a6000: which lens to buy (kit or 16-70)
Started May 2, 2014 | Questions
AKman
Junior MemberPosts: 31Gear list
May 2, 2014
I decided to get the a6000 to be my "carry everywhere" and travel camera. But I need to get a better understanding of the 2 lenses that I have options of.
The kit lens is a 16-50mm E-Mount Lens, and there is another, more expensive kit that has the Vario-Tessar T* E 16-70mm F4 ZA OSS Lens. And there is always the kit that has both.
So should I get the 16-50, 16-70 or both. What are the pros and cons of each?
This is what I tend to shoot, if that helps:
- HDR (mostly nature, buildings, etc.)
- Fast moving kids
- Street photography
- General life documentation
 AKman's gear list:AKman's gear list
Canon EOS 7D Canon EF-S 17-55mm f/2.8 IS USM Tamron SP AF 60mm F/2 Di II LD IF Macro Sigma 10-20mm F4-5.6 EX DC HSM ACDSee Pro (Mac) +2 more
Sony a6000
miro3
Senior MemberPosts: 2,326Gear list
Re: a6000: which lens to buy (kit or 16-70)
In reply to AKman, May 2, 2014
definitely 16-70 for the higher IQ
Hans von der Crone
Senior MemberPosts: 2,798Gear list
In reply to miro3, May 2, 2014
I own the 16-50 and also the Zeiss 24mm. Have also owned the 18-55 with my 5N (sold). Very much considering to get the 16-70 because I'm in the process of moving from SLR to the A6000 as my main camera system.
How much better is the 16-70 optically compared to the 16-50? Of course it'll be a lot better, but I wonder in what areas specifically. My 16-50 is only decently sharp in the center and the distortion and vignetting is well documented. Can't seem to find much info about the 16-70 though, let alone a direct comparison with the 16-50.
 Hans von der Crone's gear list:Hans von der Crone's gear list
Sony Cyber-shot DSC-RX100 III Sony a6000 Nikon D750 Sony E 16-50mm F3.5-5.6 PZ OSS Sony Vario-Tessar T* E 16-70mm F4 ZA OSS +4 more
CameraCarl
Veteran MemberPosts: 4,182
In reply to Hans von der Crone, May 2, 2014
The only on line reviews I have seen of the two lenses was on ephotozine, but they were tested at different times on two different bodies and many of the test images are not identical so it is difficult to compare scientifically.  On the photos of the conservatory building, it appears that the edge sharpness of the 16-70 is far superior to that of the 16-50 despite the bar graphs not indicating that great a difference.  If I were buying the A6000, I'd get the 16-70 without hesitation.
blue_skies
Senior MemberPosts: 9,371Gear list
- Fast moving kids
Currently, the discounted (US) price of the E1670 ($700) compares negative to the discounted pricing of the E1650 ($150) plus the E35 ($400).
I would get the E1650 plus the E35 for starters. It sounds silly, the but the E35 is a much nicer lens to use indoors and in low light.
Unless you shoot a lot at 60mm and f/4, the E1650 covers pretty much the same FOV, and perhaps you lose a stop (at longer FL), but you don't lose much in sharpness, especially if both zooms are used stopped down.
For the price delta, ($150), get a Gariz' case. Or apply it to the E50/OSS (or FE85/OSS when out).
Henry
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony Alpha 7 II Carl Zeiss Biogon T* 2/35 ZM +33 more
sabesh
Senior MemberPosts: 1,520Gear list
16-70mm is now available as a kit.
 sabesh's gear list:sabesh's gear list
Panasonic Lumix DMC-GM5 Sony Alpha 7R II Sony FE 55mm F1.8 Sony FE 24-70mm F4 OSS Sony FE 70-200 F4 +8 more
miro3
Re: 16-70mm is now available as a kit.
In reply to sabesh, May 2, 2014
sabesh wrote:
@ B&H
Sabesh
http://www.flickr.com/photos/sabesh/
also on adorama and Sony Store
Joachim Wulfers
Senior MemberPosts: 1,424Gear list
In reply to AKman, May 3, 2014
Today I shot a few samples with the A6000 and 16-50 kit lens. I bought it because of its size and also because I had seen some pretty good images.
To me it is worthwhile for the convenience of sticking it in a pocket and do some casual shooting.
