Posterization
Started Apr 27, 2014 | Discussions
Sergey_Green
Sergey_Green Veteran Member • Posts: 8,894
Posterization
Hi all,
Does anyone see posterization effect in this image (left of the flower, about half way down gradient). Sometimes I start noticing it when I do something to the image, with this particular image I see it in the CaptureNX already, before I even save it.
I wonder, does this have to do with the monitor's gamut limitation, color profile, or something else. If many of you do not see it, then it is my local hardware related issue (perhaps I need a newer monitor).  Else .. I would not even know.
- sergey
 Sergey_Green's gear list:Sergey_Green's gear list
Samsung Galaxy Note 10.1
jean bernier Veteran Member • Posts: 3,166
Re: Posterization
Was this captured in RAW ? I assume yes, since you use NX2
Did you use adjustments, or is this a straight conversion ? posting a picture here shows the posterization, no surprise, when you drop from 12 or 14 bits to jpg 8 bits......yes I see it, but it is mild. I've seen mild posterization of my own pictures disappear once printed.
Jean Bernier
All photographs are only more or less credible illusions
Sergey_Green
Sergey_Green OP Veteran Member • Posts: 8,894
Thx
Yes, it is a RAW file.
I only opened it, and I already see it.
Not a good news. Could hardware affect conversion you think? I mean, if I see it by merely opening the file, then so it will be saved.
Jean Bernier
- sergey
hendrikm2 Regular Member • Posts: 206
Re: Thx
- sergey
The most probable culprit is your monitor or your monitor profile.
Hardware won´t affect the data of your image, but the data which is shown to you. So you are save, just opening and saving a file won´t change anything*
* Before the nitpickers chime in:Yes, I´m aware that a jpg would be changed and mybe even a nef file, but this is unrelated to the hardware of a computer, which is the posters fear
Sergey_Green
Re: Thx
So that means you do not see that rough gradient I am looking at? Only those who have deficient monitors are able to see it?
- sergey
michaeladawson Veteran Member • Posts: 9,307
Re: Thx
Yes, I see it in the jpg you posted here.  But that is not a good test since the photo has already been processed by CNX2 in order to save the jpg.
Since I can see it in the jpg there is some issue with the way it is being processed in CNX2.  It could be improper profile conversion but that is a guess.  I suspect those green colors are out of gamut for the profile and that is causing posterization.  But that too is a guess.  Your monitor and associated monitor profile may still be an issue for your own viewing of the image but it shouldn't affect the jpeg you post.
Best thing would be for you to post a RAW file so others can take a look.
- sergey
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Panasonic Lumix DMC-LX3 Nikon D200 Nikon D4 Nikon D800 Nikon D800E +21 more
Sergey_Green
Thanks Mike
It is almost 40MB, where could I post it?
- sergey
Re: Thanks Mike
- sergey
The easiest thing is to use Dropbox.  You put the file out there and then share a link to it.
Mike Dawson
Sergey_Green
Re: Thanks Mike
- sergey
Ok, I think this is it,
https://www.dropbox.com/s/emkc0gw6uzhhalx/DSC_0858.NEF
Thanks Mike,
- sergey
LMCasey Contributing Member • Posts: 692
Re: Posterization
No, I don't see it.
 LMCasey's gear list:LMCasey's gear list
Canon EOS 5D Canon EOS 350D Canon EOS 400D Nikon D800 Canon EF 35mm f/1.4L USM +16 more
Sergey_Green
Really?
LMCasey wrote:
No, I don't see it.
So you have good (I mean better) monitor / hardware? I wonder what it is that makes me see it.
- sergey
Re: Thanks Mike
- sergey
Thanks Mike,
- sergey
OK, I opened up your raw file using both CNX2 and with Photoshop CC. I did not really see any posterization with either editor when first opened.
In Photoshop I played around just a little bit with large exposure changes and you can force posterization of those dark green shadow areas.  But that required me to do large histogram moves.  I have uploaded both of the jpg files to my Dropbox area.
