Dissapointing Sony A77 II High ISO performance
Started May 2, 2014 | Discussions
dr Ate Junior Member • Posts: 27
Hello
Please have a look here. High iso of new Sony A77 II looks like from version1. Sony, why ?
http://www.optyczne.pl/6962-news-_Sony_SLT-A77_II_-_przyk%C5%82adowe_zdj%C4%99cia.html
 dr Ate's gear list:dr Ate's gear list
Sony SLT-A55
Sony a77 II
VirtualMirage
VirtualMirage Veteran Member • Posts: 3,660
Re: Dissapointing Sony A77 II High ISO performance
6
What are you looking at to gather that and compared to what?
The shots you see are JPEG only on pre-production cameras. The shots are limited to the hands on time they had, so I don't see any competition shots of the same scenes to say what is better.
But looking at some of the ISO 1600, 3200, and 6400 shots I think they look pretty decent (the shot with the hanging peppers or vanilla beans). At 12,800 I can see it starting to muddy up, but it still isn't terrible if needed in a pinch for smaller sizes. I'm actually surprised as to how well the colors and dynamic range hold up. no color shifting either.
But of course, I am not a JPEG shooter. I'd be more interested in how the RAW files look.
The problems I see in these shots look a lot more to be the photographer than the camera.  But remember, they only got to use a demonstration model for a short time and were probably rushing to get some shots to publish.
 VirtualMirage's gear list:VirtualMirage's gear list
Sony RX100 Sony a77 II Tokina AT-X Pro 11-16mm f/2.8 DX Tamron SP AF 90mm F/2.8 Di Macro Tamron SP 70-200mm F/2.8 Di VC USD +18 more
J Birn Contributing Member • Posts: 770
Thanks for posting the link, but WTF are you disappointed about?
5
dr Ate wrote:
Hello
Those early images look awesome!
Seeing those images (from an early unit, obviously not final quality jpegs and no way to shoot raw and do proper raw processing in Lightroom or DXO yet...) makes it looks like the raw performance might be better than the original a77, even though it has the same sensor size and pixel density.
I have an a99, and use it up to 6400 ISO, because I've found the ISO6400 shots can look quite respectable with processing in Lightroom. (Going higher than 6400 could work too, but I usually avoid it and have 6400 as my max setting when I'm in auto ISO.)
I'm looking forwards to seeing more about the final image quality from the a77ii. I'm actually thinking about the possibility of selling my a99 and CZ24-70 f/2.8, and getting an a77ii and 16-50 f/2.8 instead, as a wait of getting a lighter, more portable, faster camera set-up that has wifi, a built-in flash, and better AF performance with an ability to AF and track things in more of the frame. Of course I'll wait to read full reviews before I'd pull the trigger on a decision like that, but the a77ii might be a good "upgrade" from the a99 in some respects.
Jeremy Birn
 J Birn's gear list:J Birn's gear list
Sony SLT-A99 Sony 50mm F1.4 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 70-300mm F4.5-5.6 G SSM +1 more
Tapper123
Tapper123 Senior Member • Posts: 1,511
Agreed. I can't imagine shooting JPEG only with a camera like this. I'm surprised some people do.
 Tapper123's gear list:Tapper123's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-F3 Olympus E-M5 II Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake +6 more
dr Ate OP Junior Member • Posts: 27
I hope Your'e right... I really wanted to purchased this new version, but (personally) I find those JPEGs not so tempting for example vs Oly E-M1. Maybe its the photographer, or maybe early firmware. Wait and see.
Sony SLT-A55
K E Hoffman
K E Hoffman Senior Member • Posts: 4,825
dr Ate wrote:
I hope Your'e right... I really wanted to purchased this new version, but (personally) I find those JPEGs not so tempting for example vs Oly E-M1. Maybe its the photographer, or maybe early Not
Looks to be an improvement over this
ISO 1600 from Oly E-M1
http://www.imaging-resource.com/PRODS/olympus-e-m1/FULLRES/YP1010039.HTM
Note the blotched mess on the hair on the arms of the nearest photographer..at ISO 1600?
Sony ISO 1600 clearly better than the camera you just listed as better... Only if you like feeding your detail to NR..
K.E.H. >> Shooting between raindrops in WA<<
Don't Panic!.. these are just opinions... go take some pictures..
 K E Hoffman's gear list:K E Hoffman's gear list
Canon EOS 450D Nikon 1 J1 Sony Alpha a6300 Sony 100mm F2.8 Macro Sony E 18-200mm F3.5-6.3 OSS +4 more
GingerSix
GingerSix Forum Member • Posts: 82
If the JPEGs are good enough, why shoot RAW? I'm more surprised that you you are surprised...
To the OP, I think ISO 1600 still looks decent, can't say it's same or better than the A77, I'm sure there will be side by side comparisons when the retail is out.
 GingerSix's gear list:GingerSix's gear list
Sony SLT-A77 Sony DT 35mm F1.8 SAM Sony DT 16-50mm F2.8 SSM +1 more
JimmyMelbourne Senior Member • Posts: 2,442
Generally speaking 1600 looks better than a77, 3200 things get too noisy for me. 1600 looks acceptable. That compares to 1000 - 1250 ISO which is as high as I go for acceptance on the a77. To me I *think* I am seeing about 1/3 to 1/2 stop improvement, maybe more on the lower side. But it is very difficult to compare this way and is really just an educated guess at this stage. ISO 800 looks quite clean on the a77ii from what I have seen so far. Cant wait to see raw file output comparison.
