Process my RAW!
Started Apr 28, 2014 | Discussions
hellocrowley
hellocrowley Senior Member • Posts: 1,269
Process my RAW!
7
I recently got this pic of a very close lightning bolt in front of my apartment. Thinking of printing it big, but I can't seem to get a quality file out of Lightroom, which is the only RAW developer I have.
Can anyone with a superior RAW developer take a shot at this? Thanks, it would also help me decide which program to buy.
Link to RAW: https://drive.google.com/file/d/0B5JGrbRCHp5KY25WcjY4dnpidlU/edit?usp=sharing
DaveHutch
DaveHutch Senior Member • Posts: 1,968
Re: Process my RAW!
What are you looking for in terms of "quality" exactly?
Also, how do we get hold of the RAW file?
I can only help one person each day...
...and today is not your day!
(tomorrow doesn't look good either!)
 DaveHutch's gear list:DaveHutch's gear list
Fujifilm X-T1 Canon PowerShot G15 Fujifilm X70 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +1 more
Al Valentino
Al Valentino Senior Member • Posts: 4,579
Re: Process my RAW!
Fantastic capture. Of course the sharpness starts with the quality of the capture but I would give a Photo Ninja a try. The two week trial lets you save results, no watermark. Here's a secret, if you have the trial code it will expire in 2 weeks but if you do not close the program (or your computer) it will keep letting you save your work thus extending the trial.  But without a trial license you can still play with the program but you cannot save your work. I did that few two weeks before getting a trial license giving me more time to understand the nuances.
PN also plays well with adobe and lightroom as they have free plugins to play nicely with both to make the work flow remain smooth.
Fuji Silver XE1 w/14, 35, 18-55, 55-200, Rokinon 8mm Fisheye & Tamron 90mm f/2.8 Macro
 Al Valentino's gear list:Al Valentino's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +6 more
hellocrowley
hellocrowley OP Senior Member • Posts: 1,269
Re: Process my RAW!
Sorry I knew I missed something, edited the post with the link. I'm trying to get more sharpness without the usual sharpening artifacts and less smearing. Also Lightroom renders posterisation in the gradient of the sky.
Thanks Al Valentino, I'll give PN a try. I'm quite clueless at post processing so I'd like see someone skillful show me what could be done to this file.
Al Valentino
Photo Ninja
Below is the shot with Photo Ninja, close to the default. Note that it does not have spot removal or built-in lens corrections. I could have fixed both, adjusting distortion in PN and spots in Photoshop, but wanted to show the conversion. I did not obsess over getting it perfect. Sharpening was the default settings
Photo Ninja
KariP
KariP Veteran Member • Posts: 4,059
Re: Process my RAW! - i tried Aperture
I think the original  file is good enough for quite big prints !
This is my way to use your nice file - just 50%
Just some highlight saving , some contrast, modest edge sharpening ... etc
It can look great in a 1mx1,5m size
Kari
SLR photography started in 1968, Canon DSLR cameras, lenses and now also a Fuji X-E1
60.21 N 24.86 E
 KariP's gear list:KariP's gear list
Canon PowerShot G12 Canon PowerShot G1 X Canon EOS 7D Fujifilm X-E1 Fujifilm X-T1 +11 more
Al Valentino
Distortion Correction
Just a quick but important note about distortion correction. The adobe versions above have it applied, the Photo Ninja version does not (I could have done it manually).
Applying the lens profile essentially stretches the image back to compensate for the distortion, in this case barrel distortion at 18mm. Once the image is stretched it is then cropped to be rectangular.
So the difference above is that my PN version has a curved horizon, a result of the lens, but is not stretched (always bad for corner sharpness) and cropped. The result is my conversion includes the large vertical lightening bolt on the right!!! Adobe crops it out
57LowRider
57LowRider Senior Member • Posts: 3,727
Re: Process my RAW!