Here is the CNX2 version. Opened in CNX2 with zero adjustments. Then moved to Adobe Photoshop where it was converted to sRGB, 8 bits, and saved as a quality 12 jpg.
https://dl.dropboxusercontent.com/u/10447490/DSC_0858_CNX2.jpg
Here is the Photoshop CC version. Opened in ACR using the Camera Neutral profile. Neutral (linear) tone curve, no sharpening or noise reduction. Inside PS converted to sRGB, 8 bits, saved as quality 12 jpg.
https://dl.dropboxusercontent.com/u/10447490/DSC_0858_Photoshop.jpg
Mike Dawson
InTheMist
InTheMist Senior Member • Posts: 3,077
I see it
I do see it, but only when small on the screen.  When I zoom, it's gone.
It could also be because my iMac (calibrated) really only does sRGB well.
It's more important how an image looks as a thumbnail than how it looks at 100%.
http://inthemistphoto.com
 InTheMist's gear list:InTheMist's gear list
Leica M Monochrom (Typ 246) Leica M-Monochrom Nikon 1 AW1 Nikon Df Nikon D810 +18 more
Simon Garrett Veteran Member • Posts: 4,924
Re: Really?
Sergey_Green wrote:
LMCasey wrote:
No, I don't see it.
Is your monitor calibrated/profiled (e.g. with a ColorMunki, Spyder etc)?
If not, I recommend you do so.  I use ColorMunki Display because it came out best in the reviews I read of cheaper colorimiter.
If so, try recalibrating.  A poor calibration can result in posterisation.
Simon
 Simon Garrett's gear list:Simon Garrett's gear list
Nikon D800
JJ10 Senior Member • Posts: 1,013
Re: I see it
I got the same results as Mike, only showed up after strong manipulation in NX2.
clarnibass Senior Member • Posts: 1,846
Re: Posterization
If I look at the small photo in the actual post, it is barely there, almost impossible to see. I doubt I would notice unless you told me.
If I click on the photo and look at it full screen in the DPR viewer, it is more or less the same, just barely there.
If I click on 1:1 100% in the DPR viewer, it's still the same, barely there.
If I click to view the original, where DPR will open the file in a new tab, as opposed to show it in its viewer, then look at it full screen, it is much more obvious.
If then I enlarge to look at the 100% size photo in the new tab, it is even more obvious.
Obviously the DPR viewer does something that makes this less obvious. I've seen and posted before about how the DPR viewer changed photos in some ways, generally for the worse. In this case I doubt the new tab photo is worse, causing the issue. I am guessing that whatever the DPR viewer does to change photos for the wosre in this case also happens to remove some of this issue.
I also downloaded the NEF and there is no issue there at all.
Jack Hogan Veteran Member • Posts: 5,153
Re: Posterization
Sergey_Green wrote:
Hi all,
I don't see it in the NEF (both sRGB and aRGB in CNX2, calibrated/profiled U2410).
I see what could be posterization (possibly due to Jpeg artifacts?) on the Jpeg you posted in Chrome.
Jack
Sergey_Green
Re: Thanks Mike
I will look at those once I get home. I just opened NEF on my work computer and I see gradient looks rather smooth.
So this is only the monitor I should be singling out for now?
- sergey
Sergey_Green
Thank Jack
Jack Hogan wrote:
Sergey_Green wrote:
Hi all,
It is possible. My first thought was if these were the files the camera produces.
- sergey
Sergey_Green
thx
This is something different, I have been seeing this also. What bothers me the most is the limitation in producing smooth gradients regardless of the viewer. I have several of those frames from winter, where the moment I darken the sky (just barely) I start seeing the gradients breaking down. It's like there is no way around it.
I wonder if different image editors will produce different results in that area. Like PS vs LR, or some other RAW processors. Have you tried to save it to TIFF, see what happens?
- sergey
