Catch-All Focus on the XT-1?
Started May 3, 2014 | Discussions
PG Thomas Contributing Member • Posts: 667
I relay like this Camera and I've retired the X-Pro1
BUT
It doesn't have Catch-All in manual focusing mode for Manual Lenses. And I can't understand why.
Its the most useful feature at motor sports events where one picks a spot on the track and lets the camera fire the shutter when the subject comes into focus.
It has Release/Focus priority which links the shutter to the focus point, so why not for manual lenses when the subject comes into focus rather than the other way round?
The Pentax K5 has this from day 1. And is the reason why I won't retire it now when the Water resistant lenses are released.
Also - why is the Vertical Battery Grip not water resistant? What's the sense in that? You are most likely to use it outdoors at sporting events / heavy telephoto lenses. Surely It wouldn't have been difficult to add a few seals to complete the job.
Semi-Pro camera? Nearly but not quite.
Just my take on the XT-1
Pete
 PG Thomas's gear list:PG Thomas's gear list
Fujifilm FinePix F100fd Fujifilm X10 Pentax K20D Pentax K-5 Fujifilm X-T1 +14 more
Fujifilm X-Pro1 Pentax K-5
J Frank Parnell Regular Member • Posts: 263
Re: Catch-All Focus on the XT-1?
From the Fujifilm web site:
Combined with the rechargeable battery in the body, the battery in the dust-and water-resistant vertical grip provides enough change for approximately 700 frames.
(the typo is Fuji's)
 J Frank Parnell's gear list:J Frank Parnell's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS
Just a Photographer Senior Member • Posts: 1,368
Under Priority Focus set both option to focus - should do the trick.
 Just a Photographer's gear list:Just a Photographer's gear list
Nikon D4 Nikon D800E Fujifilm X-T1 Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +9 more
PG Thomas OP Contributing Member • Posts: 667
Hi Frank.
I quote from the VG-XT1 handbook:-
"This product is not waterproof. Keep the interior free of water, sand, dust, mud, salt, harmful gases, and other foreign matter. Do not place on wet surfaces." (My underlining).
In my mind it isn't up to the standard of the XT-1, but lets wait and see how the camera performs when the ''Weather resistant lenses" appear.
The Pentax K5 with it's lens will survive and operate in hours of torrential rain. (As proven this week in the UK) without a blip. That's what I expect from my semi-pro kit.
I hope DP review have the guts to test this when the lenses appear.
Pete
PS. Fuji UK are offering £250 off the price of the XF 18-135 when it is released (if you buy the XT-1). No doubt I will take them up on it as I really would like to go down to one camera system. But for now the K5 is staying.
Tried it.
It should work as logic would suggest that the camera  would use its phase / contrast  detect to confirm focus before releasing the shutter.
But no, the camera shutter just fires irrespective of the focus point of the lens (Pentax 50mm FA 1.4).  I have lots of wildly out of focus images to prove it. Press the shutter- and it fires anywhere from 0.5 meters to infinity!
It clearly needs to communicate with the lens to work, but I can't understand why it is needed.
Any ideas?
Pete
(unknown member) Senior Member • Posts: 1,321
With regard to third-party lenses and focus.
I assume you refer to this menu option when you discuss catch all focus?
"Choose how the camera focuses in focus mode AF-S or AF-C.
RELEASE: Shutter response is prioritized over focus. Pictures can be taken when the camera is not in focus. • FOCUS: Focus is prioritized over shutter response. Pictures can be only taken when the camera is in focus."
 wchutt's gear list:wchutt's gear list
Fujifilm X-Pro1 Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +20 more
Yes
And it doesn't work. Pictures can be taken at any focus position with non Fujinon lenses.
So it only appears to work with lenses which communicate with the body. (I.e. Fujinon). Try it!
Pete
Chad Hardy
Chad Hardy Senior Member • Posts: 1,191
Tried it.
Any ideas?
Pete
Just to confirm, you are saying the Pentax K5 will work the way you want it to with a non-native lens (i.e. lens with adapter)?
 Chad Hardy's gear list:Chad Hardy's gear list
Fujifilm X-T1 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 56mm F1.2 R Sony Cyber-shot DSC-RX100 III Olympus E-M1 +16 more
Chad Hardy
Tried it.
Any ideas?
Pete
If the sensor can't communicate with the lens, how is it is supposed to know when a subject is in focus?  For the same reason AF doesn't work I would not expect the camera to know it is in focus with a non native lens.  However if you say Pentax has pulled this off then cool beans.  My A7R works the same as the Fuji.
Yes
Pete
Of course it doesn't work with lenses that can't communicate with the body. There is no way for the focus system to interact with the shutter system.