LR5.4, made a hash of one of the spots :/
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +10 more
Sebastien Guyader
Sebastien Guyader Regular Member • Posts: 266
with Dcraw / Photivo
Trying to respect most of the color tone from your own version:
- dcraw 9.20 to convert the RAF file to 16-bit TIFF
- Photivo to process the Tiff file (sligthly tuning for color tone, brightness, chromatic aberration, lens distorsion, local contrast, sharpening)
dcraw + Photivo
 Sebastien Guyader's gear list:Sebastien Guyader's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Gimp +2 more
BlueJakester
BlueJakester Senior Member • Posts: 2,079
Re: Process my RAW!
best viewed full screen
Tack007
Tack007 New Member • Posts: 23
Re: Process my RAW! Apple Aperture
Processed in Aperture, removed distorsion in PS, removed spots in aperture and applied colors good to my eye, but really it is subjective to me
Tack007
Printed A3+ and it looks good to me
Charles2
Charles2 Veteran Member • Posts: 3,315
Re: Process my RAW!
The camera JPG is pretty good. If you want to sharpen for a print, you can apply enough just to start making halos on the monitor; the print will come out great.
This shot will benefit from sharpening by area -- more on the buildings, very little needed on the lightning.
For the raw, I would begin with Fuji Raw File Converter. Start from "Super Neutral," reduce exposure while watching the histogram at the highlight end. Export a TIFF file. My post processing program is Picture Window Pro. It has excellent sharpening tools, and you can get the sky color you want with its Color Correction tool.
Gloomy1
Gloomy1 Forum Member • Posts: 96
ACR despite the "popular" opinion that it is poor with X series.
Tried to remove the chromatic aberation at the corners and sharpened the file a lot, but with the sky masked and noise reduction in the sky. Trying to darken the sky produces lots of banding so I found it difficult to remove the flare caused by bright lightning flash. I will try Capture 1 later to see if it is any better.
Ken
Just a Photographer
Just a Photographer Senior Member • Posts: 1,368
Hope you'll like it.
Done in Capture One Pro 7
PS. there is some serious dust on the left side of your sensor. Two large spots, which needs to be wet cleaned.  I'll cleaned it of on the picture, but it was pretty visible.
 Just a Photographer's gear list:Just a Photographer's gear list
Nikon D4 Nikon D800E Fujifilm X-T1 Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +9 more
KVI08106
KVI08106 Forum Member • Posts: 72
Re: Process my RAW!
Two Caveats: One, I really have no idea how to process raw. I'm totally new at it. Two, I'm limited with the Silkypix EX that came with the camera.
Here's my attempt anyway
Astia film mode gave it the cyan blue accent around the main flash.
 KVI08106's gear list:KVI08106's gear list
Fujifilm X-E2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
Chris Dodkin
Chris Dodkin MOD Veteran Member • Posts: 6,715
Quick Edit
ACR 8.4, PS CC, NIK Suite
I did correct for perspective distortion, and nuke most of the dust bunnies
http://f-sunny.com
The future is just a click away...
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm FinePix X100 Canon EOS-1D Canon EOS-1D Mark II Canon EOS 5D Mark II Canon EOS 30D +34 more
Joe Brush
Joe Brush Contributing Member • Posts: 961
Oloneo PhotoEngine...
This is a great thread! I'm enjoying seeing all the different versions.
Here's a quick attempt using Oloneo PhotoEngine. Exported as jpeg then some spots removed in Picasa.
Regards,  Joe.
alextardif
alextardif Contributing Member • Posts: 937
Re: Process my RAW!
20
I seem to be struggling with LR5 as well.  Here's what I came up with... I feel like something's off but I can't quite put my finger on it?  Is it that watercolor effect that everyone else is bitching about maybe?  Hm...
Alex
 alextardif's gear list:alextardif's gear list
Sony FE 55mm F1.8 Sony FE 35mm F1.4 Sony Cyber-shot DSC-RX100 IV Sony Cyber-shot DSC-RX10 II Sony Alpha 7R II +10 more
b0k3h
b0k3h Regular Member • Posts: 368
Re: Process my RAW!
you shall not snap!
Alex
