it.
Tom Schum
Sigma DP2 Sigma DP3 Merrill Ricoh WG-4 GPS Fujifilm X30 Sigma dp0 Quattro +8 more
TonyB51 Regular Member • Posts: 129
I use clear glass.
Fuji's own are nice
http://shop.fujifilm.co.uk/accessories/protector-filters?dir=asc&order=price
..but a bit expensive.
Otherwise, as others have said, the Hoya top-of-range stuff.
 TonyB51's gear list:TonyB51's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 27mm F2.8 Fujifilm 50-230mm +6 more
ryan2007 Forum Pro • Posts: 12,001
With all digital cameras you do not need a UV filter. The clear protective filter is all you need.  UV was designed for Film based cameras as I have come to understand the difference.
So, get a multi-coated filter.
Heliopan IMO is a step above B&W and the Kasseman (spelling) version of the B&W filters are at least equal to heliopan and a step above the standard B&W versions.
Only spend the money on a Multi-Coated filter and more money in proportion to the cost of the lens.  If you took the time to buy a $2,000 lens don't put a cheap filter on that, but you do not need a UV filter unless maybe you live in the mountains where it may help.
Patrick T. Kelly Veteran Member • Posts: 4,061
I'm with Robb and use filters as filters. I am a fanatic about using my lens caps. If I'm moving, my lens cap is on. The filter I use most often is the polarizing filter. I have some ND filters I use on occasion.
Patrick T. Kelly
Oaxaca, Mexico
bs1946
bs1946 Senior Member • Posts: 3,474
I have the 18mm and 35mm lenses. Both take a 52mm filter and you can get a Fuji 52mm clear protection filter for $9.95. I am assuming that the filter is of the same quality as the front glass on the lens. Any other size and the price jumps up to around $50.
 bs1946's gear list:bs1946's gear list
Fujifilm X-E2 Fujifilm XF 18mm F2 R Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Samyang 21mm F1.4 +1 more