On most Nikon bodies the phase-sensitive focus sensors on the mirror can indicate focus using a green dot at the lower left hand side of the screen. This works if the lens is 5.6 or faster and shutter is depressed half way. I don't remember if the Nikon allows prioritized shutter control.
For the XT-1 Fujifilm does not use the phase sensitive pixels on the sensor to detect for focus. Instead in manual mode they provide the dual-screen mode so you can use focus peaking, a split screen display, or just visual inspection to set and confirm focus.
I have used D200/300/700 bodies since 2008 and the XT-1 manual mode outperforms the Nikon green dot method by far.
shigzeo
shigzeo Senior Member • Posts: 1,722
Yes
Pete
Nikon has the system the OP is talking about. I used it all the time. Amazing. The Fujifilm doesn't. Every time the shutter is tripped, no matter the setting, it will fire or try to achieve focus. The camera does NOT understand trap focus with native or other lenses, which is a shame. That said, the control layout isn't as good for that sort of photography as it is on Nikon cameras.
The buttons are harder to blindly press and each one feels the same, so there is no physical indication of which button you are pressing apart from position of the thumb. I have been rather unimpressed by the AF system and the shutter tripping system of the X-T1. It takes too many opposing ideas and throws them into a body that looks like it should be able to do the trick, but does not.
It is NOT a replacement for a Nikon DSLR for a number of key photographic areas. It is an awesome camera though.
 shigzeo's gear list:shigzeo's gear list
Nikon D200 Fujifilm X-Pro1 Nikon D800 Leica M Typ 240 Sony Alpha 7R +9 more
HB1969 Contributing Member • Posts: 751
Hi Frank.
Perhaps fuji is using the same language used by watch manufacturers...ie water-resistant is not the same as water-proof. Water-resistant means that it can tolerate being lightly splashed with water. Water-proof can be immersed in water to a certain depth. For example, my watch says water-resistant to 50m but in the user manual "do not immerse in water".
 HB1969's gear list:HB1969's gear list
Fujifilm X-E1 Canon EF 50mm f/1.8 II Canon EF 75-300mm f/4.0-5.6 III Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +6 more
Dabbler
Dabbler Senior Member • Posts: 1,848
The XT1 isn't waterproof either. But it is weatherproof as is the batterygrip. If you need waterproof get a waterproof housing.
Michael
 Dabbler's gear list:Dabbler's gear list
Sony Cyber-shot DSC-RX10 Sony Cyber-shot DSC-RX100 III Panasonic Lumix DMC-FZ1000 Nikon D800 Fujifilm X-E1 +18 more
Hi Chad
Yes that's how it works.  I often use the Tamron SP 300/2.8 at sporting events focused  on a part of the track and then raised a tad so that the image is out of focus at the focus point. When the Car / bike (whatever) comes into focus the shutter fires.
Saves a lot of wasted shots!
Pete
shigzeo
PG Thomas wrote:
Hi Chad
Pete
It is useful in so many places. Set a distance, finger on the trigger, depressed fully, wait, or drag the camera in a line and fire it does only when the camera detects focus. No AF motor engaged, just AF prediction. Amazing tech that the X-T1 lacks.
Not only that but the shutter always triggers the AF module, too. Unless I'm missing something, there is no way to use AF with the AF button only, and 'M' mode doesn't count.
The way I see this. In AF mode The Fuji sends signals to the focusing motor to bring the subject into focus within the focus area. So it is the Camera (not the lens) which matters here.
With the K-5 you leave the camera in AF.S as Shigzeo mentions, and the camera waits for the image to be in focus before releasing the shutter as it clearly has no control over the manual lens.
Of course if one pans the camera around it will find something in focus and fire. But in this kind of sports event where one chooses the point of focus (on a tri-or monopod) you can keep that out of focus until the subject is at the right distance. I typically have a piece of out of focus crash barrier or road surface in the focus area where I know I will get a full frame shot of the subject in the centre of the frame in focus when it comes into view (usually about 10 meters nearer).
it seems to me that the XT-1 could do this. Leaving the setting on AF-S (Focus), and allow this mode  as an option in 'Shoot without Lens".
Pete
shigzeo
Pete
Would be so nice if this were available.
marvin t martian Forum Member • Posts: 58
PDAF does not require control over the focus mechanism to confirm focus.
Hi Frank.
Pete
Just noticed this from the X-T1 manual:
"Do not place the camera on a wet surface." Fuji doesn't seem to be claiming the camera is waterproof either.
junyo Regular Member • Posts: 321
BUT
Pete
FYI, it's "catch in-focus" not catch-all.:
http://en.wikipedia.org/wiki/Autofocus#Trap_focus
Nope, Fuji doesn't have it. If you look at the companies that have implemented it, they have some legacy non-AF glass to support, and it's a neat feature for that niche. I'd assume Fuji didn't add it to their bodies because they have no MF lenses and want to sell AF lenses.