 JimmyMelbourne's gear list:JimmyMelbourne's gear list
Sony Alpha DSLR-A300 Sony SLT-A77 Sony SLT-A37 NEX-5T Sony Alpha 7 +20 more
Danny Williams Contributing Member • Posts: 835
Looking at the 1600 iso sample.....it's awful. Come on Sony, this isn't even competitive with other brands. Very disappointing to say the least.
 Danny Williams's gear list:Danny Williams's gear list
Tamron 15-30mm F2.8
TrojMacReady
TrojMacReady Veteran Member • Posts: 8,683
NR was turned off...
.. from what I can tell looking at the pictures and a lacking google translation of the original page.
From what I recall, the A77 does not offer a NR off setting and based on recent Sony cameras that do offer a NR off setting, RAW opened in Lightroom/ACR with NR turned off still looks better due to a lot less artifacting.
That being said, these still give a much better starting point than the same scenes posted by other early previewers that had NR turned on with a lot of smudging above ISO 400 as a result (way too much for my liking still).
Keeping all that in mind, I do see some potential.
VirtualMirage
10
When taking pictures with an old film camera, after you get your pictures developed, do you throw out the negatives?
For some JPEG may be fine and dandy, but I feel JPEG is starting to get a little long in the tooth.  If you are perfectly happy with the out of camera results, then they can be fine.  But if you need to make adjustments to them, you start to become limited.
JPEGs, by nature, are only limited to 8-bits per color channel.  That is only 256 shades of color per channel.  This camera is capable of shooting at 14-bits, which is 16,384 shades of color per channel.  This gives you smoother transitions in color without the risk of posterization, more accurate color, and more accurate tones.
While you might not be able to see the full advantage of 14-bit images on your current display, as technology continues to improve RAW files will be more future proof than JPEGs.  We will be able to see on our displays what that 14-bits gets you, RAW editors will be able to get better results out of the RAW files etc.  Meanwhile, JPEG will still be stuck with little to no room for improvement.
For those happy in the now and not concerned about the future, JPEGs are fine.  For the rest, RAW is still the go to source.
Just remember how JPEGs looked back in the 90s.  Now imagine your JPEGs taken today 20 years from now.  Will they hold up just as well as they did back then, or will they be showing their age (and not in a good way)?
While RAW isn't for everyone (I agree on that), I do feel it is time that the camera manufacturers look to a new format other than JPEG that is little more future ready.  JPEG2000 or JPEG XR are good candidates and attempts have been made to push them, but not much success has come from it.
K E Hoffman
You can't rationally tell that from early samples, there are no controls and no comparative examples to see how another camera would handle the scene.
Love how account that post less than a dozen times a year.. suddenly go active for pots like this..
philbot Contributing Member • Posts: 846
Since we know it has the same sensor as the A6000, SLT = 1/3 stop of light loss, so obviously whilst it's going to be 'worse', we know how much worse..
I was amazed how well my A77 held up once I understood it had a high ISO sensitivty.. I'd trade 1/3 stop of light for all the features anyday, but that's my personal choice, I don't feel I need to run to the other forums and start telling people that anything less than 12fps is 'terrible' or other such reciprocal actions..
vw671 Contributing Member • Posts: 536
1600 looks good enough for me. Submitted my pre-order:D
 vw671's gear list:vw671's gear list
Sony RX100 Sony SLT-A57 Sony a77 II Tamron SP 70-300mm F/4-5.6 Di USD Sony DT 16-50mm F2.8 SSM +2 more
Raven Falls Regular Member • Posts: 101
dr Ate wrote:
Sony, why ?
So certain Usual Suspects here can have something to rant, whine, and doomsay about until actual production samples come out?  (Not that they wouldn't have anyway, of course...)
 Raven Falls's gear list:Raven Falls's gear list
Konica Minolta Maxxum 5D Sony Alpha DSLR-A100 Sony SLT-A77 Sony DT 18-70mm F3.5-5.6 Sigma 10-20mm F4-5.6 EX DC HSM +5 more
Hey K E Hoffman,
Here is another portion of samples, I've searched a little bit. These look slightly better, isn't it ?
http://www.fotopolis.pl/index.php?n=18738&sony-a77-ii-zdjecia-przykladowe
Sony SLT-A55
Bacho Forum Member • Posts: 77
i dont see any iso improvemets over a77 I, i think it is the same sensor, disappointed!
 Bacho's gear list:Bacho's gear list
Sony Alpha 7
K E Hoffman
Hey K E Hoffman,
I am waiting for controlled tests of some kind  to judge. Since I shoot RAW I need to see RAW.
In the end its going to be the same or just a bit better than the A77.. There was a point I hoped for a full stop.. But guessing about a half.. which in reality I can easily deal with in Batch processing in LR.. so not even an issue.. the AF and stabilization improvements are more important.
sybersitizen Veteran Member • Posts: 5,843
philbot wrote:
Since we know it has the same sensor as the A6000...
I don't know that. Does it also have the same dedicated OSPDAF sensor elements left unused?
Even before this particular comment, the thread started off badly and has already gone off the deep end in a very short time.
The original A77 sensor wasn't gapless, so no it's not the same sensor.
http://www.sony.net/Products/di/en-gb/products/g2sw/feature.html?contentsTop=1
