Process my RAW!
Started Apr 28, 2014 | Discussions
ChicagoRob
ChicagoRob Regular Member • Posts: 196
Re: Hope you'll like it.
Just a Photographer wrote:
Done in Capture One Pro 7
PS. there is some serious dust on the left side of your sensor. Two large spots, which needs to be wet cleaned.  I'll cleaned it of on the picture, but it was pretty visible.
I do like it. Detail rendering seems very good, but I do see some artefacting.
(unknown member) Veteran Member • Posts: 3,441
Re: Process my RAW!
My Try with DCRAW...
The embedded JPEG in the RAW File. (Missing a Part on the right from the Lightning)
Camera WB.
Full Photo WB.
View the EXIF-Data for the full DRCAW Parameter...
MrChristopher
MrChristopher Senior Member • Posts: 1,288
Re: Process my RAW!
I seem to be struggling with LR5 as well.  Here's what I came up with... I feel like something's off but I can't quite put my finger on it?  Is it that watercolor effect that everyone else is bitching about maybe?  Hm...
Alex
OMG it's the ghost of the ISO 6400 waxy skin haunting your Fuji!
http://chriscurnutt.tumblr.com/
 MrChristopher's gear list:MrChristopher's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 56mm F1.2 R +1 more
Sal Baker Veteran Member • Posts: 9,445
Re: Process my RAW!
Another shot at it.  Iridient and Nik
Sal
 Sal Baker's gear list:Sal Baker's gear list
Ricoh GR Canon EOS 5D Mark II Fujifilm X-E2 Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM +7 more
Ysarex
Ysarex Senior Member • Posts: 1,247
Re: Process my RAW!
PhotoNinja & Photoshop
Charuteiro
Charuteiro Contributing Member • Posts: 714
Re: Process my RAW!
RFC EV -4, -3, -2, -1, 0 + Oloneo PhotoEngine Stack
Looks too dark posted here, but a faux HDR may provide an alternative.
(unknown member) Senior Member • Posts: 1,321
All Rendering Platforms Are Dommed
The diffraction at f 13 limits any attempt to improve this image.
A ND filter would be useful for this sort of work.
 wchutt's gear list:wchutt's gear list
Fujifilm X-Pro1 Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +20 more
Robert Garcia NYC Senior Member • Posts: 1,761
Great image but sensor needs cleaning.
Capture one:
Chrisada Regular Member • Posts: 194
Re: Process my RAW!
Sal
You brought out lots more of the lightnings with this one, Sal. Very nice overall.
 Chrisada's gear list:Chrisada's gear list
Fujifilm X-T1 Panasonic Lumix DMC-GH4 Fujifilm XF 18mm F2 R Panasonic 12-35mm F2.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +4 more
Keit ll Senior Member • Posts: 3,703
My try
Not too sure about reducing the blue sky ?
LR 5.4
C Frank Junior Member • Posts: 41
Re: Process my RAW!
This looks very nice.  I like the clouds and how straight the buildings are.
KennyXYZ
KennyXYZ Regular Member • Posts: 257
Re: Process my RAW!
I used SilkyPics and ACDSee Pro 7.
 KennyXYZ's gear list:KennyXYZ's gear list
Fujifilm X-E2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 10-24mm F4 R OIS
UfoPeople New Member • Posts: 5
Re: Process my RAW!
Iridient developer
RPP + K64 Profile
 UfoPeople's gear list:UfoPeople's gear list
Fujifilm X-E1 Fujifilm X-E2
DaveHutch Senior Member • Posts: 1,975
Re: Process my RAW!
Did a colour balance change to Daylight/Flash and a distortion correction (not quite a full upright correction as I wanted to keep as much image as possible)
Also a couple of graduated filters: One for the sky exposure and one for the buildings colour balance
LR 5.3 (I haven't managed to get my work Mac updated to 5.4 quite yet)
Lovely shot though, well done!
I can only help one person each day...
...and today is not your day!
(tomorrow doesn't look good either!)
 DaveHutch's gear list:DaveHutch's gear list
Fujifilm X-T1 Canon PowerShot G15 Fujifilm X70 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +1 more
KariP
KariP Veteran Member • Posts: 4,110
For the accurate colors - AccuRaw
If you really need a well controlled image - there is also AccuRaw
A rather slow tool - but the results are what they say - accurate
AccuRaw - just very simple adjustments - capable of more than this
Kari
SLR photography started in 1968, Canon DSLR cameras, lenses and now also a Fuji X-E1
60.21 N 24.86 E
 KariP's gear list:KariP's gear list
Canon PowerShot G12 Canon PowerShot G1 X Canon EOS 7D Fujifilm X-E1 Fujifilm X-T1 +11 more
NZ Scott
NZ Scott Senior Member • Posts: 4,102
Photoshop CS6 + detailed account of processing
hellocrowley wrote:
I used Adobe Camera Raw, in Photoshop CS6.
I performed the following actions:
1) Spot Removal tool: removed some spots from upper left.
2) Lens Corrections tab: Vertical -25
3) Crop tool
4) Basic tab: Shadows +86, Clarity +19, Vibrance +28
5) Detail tab: Sharpening: Amount 58, Radius 1.0, Detail 36, Masking 40; Noise Reduction: Luminance 20, Luminance Detail 50, Colour 25, Colour Detail 50
6) Straighten tool
The result:
The original:
My Flickr stream:
http://www.flickr.com/photos/scottkmacleod/
My kit: E-P3, 12/2.0, 17/1.8, 45/1.8, 60/2.8 Macro, 7.5 Fisheye, 12-35 f2.8, 14-42 IIR, 40-150 ED, 75-300 II
 NZ Scott's gear list:NZ Scott's gear list
Olympus PEN E-P3 Panasonic Lumix DMC-GM5 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G II Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +13 more
NZ Scott
Second attempt
Hmm. I had another crack at it to tame the blown-out areas around the lightning on the right-hand side. I did this by pulling back Whites and Highlights in the Basic tab. I also tweaked the White Balance just a touch:
My Flickr stream:
Bob Gates
Bob Gates Senior Member • Posts: 1,479
Re: Process my RAW!
LR 5.4
 Bob Gates's gear list:Bob Gates's gear list
Fujifilm X-T1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +2 more
Techbum Junior Member • Posts: 41
Re: Process my RAW!
My take using Intensify Pro and Snapheal Pro
 Techbum's gear list:Techbum's gear list
Fujifilm FinePix X100 Nikon D610 Fujifilm X-T1
DanielBme
DanielBme Contributing Member • Posts: 677
Re: Process my RAW!
Thought I would give it a shot too!
Processed in SP and then LR 4 applying a VSCO film emulation.
'Not all those who wander are lost.'
- J.R.R Tolkein