Joachim
 Joachim Wulfers's gear list:Joachim Wulfers's gear list
Sony Alpha NEX-5N Sony a6000 Sony E 16mm F2.8 Pancake Sony E 18-55mm F3.5-5.6 OSS Sony E 50mm F1.8 OSS +9 more
123Mike
Senior MemberPosts: 4,643
In reply to Joachim Wulfers, May 3, 2014
These are scaled down images, which conceals the good or the bad of the lens.
123Mike
Size permitting, the 18-105 F/4 G lens is a nice choice, at around $600.
Joachim Wulfers
In reply to 123Mike, May 3, 2014
Of course man, what do you expect, a 24 MB picture? Read the post. It says casual shooting, not for pixel peepers.
Joachim
RonFrank
Senior MemberPosts: 2,128Gear list
General life documentation - so birth certificates, drivers licenses, that stuff?
Buy the kit lens and see if you like it. It is very compact and has good IQ assuming you are not a lens snob. It is not the best build quality and is a cheap lens. If you decide you hate it, sell it and you have some very limited options.
B&H is still running the 16-70mm special so that is an option as $700 is as reasonable as you will get for the 16-70mm f4. You can get all three for $1500 if you want the option of the compact kit lens on some occasions.
 RonFrank's gear list:RonFrank's gear list
Nikon D200 Nikon D300S Nikon D1X Sony a6000 Nikon AF-Nikkor 80-200mm f/2.8D ED +7 more
José B
Forum ProPosts: 18,319Gear list
Zeiss 16-70/4 for travel, events and portraits (pics)
Once I got the Zeiss, I don't bother with my kit lens anymore. It is faster to focus to begin with plus it is longer for portraits. Not to mention the awesome color, contrast and bokeh of this lens.
Good luck in whatever decision you make.
José
 José B's gear list:José B's gear list
Sony Alpha NEX-6 Canon EOS 5D Mark II Canon EOS-1D Mark III Sony a6000 Canon EOS 5DS +11 more
RonFrank
In reply to Hans von der Crone, May 3, 2014
There are very few direct comparisons with the 16-50mm. Here is one of many reviews I find with a quick web search. The 16-70mm is overpriced like most Zeiss, made in Thailand of all the weird Zeiss locations, is made of plastic, and grows. Not the qualities of a $1000 lens but besides me making fun of it, it seems like a good lens despite the oddness.
http://kurtmunger.com/sony_zeiss_16_70mm_f_4id354.html
There are a bunch of reviews most positive like 4 of 5 star.  The kit zoom gets anywhere from 1 of 5 stars to 3.5 of 5 stars.  The reviewers all pan the 16-50mm for having an uncorrected RAW mode even if ALL m4/3 lenses need correction as well as Zeiss.  A lesson to lens makers, hide your RAW native images!
CameraCarl
In reply to blue_skies, May 3, 2014
Henry
So where can you get a new 16-70 which is not part of a kit for $700?  I've been shopping for months and have not found a new one in the USA for less than the list price of $998.
123Mike
I would not expect someone claiming a lens is good using pictures that don't back your claim.
captura
Forum ProPosts: 21,099Gear list
Re: Zeiss 16-70/4 for travel, events and portraits (pics)
In reply to José B, May 3, 2014
José
Nice shooting!
José B
In reply to captura, May 3, 2014
José
Nice shooting!
thanks Steve.
john-photoguy
Regular MemberPosts: 469Gear list
I have been using the Sony Emount cameras since I picked up a NEX3 several years ago.  quickly purchased the 16-70 when it came available, and LOVE it.  Have the 18-55, and it works well.  So when I went to get the a6000 I figured I would just get the body, but the body wasn't available.  So I picked it up with the 16-50 and it is a fun little lens.  Wow distortion in the few photos I have taken, but easily corrected so that sholdn't be a problem.  But it is so cute, and small and light I figure it will just stay on the camera.  Would I trade it for the 16-70, No.  Am I glad I purchased with the lens,  Yeah.  Would I purchase without the body,  No.
So My take is,  Get it with the kit lens.  If it is enough, great.  If not spring for the 16-70 or the 18-105 depending on the work you do.  But I bet you want to keep it and not get rid of it at the end of the day,  It is just so Cute!  and it does work well.
Good Luck in your search!
Let just all take more photographs!
 john-photoguy's gear list:john-photoguy's gear list
Nikon D300S Nikon D200 Sony Alpha NEX-3 Nikon D5000 Sony Alpha 7 +19 more
Joachim Wulfers
We had a similar discussion once before regarding the SEL18200. Re-read my post and then get back to me.
Joachim
