Process my RAW!
Started Apr 28, 2014 | Discussions
Dorkington
Regular MemberPosts: 355Gear list
Re: Process my RAW!
In reply to Sal Baker, Apr 30, 2014
Sal Baker wrote:
Another shot at it. Iridient and Nik
Sal
Excellent.
 Dorkington's gear list:Dorkington's gear list
Fujifilm X-E2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +2 more
johanPO
New MemberPosts: 13Gear list
Re: Process my RAW!
In reply to Dorkington, Apr 30, 2014
A quick lightroom edit
 johanPO's gear list:johanPO's gear list
Nikon D300S Panasonic Lumix DMC-GF1 Fujifilm X-Pro1 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II +4 more
Charles2
Veteran MemberPosts: 3,091
Re: Process my RAW!
In reply to hellocrowley, Apr 30, 2014
I found that sharpening of the lightning made the sky darker than desired. So I laid the sharpened version over the predecessor image and made a composite by lightening (Picture Window Pro working on a TIFF from Fuji Raw File Converter).
_Michel_
Veteran MemberPosts: 4,492Gear list
Changing a bit the mood
In reply to hellocrowley, May 1, 2014
See full size for best result
All the best, Michel
 _Michel_'s gear list:_Michel_'s gear list
Panasonic Lumix DMC-ZS40 (TZ60) Nikon Coolpix P900 Konica Minolta Maxxum 7D
hamed
Forum MemberPosts: 58Gear list
processed in Photomatix Pro and sharpened in lr5
In reply to ChicagoRob, May 1, 2014
Hope you'll like it
 hamed's gear list:hamed's gear list
Fujifilm X100S
NZ Scott
Senior MemberPosts: 4,028Gear list
Can you legally copyright somebody else's photo?
In reply to _Michel_, May 1, 2014
Why did you put a copyright mark on somebody else's photo?
S
My Flickr stream:
http://www.flickr.com/photos/scottkmacleod/
My kit: E-P3, 12/2.0, 17/1.8, 45/1.8, 60/2.8 Macro, 7.5 Fisheye, 12-35 f2.8, 14-42 IIR, 40-150 ED, 75-300 II
 NZ Scott's gear list:NZ Scott's gear list
Olympus PEN E-P3 Panasonic Lumix DMC-GM5 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G II Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +13 more
hamed
Re: Hope you'll like it.
In reply to Just a Photographer, May 1, 2014
Just a Photographer wrote:
Done in Capture One Pro 7
PS. there is some serious dust on the left side of your sensor. Two large spots, which needs to be wet cleaned. I'll cleaned it of on the picture, but it was pretty visible.
sorry i post my processed photo here
Fujifilm X100S
hamed
Fujifilm X100S
StevenScholten
Regular MemberPosts: 132Gear list
Re: with Dcraw / Photivo
In reply to Sebastien Guyader, May 1, 2014
oginal looks sharper then this downgraded JPG
 StevenScholten's gear list:StevenScholten's gear list
Canon EOS 5D Mark III Fujifilm X-T1 Canon EF 50mm f/1.4 USM Canon EF 70-200mm f/2.8L IS II USM Fujifilm XF 35mm F1.4 R +6 more
jl_smith
Veteran MemberPosts: 3,612Gear list
LR should be just fine for this shot.
Too many people focus on sharpness for every photo. This photo has nothing to do with sharpness.
JL Smith
www.smithclicks.com
www.flickr.com/photos/jl_smith
 jl_smith's gear list:jl_smith's gear list
Sony Alpha 7 II Samyang 85mm F1.4 Aspherical IF Sony FE 55mm F1.8 Sony FE 28mm F2 Sony FE 24-240mm F3.5-6.3 OSS
_Michel_
Re: Can you legally copyright somebody else's photo?
In reply to NZ Scott, May 1, 2014
Wanted to show that it is not my pict but a pict by hellocrowley. Should have wrote "pict by hellocrowley"probably
NZ Scott
Oh, it's HIS name. I thought you stuck your own one on there.
My bad.
S
My Flickr stream:
bowportes
Senior MemberPosts: 2,229Gear list
Re: Process my RAW!
Here's one from Silkypix Develop Studio Pro 6:
Silkypix. No additional post-processing.
And here's another... also just from Silkypix, but with additional Silkypix sharpening applied.
Silkypix -- with additional Silkypix sharpening
 bowportes's gear list:bowportes's gear list
Panasonic Lumix DMC-G5 Fujifilm X-M1 Fujifilm X-T1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +9 more
Ryanmoe
Junior MemberPosts: 28
Re: Process my RAW!
In reply to bowportes, May 1, 2014
PhotoNinja only
bowportes
Re: Process my RAW!
In reply to Ryanmoe, May 1, 2014
Ryanmoe wrote:
PhotoNinja only
I'm not saying that Silkypix is better than PN, but I much prefer my Silkypix rendering to your photo ninja one. To my tastes, lifting the shadows as much as you do detracts from the drama of the lightening and also produces an unnatural, overprocessed look. There are over-sharpening artifacts in the sky on your rendering, and also in the buildings on the ground. And the over-sharpening produces no additional details. Take a look at the fancy building to the right of the bright yellow light in both your PN image and my second SP image. Mine provides greater detail without the obvious processing artifacts.
I think you could do much better with PN on this one if you'd turn off the "smart lighting," which I imagine was imposed to even out the photo. For an image like this, you want to preserve the stark contrast between darker and lighter areas rather than flattening them.
My opinion, anyway.
bowportes
Re: Process my RAW!
Here's one a bit more like your PN rendering from Silkypix.  You can certainly see more details in the city, but I like the earlier one I posted better.
Silkypix - alternate rendering
bowportes
Re: Process my RAW!
And a final Silkypix one, different color rendering:
last silkypix -- still too light, in my opinion
bowportes
Re: Process my RAW!
In reply to johanPO, May 1, 2014
I really like your colors. Unfortunately, your sharpening yields double-lines and unnatural outlines on most everything in the photo.
bowportes
Re: Process my RAW!
In reply to Sal Baker, May 1, 2014
Sal
difficult to assess when you've reduced the size of the image...
Nice colors.
bowportes
Re: Process my RAW!
bowportes wrote:
Sal
Nice colors.
This is what I get by reducing the Silkypix image size by 50% in Irfanview:
Silkypix is not bad. Yours is better.  It would take a lot of fiddling in SP to improve it further.
