Sony RX1 VRS Nikon DF
Started Apr 27, 2014 | Questions
David Gore
Veteran MemberPosts: 4,512
Apr 27, 2014
I know this is somewhat comparing apples and oranges but since I have the RX1 and am happy with it if cost is not a factor how would you compare the color,contrast,high ISo etc of the 35mm RX1 with say the DF with the Nikon 35mm 1.4??
I realize the DF is expandable with additional lenses while the RX1 is fixed with its beautiful Zeiss 2.0
Just wondering if anyone has this combo or has read anything comparing the 2 of them
Thanks, Dave
Nikon Df Sony RX1
LD_50
Regular MemberPosts: 356Gear list
Re: Sony RX1 VRS Nikon DF
In reply to David Gore, Apr 27, 2014
I own an RX1 and D4s. I previously owned the D4.
The RX1 beats any combination of D4 and 35mm lens for IQ (resolution, contrast, sharpness across the frame, microcontrast, etc) that I've tried.
D4 is better at high ISO, AF, handling, speed.
 LD_50's gear list:LD_50's gear list
Leica M Typ 240 Leica SL (Typ 601) Leica Summilux-M 35mm f/1.4 ASPH Leica Summilux-M 50mm f/1.4 ASPH Leica SL 24-90mm F2.8-4 +1 more
David Gore
In reply to LD_50, Apr 27, 2014
So I should assume that if I bought the DF with the 50mm 1.8 kit lens the only advantage the df might have is higher IS0"s?/ If i get the DF I might also get the 24-85 Nikon lens.
Appreciate any further thoughts you might have..Thanks
LD_50
Df with 50 1.8 is definitely different than RX1. Different focal length, shallower DOF, lesser quality lens, etc.
I prefer a Nikon setup for the AF, speed, ergonomics, optical VF, lens selection.
I have kept the RX1 because I can't beat the IQ at 35mm, the leaf shutter is silent, and it's fun for street shooting discreetly with the EVF at the 90 degree position.
The RX1 to me is all about having great IQ in a tiny and silent package. It leaves a lot to be desired outside of those qualities.
All that being said I'm not a fan of the Df. I don't like the AF system when compared to the higher end Nikon system, I don't like the ergonomics, and I don't care for the half retro half modern control scheme.
If you enjoy the RX1 and are not invested in Nikon, I would recommend taking a look at the Olympus OMD-EM1 and Fuji XT-1.
David Gore
Thanks for your input..I decided not to invest in the DF and will look into the EM1
ekaton
Contributing MemberPosts: 614Gear list
In reply to David Gore, Apr 28, 2014
DF and EM1, two completely different cameras in every way possible. IQ wise country miles apart. I love my Df, and don`t like my EM1. I respect the EM1 for some things it is a good tool for, but do not enjoy shooting with it, it simply does not grow on me. If it shall not be the Df, have a look at the Fuji XT1 which is much closer to the Nikon in philosophy than the Olympus and beats the mft for IQ by quite a margin.
 ekaton's gear list:ekaton's gear list
Sigma DP2 Merrill Fujifilm X70 Leica M9 Fujifilm X-Pro2
nightmedia
Contributing MemberPosts: 713Gear list
In reply to ekaton, Apr 28, 2014
Same experience here, had the OMD5, sold it because I was not having fun with it, got the OMD1 with the nocticron 42mm, returned it and actually felt sorry to see the nocticron go, a fantastic lens.
the OMD series 5 axis stabilization is indeed great, nothing comes close, but the camera output leaves much to be desired. The JPGs are over-processed and have very complex artifacts hard to remove, the raw has lots of noise at base ISO (hence the crappy JPG). Viewed from a distance all images look fine-ish, but when you look in detail or crop into the pic it's just disappointing. All in all, an underwhelming experience, albeit there are some lenses in the MFT stable that I would love to have on FX.
 nightmedia's gear list:nightmedia's gear list
Carl Zeiss Apo Sonnar T* 2/135 +1 more
crosstype
Regular MemberPosts: 179Gear list
If you do not need autofocus speed or interchangeable lenses, then the RX1/R is a better bet. However, SONY is going to release RX2 in the near future (either August 2014 or 1 May 2014). It is rumored to feature curved sensor with 35mm f1.8 lens.
 crosstype's gear list:crosstype's gear list
Sony Alpha 7S Nikon D810A Nikon AF-S Nikkor 24mm f/1.4G ED Nikon AF-S Nikkor 85mm f/1.4G +1 more
