Need a High Quality Camera Strap for D4S
Started Apr 26, 2014 | Questions
ngtszhodavid
ngtszhodavid Contributing Member • Posts: 661
just wondering any good ones you guys recommend out there...
heavy camera.. love it..but getting old myself and need a nice strap...
thanks in advance!
 ngtszhodavid's gear list:ngtszhodavid's gear list
Nikon D4S Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 85mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II
Nikon D4S
Cliff Fujii
Cliff Fujii Veteran Member • Posts: 4,495
Re: Need a High Quality Camera Strap for D4S
I would consider Op/Tech system straps for your new D4s. I've been using them for years and there are so many ways you can configure them that if you can't find something to work for you, it hasn't been invented yet. They are of the neoprene stretchable type and are very comfortable. I can carry a D800 with a 70-200 f/2.8 around all day. I have tried many other brands, in trying to find something better but I always come back to Op/Tech. My strap collection is starting to look like my camera bag collection. I personally would not carry around a D4s because it's too heavy but then I'm planning to purchase a Graflex Super Graphic press camera so that I can take 4x5 images again.
http://optechusa.com/straps.html
Cliff
 Cliff Fujii's gear list:Cliff Fujii's gear list
Nikon Df Nikon D810 Fujifilm X-E2 Nikon AF-S DX Micro Nikkor 40mm F2.8 Nikon AF-S Nikkor 50mm f/1.4G +45 more
9ck
9ck Contributing Member • Posts: 843
thanks in advance!
I've just got the Joby Pro Sling Strap and the Op/Tech which I've been writing a bit about in the tread linked to below. For a traditional good quality strap I'd also be looking at the Black Rapid and Sun Sniper. I tried the Black Rapid out in the store and it was a nice fit and well function. I got the Joby cause I wanted the option to secure the camera in a higher position.
http://www.dpreview.com/forums/post/53366141
Regards 9ck
 9ck's gear list:9ck's gear list
Nikon 1 AW1 Nikon D750 Nikon AF-S Nikkor 28mm f/1.8G Nikon AF-S Nikkor 85mm f/1.8G Nikon AF-S Nikkor 70-200mm f/4G ED VR +12 more
calson
calson Veteran Member • Posts: 7,177
I put Tamrac neoprene straps with their quick release buckles on all my cameras. The neoprene does not slip off a shoulder and it acts like a shock absorber when using a heavy camera with a heavy lens. Huge difference in comfort.
The Tamrac are the only straps I have found with quick release buckles that do not self-release. When using a tripod I remove the strap after the camera is safely mounted on the head. I avoid accidentally getting caught in the strap and having the tripod and camera crash to the ground. I take the strap off and wrap it around the tripod where it is out of the way completely.
I have used many "pro" straps and all ended up in the trash after a single day of use.
ngtszhodavid
ngtszhodavid OP Contributing Member • Posts: 661
Cliff
Thanks. I've been using them for my D700 and are indeed quite good. Was just wondering if there is anything much better or is it all about the same...
Aimhere
Aimhere Regular Member • Posts: 210
Putting in my two cents' worth here...
Currently using the Custom SLR Split Strap with my D7100:
http://www.customslr.com/products/camera-split-strap
It's VERY soft and comfortable, the split design improves ventilation. Worn over the shoulder (but I use it around the neck too). Comes with two sets of modular straps (short and long). You can also buy a glide-strap for it, and attach it to the camera's tripod socket with their "C-Loop".
I use mine attached to the regular strap lugs on the camera, but I added S-Biners (http://www.niteize.com/product/S-Biner-MicroLock.asp) so I can detach and reattach the strap fairly quickly (useful when you want to use it with a tripod). (If you use a strap with S-Biners, though, make sure you get the locking kind!)
 Aimhere's gear list:Aimhere's gear list
Nikon D7100 Canon PowerShot SX120 IS Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +8 more
RichRMA
RichRMA Senior Member • Posts: 4,073
If it has eyelets (where metal rings go through) instead of strap slots, get a strap with some give to it.  Otherwise, the camera and a heavy lens can wear those eyelets.  I actually wore a eyelet right through (I didn't notice it) stupidly leaving a 300mm f/4.0 lens and the camera hanging off my shoulder.
egk4260
egk4260 Regular Member • Posts: 394
Strap for D4s
I have been happy with  UpStrap heavy duty QR strap with "vectran" loops on both D4 and D700 for the past two to three years. I have had no self release problems. I leave the short loops attached to the bodies. There is also a kevlar loop option for metal lug lenses and bodies where wear would be an issue. Those kevlar QR attachments are too long and bulky on the body for my liking. The strap has a large rubber pad which stays put and is comfortable except on bare skin.
