Purple fringing shocker !
Started Apr 27, 2014 | Discussions
Stewart McKInlay Regular Member • Posts: 256
Just got back from a holiday and had a look at a few pics.  Wow my D610 with 24-120 F4 can produce an amazing amount of purple fringing in the usual places like around branches and foliage.  Anybody else suffering with this combo?
Nikon D610
shmn Regular Member • Posts: 349
Re: Purple fringing shocker !
Are you shooting RAW or JPG?  The processor should remove most lateral chromatic aberrations automatically for JPG.  For RAW, fix it in the converter.
If you want less CA...use a better (more expensive) lens that has less CA to begin with.  But most lenses will have some...esp in any high contrast area.
Steve Bingham
Steve Bingham Forum Pro • Posts: 23,305
If you shoot raw and use something like Lightroom 5 or ACR 8.3 you can make these go completely away.
Steve Bingham
www.dustylens.com
www.ghost-town-photography.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon D810 Nikon D5500 Nikon D7200 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF Nikkor 85mm f/1.8D +27 more
VicC Senior Member • Posts: 1,553
Why not show an example, as this will enable more detail to view. You may be expecting something a bit OTT. Vic
chlamchowder Senior Member • Posts: 2,083
The 24-120/4 is already very expensive. At over $1200 new, it's about the same price as the Tamron 24-70/2.8 VC.
But if you really want to see purple fringing, I suggest trying the pre-G Nikon 50mm f/1.4 (either D or non-D version). Shoot it wide open outdoors, and there'll be more purple haze than you ever thought possible. There's so much of it that it actually affects the color balance of the image.
 chlamchowder's gear list:chlamchowder's gear list
Sony Alpha DSLR-A580 Nikon D600 Sony DT 18-55mm F3.5-5.6 SAM +8 more
RichRMA Senior Member • Posts: 4,073
The defocussed blue and red light can be a problem when it comes to contrast as well, since even though (mostly) we see it on the edges of things, it's actually suffused across the entire image.
