K3 or K5 IIs as second body having already a K5IIs?
Started Apr 27, 2014 | Discussions
joaquim hierro1
Junior MemberPosts: 39
Apr 27, 2014
After being stolen half of my gear, with a K5 included I only kept one body K5IIs and I need to buy a second body.  I'm hesitating between buying a second K5IIs or the new K3.
I would appreciate some thoughts about this choice.
Thanks and regards
Joaquim
Pentax K-5 Pentax K-5 IIs
brecklundin
Senior MemberPosts: 1,995Gear list
Re: K3 or K5 IIs as second body having already a K5IIs?
In reply to joaquim hierro1, Apr 27, 2014
Thanks and regards
Joaquim
in case it matters to you the button and menu layouts are different between the K3 and the IIs.
If you read the review here and over at http://www.imaging-resource.com/MFR1.HTM?view=Pentax_reviews you'll find some good comparisons to augment the hands-on observations you get here.
There are lots of reasons to go either way in your idea.  I decided on a IIs over a K3 for now and maybe a K3 at the end of the year when the price might drop a bit, or with my luck the price will increase.    But I do have a need of a larger pixel count for needing to do some 30x20 printing.  The 24MP sensor will need less upsizing.  Still I know the IIs will be likely accept the enlargement better than the K5/K5II because of the lack of the AA filter.  So I decided to go with the IIs unless I find an extra $400 in the mail.  Worst case is I end up swapping it for a IIs.
Younes B
Contributing MemberPosts: 741Gear list
In reply to brecklundin, Apr 27, 2014
I have printed large than 20x30 with the files from the K10, with no loss in detail.
So I believe the files from the k5IIs woul d be sufficient.
The previous poster's remarks re button layout are very valid. If you intend to use them side by side with different lenses mounted, it helps a lot to have same layout...
 Younes B's gear list:Younes B's gear list
Pentax K10D Pentax K-30 Pentax K-5 II Pentax K-5 IIs Pentax smc DA 15mm F4 ED AL Limited +6 more
brecklundin
In reply to Younes B, Apr 27, 2014
oh, for sure.  It's just nice to have a bit more headroom.
audiobomber
Veteran MemberPosts: 5,187Gear list
In reply to joaquim hierro1, Apr 29, 2014
The main difference is in auto-focus.
  • Prior to the K-3, the size of the Pentax AF points has been a constant complaint. The K-3 allows pinpoint accuracy in AF-S due to smaller points.
  • AF-C is improved immensely. The K-3 uses colour to track the subject, and 27 vs. 11 points for closer tracking. AF Hold control is an important feature, not available on previous Pentax bodies.
Dan
 audiobomber's gear list:audiobomber's gear list
Pentax K-3 Sony a6000 Pentax K20D Pentax smc DA 15mm F4 ED AL Limited Pentax smc FA 50mm F1.4 +16 more
joaquim hierro1
In reply to audiobomber, Apr 30, 2014
Dan
Thanks Dan for your reply.
what would be your choice for landscape and for portraiture.
I've noticed with the K5IIs some exaggerated or "cruel" red skin imperfections in some portraits. Could it be the lack of anti-aliasing filter? Could this be corrected using K3 with the filter "on"?
regards
audiobomber
In reply to joaquim hierro1, Apr 30, 2014
Dan
Landscape and portraiture are kind of opposites. Landscape shooters want corner to corner sharpness at small apertures, and often pump the colour/contrast. Portraits shooters value softer corners for subject isolation, like to blur skin detail, and want natural or even de-saturated colour/contrast. I rarely shoot portraits, and I've never shot a K-5 IIs, but here are my thoughts, for what they're worth.
  • I find skin tones from the K-5 family pretty horrible. White balance is to the cool side (too blue) and may be the reason you note the highlighted skin imperfections. The blue cast can make landscapes and water bodies look spectacular. Of course in raw images, an extra step of processing or a suitable import profile makes WB whatever you like.
  • The K-3 has more detail, always a plus for landscape, and can blur sharpness, sometimes desirable for portraits. If the subject is wearing fine patterned clothing, a blur filter can save you some work in post-processing. I've never tried to remove moiré, but I believe it is time consuming and never as good as not having had it in the first place. K-5 IIs owners say it is seldom a problem, but it depends on what you shoot. Even with the blur filter off, the finer pixel pitch of the K-3 is less likely to show moiré in the first place.
  • The K-3 also has three f2.8-sensitive AF points vs. only the center point in the K-5 IIs, which in theory should make it a little better for fast portrait lenses.
  • The K-3 has faster CDAF, with focus peaking (no FP on K-5 family).
  • Dual card slots are a great feature and can be a lifesaver for important shoots. Card failures are rare, but I've had a couple.
I waited for the K-3 and it was definitely the right choice for me, mostly due to more pixels for cropping bird photos, and superior AF-C for BIF and sports. If your finances allow it, I don't think you'd regret buying the latest and greatest.
Dan
joaquim hierro1
Dan
Dan
Thankyou Dan for your interesting comments.
I 've made up my mind and I ' m going to buy a K3.
I hope it fit well with my primes 15 f/4 limited, 28 f/3,5 and 50 f/1,2 old Pentax lenses and my 100 f/2,8 EX and 28-70 f/2,8 EX Sigmas.
I still need to replace my stolen 70-200. What would you recommend me?
regards
joaquim
audiobomber
In reply to joaquim hierro1, May 1, 2014
Sounds like fun.
I haven't paid much attention to 70-200's. Which one did you own? There are these: http://www.bhphotovideo.com/c/search?Ntt=70-200mm+for+pentax&N=0&InitialSearch=yes&sts=ma&Top+Nav-Search=
What uses do you have in mind for the 70-200?
Dan
joaquim hierro1
In reply to audiobomber, May 1, 2014
Sounds like fun.
Dan
I had the old 70-200 f/2,8 EX Sigma and used it for concerts and scenic shows and also some portraits.
do you know the Tamron?
regards
Joa
audiobomber
Sounds like fun.
Dan
Not at all. Have you considered the DA*50-135mm? It would be a good fit for your uses.
Dan
