X-T1 - First experience with a Fuji camera. Is this noise normal?
Started Apr 26, 2014 | Questions
Xesko New Member • Posts: 4
Hi all,
I'm new to the forum, and new also to Fuji cameras. I normally use Canon DSLRs and never found this issue there (if it's really an issue...). I apologise if this is a trivial question, but again my experience is very limited at the moment with this camera (1 hour?). Searched in the forum but couldn't find this being asked.
I just got an X-T1, with the 18-55 kit lens. Trying Aperture priority. Pre-AF is OFF. ISO 200. If I aim the camera to somewhere and then move it to aim to a different place with a contrast difference, I can hear like a mechanical noise going on al the time until I get the camera more steady. IS on the lens is off too. What's that noise about? I'm not half-pressing the shutter button, so the camera shouldn't be trying to focus or anything. As far as I understand, nothing mechanical should be happening there but I might very well be wrong. Is this normal? what causes it? Can it be avoided?
Thanks a lot for your help!
Fujifilm X-T1
Robert Garcia NYC Senior Member • Posts: 1,769
Re: X-T1 - First experience with a Fuji camera. Is this noise normal?
yeah, the lenses are noisy.
Edward Chatlos Veteran Member • Posts: 3,213
On my XE2 with 18-55 lens attached I don't hear anything.
Check the switch on the front of the camera that it is not set to C for Continuous Auto focus. Make sure it is set to S for Single focus.
Even with mine set to continuous I don't hear much if anything.
 Edward Chatlos's gear list:Edward Chatlos's gear list
Fujifilm X-E2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +2 more
dengx Senior Member • Posts: 1,020
Part of the OIS is always on keeping the moving part of glass in place, hence the little humming.
Some people hear it, some don't but it's there
Regards
Regards
Yes if I hold the lens/camera up to my ear I here something along with some clicking at times. A few inches away from my ear I hear nothing.
If my eye is at the viewfinder I don't hear it or I don't notice it.
Xesko OP New Member • Posts: 4
Thanks all!
Edward, I didn’t mentioned in my post but I was using S (single focus) already. Thanks anyway, as this indeed could have been an explanation.
Dengx, yes, this might be what I hear, this little humming, as you say, with some clicking at times like Edward says too. It might be a little bit louder in the X-T1 as I hear it if my eye is at the viewfinder. But it’s very soft or low anyway, hard to hear if there is a bit of ambient noise around.
I guess then this is normal function in these cameras, was just worried if there was something wrong in my unit.
Cheers!
Chad Hardy
Chad Hardy Senior Member • Posts: 1,191
Xesko wrote:
Hi all,
I hadn't noticed until you asked.  I held my ear up to it.  It is just the gyros motors for the OIS, at least that is all I hear.  No worries.   I have had mine for over a year (the 1855), no issues.
 Chad Hardy's gear list:Chad Hardy's gear list
Fujifilm X-T1 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 56mm F1.2 R Sony Cyber-shot DSC-RX100 III Olympus E-M1 +16 more
John Carson Veteran Member • Posts: 4,212
Regards
I've never noticed any sound when looking through the viewfinder (other than the beep for focus lock of course).
john carson
 John Carson's gear list:John Carson's gear list
Fujifilm X-E2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
AlbieSky Veteran Member • Posts: 3,333
I haven't noticed any bad noise from my lens.
Have you also checked to see if you need to upgrade the lens firmware?
 AlbieSky's gear list:AlbieSky's gear list
Nikon 1 J1 Nikon 1 V2 Fujifilm X-T1 Nikon AF-S Nikkor 85mm f/1.4G Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR +10 more
That's a good point, AlbieSky. No, I didn't. Going to check right away. Thanks!
just to keep you guys updated, I just upgraded the firmware from 3.1 to 3.11, but the noise is still there.
jadot
jadot Regular Member • Posts: 183
Do you have the pre-focus switched on?
examples of my photography at www.alexanderleaman.co.uk
User1070092745
User1070092745 New Member • Posts: 1
Regards
john carson
I have X-E1, X-T1 bodies and 18-135mm OIS and 35mm f/1.4 lens to test.
X-E1 + 18-135 OIS = Humming
X-E1 + 35mm f/1.4 = No Humming
X-T1 + 18-135 OIS = Humming
X-T1 + 35mm f/1.4 = No Humming
Humming is like CPU fan whirling noise.
Answer is clear - it is not X-E1 or X-T1 which is Humming. It is the OIS lens which is causing the noise.
 User1070092745's gear list:User1070092745's gear list
Nikon D90 Fujifilm X-E1 Fujifilm X-T1 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF Nikkor 50mm f/1.8D +6 more
