Green Heron Eyeball...60-250+1.7AFA
Started Apr 28, 2014 | Discussions
johnat60 Regular Member • Posts: 404
 johnat60's gear list:johnat60's gear list
Pentax K-5 +1 more
Petroglyph
Petroglyph Senior Member • Posts: 4,977
Re: Green Heron Eyeball...60-250+1.7AFA
Nice detail!  Does the f-stop recorded in the exif get automatically converted when using the converter or is the f-stop reported what is set on the lens.  So the 60-250 becomes a f/6.3 as reported on the top lcd/viewfinder or it still says f/4?
 Petroglyph's gear list:Petroglyph's gear list
Sony Alpha 7R II Pentax K-1 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 43mm F1.9 Limited +5 more
leopold Forum Pro • Posts: 14,029
Nice shots, i like those Herons, beautiful birds.
 leopold's gear list:leopold's gear list
Canon EOS 7D Fujifilm X-E1 Canon EF 400mm f/5.6L USM Canon EF 70-200mm f/4.0L USM Fujifilm XF 14mm F2.8 R +3 more
johnat60 OP Regular Member • Posts: 404
Actually the viewfinder will say f/6.7 if you open it up to maximum.
Pentax K-5 +1 more
PvC001 Contributing Member • Posts: 577
Very nice sharp shots.
Philip
 PvC001's gear list:PvC001's gear list
Pentax Q Pentax K-5 IIs Pentax K-3 Pentax K-3 II Pentax K-1 +20 more
Petroglyph
Thank you.  So you had it stopped down, er ummm (steam coming out ears) 1/6 stop at f/7.1 as reported in exif?  That tells me the 1.7 will cost about 1 1/2 stops instead of 1 2/3.
