Well...I finally pulled the trigger on a Fuji 14mm f2.8!
Started May 3, 2014 | Discussions
Smiller4128 Regular Member • Posts: 452
Dropped about $650 on a used one in really good condition on eBay and it comes with a 6 month warranty should anything go wrong. It has the box and hood and lens caps as well so everything as well.
It took me a really long time to come to a decision between the 14mm and the 10-24mm zoom lens. I ultimately decided to go with the 14mm though because it's smaller, lighter, faster aperture (I know OIS in the 10-24mm makes up for this, but still) and because of the quick and easy way to go into manual focus mode by just simply sliding back the focus ring...for some reason that really enticed me so I got one/ Hopefully it'll be here sometime by the middle of this next week.
I'm hoping that I'll now be able to find a used 55-200mm and that, combined with my 14mm and 18-55mm on my X-T1 will be the perfect trifecta for my Alaskan Cruise at the end of September
 Smiller4128's gear list:Smiller4128's gear list
Olympus E-M5 II Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F1.4 R Olympus 12-40mm F2.8
Fujifilm X-T1
Al Valentino Senior Member • Posts: 4,661
Re: Well...I finally pulled the trigger on a Fuji 14mm f2.8!
Congratulations. Good choice and great price. I paid $800 on ebay last summer for a Used one in Like New condition. Never regreted. It mates very well with the 18-55. Hard to find anyone that regrets purchasing this little gem.
Fuji Silver XE1 w/14, 35, 18-55, 55-200, Rokinon 8mm Fisheye & Tamron 90mm f/2.8 Macro
 Al Valentino's gear list:Al Valentino's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +6 more
Ollie 2 Senior Member • Posts: 1,530
Well done. I'm a bit jealous. I have the 10-24mm and as much as I love it, I do ultimately prefer primes.
Grrr....is having both simply self indulgent and excessive????
....maybe I'll have to find out.:-)
Congrats. I hate you.;-)
 Ollie 2's gear list:Ollie 2's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Olympus PEN E-P2 Fujifilm X-Pro1 +19 more
km25
km25 Contributing Member • Posts: 601
You guys got good deal, I paid full price, but I do to care the 14mm F/2.8 is a little soft at 2.8 at the edges, that is were the cons end. The distortion is correct, but it is nearer normal the wide. IOS on a wide, not so much. I feel this a gotta own lens if you go Fuji.
kam
 km25's gear list:km25's gear list
Fujifilm X-T1 Leica Elmarit-M 24mm f/2.8 ASPH Leica Summilux-M 35mm f/1.4 ASPH Leica Summicron-M 50mm f/2 Fujifilm XF 14mm F2.8 R +3 more
machoman Regular Member • Posts: 109
kam
Can someone please make a comment about distortion from the lens - I'm always disappointed with wider than normal lenses as pics taken with people at the edges always distorts their faces. The panasonic 20mm on the GH1 distorts people faces - i spent so much time trying to make it look acceptable that i gave up. I would love to get a nice wideangle but i'm afraid the distortions will let me down.
viking79
viking79 Forum Pro • Posts: 14,137
machoman wrote:
kam
There are a couple types of distortion, but what you are referring to is a side effect of rectilinear projection. In order to force straight lines in the lens, objects must get stretched and distorted near the edge of the frame. There is no way around this and it will get worse the wider you go. This isn't a property of the lens specifically.
A fisheye is an alternative to a rectilinear lens. It maintains scale and prevents stretching near the edge of the frame, but straight lines are no longer straight. Fisheye lenses will often be better for people shots if you go extremely wide to prevent scaling/rectilinear distortion issues. You do have to be extremely careful though so you don't have bow shaped people at the edge of the frame. Probably best with one person and you can run them through the center.
But when people talk about distortion and the 14mm are referring to barrel distortion in the lens. The 14mm doesn't have any, if you took a picture of a checker board all the squares would be square (not curved). It is "optically correct". This may or may not be important to you, in general this is going away as you can typically do as good of a job digitally. Either digital or optical will suffer some issues and field of view loss.
The following pictures show the lack of distortion in the 14mm and how a different lens looks in comparison.
14mm from my review on my blog. Notice the top and bottom red line are parallel, virtually no barrel/pincushion distortion.
The following is one from the Sony E mount 16-50mm without distortion correction applied, this lens is an extreme example:
Sony E mount 16-50mm with no correction applied at 16mm.
Either lens is going to have stretched subjects near the edge of the frame, they are both rectilinear lenses (the Sony not quite as much, it is slightly fisheye due to the distortion), but if you correct it, the stretching will occur.  If you ever de-fish a fisheye image, it will be just like a rectilinear image being stretched out at the edges.
Eric
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
57LowRider Senior Member • Posts: 3,766
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +10 more
jrk Senior Member • Posts: 1,853
Congratulations.  I took advantage of the recent Fuji sale to purchase the lens.  I had originally pre-ordered the 10-24, but after reading more and more about the 14, I cancelled the order for the 10-24 and got the 14 instead.  I'm glad I did!
 jrk's gear list:jrk's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Canon EOS 70D Fujifilm X-E2 Fujifilm X-T1 +12 more