I tried the kevlar QR loops on a 300 f/2.8 lens, but removed them as they seemed to be in the way the majority of the time and I was nervous about anything QR on lens/body combo that heavy.
Like most of you, I have a box of unused straps, slings, and connectors!
 egk4260's gear list:egk4260's gear list
Sigma 35mm F1.4 DG HSM Art Sigma 85mm F1.4 EX DG HSM Sigma 24-105mm F4 DG OS HSM Apple iPhone 5s
Yorkshireman
Yorkshireman Regular Member • Posts: 176
Re: Strap for D4s
Take a look at Eddycam at www.eddycam.com.
Irwin
Irwin Senior Member • Posts: 1,768
I've tried Kata, Optech, Upstrap, Blackrapid, among others. My new favorite is the Crumpler Convenient Disgrace. It's the most comfortable one I've tried.
overniteman
overniteman Contributing Member • Posts: 813
Crumpler Industry Disgrace
Cliff Fujii
Well, NIkon just released it's new strap for sale at B&H.
http://www.bhphotovideo.com/c/search?Ntt=Nikon+Quick-draw&N=0&InitialSearch=yes&sts=ma&Top+Nav-Search=
Cliff
hikerdoc
hikerdoc Senior Member • Posts: 1,013
Cliff
Interesting! Has Nikon physically modified their cameras, which for years we have been told are not designed to be carried by the tripod mount? Can this strap be used on all those old cameras which, we are warned, will be damaged by these rigs and not covered by warranty? Was this weakness rectified by a profitable licensing arrangement?
 hikerdoc's gear list:hikerdoc's gear list
Nikon D4 Nikon D810 Carl Zeiss Distagon T* 2,8/21 Carl Zeiss Apo Sonnar T* 2/135 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +11 more
Cliff Fujii
I asked Nikon Service is there were any issues with using a sling type strap that screwed into the tripod socket (al la Black Rapid) a number of years ago.  The service tech looked through some papers and said using that type of strap would not void the warranty.  Apparently Nikon has gone one step further and collaborated with Black Rapid to make a sling type strap.  This strap is a bit different from the usual Black Rapid stuff.  The way I look at it, I can use it with my RRS B2-FABN by screwing the adapter into the 1/4-20 thread hole in the RRS clamp.  I suspect that I should get results similar to using the CS FS-Pro.
I did some looking and could not find any official document or technical paper that said that using a sling type strap would void the warranty.  With that in mind, I got the CS FS-Pro.  I noticed a lot of Canon professionals use the Black Rapid strap, so I guess there might be something to it.
Cliff
hikerdoc
Cliff
There is apparently no set answer from Nikon as I asked the same question of Nikon support in 2011 and was told that the camera should not be carried on these slings, that lens and camera should be carried in a bag if conventional strap mount was not optimal, and that only this way could they "guarantee" performance. We have all heard of the term "impact damage". I just referred to the emails in my Nikon account.
I remain leery of the RRS option wherein one has a ring mounted carabiner mounted to the socket screw mounted to the RRS clamp mounted to the L-plate mounted to the tripod socket. That represents 5 potential failure points. My BR is long gone. The RRS clamp now attached to one of my monopods.
DWR
Bandit57
Bandit57 New Member • Posts: 4
No strap but nevertheless..
I am a big fan of Spiderholster, no dangling, bumping aso and very well crafted.
I even use it to carry a D7100 with 200-400 F/4 attached! (pin screwed in lensfoot)
 Bandit57's gear list:Bandit57's gear list
Canon PowerShot G11 Nikon D3S Nikon D800E Nikon AF-S Nikkor 200-400mm f/4G ED VR II Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +4 more
Mk4doorigami
Mk4doorigami New Member • Posts: 1
If you're looking for something inexpensive and no frills that works then the pro strap from Op/tech is always a nice bet http://www.uniquephoto.com/product/optech-pro-strap-black-with-3-8-webbing-connectors-1501012/ but with heavy lenses I would highly suggest more of a sling strap to relieve some of the weight. That being said, if fancy and proper Nikon is more your bag, their new strap in conjunction with Black Rapid is awesome. It is basically an even more robust version of their Sport Strap made with heavy full bodies and long lenses in mind
http://www.uniquephoto.com/product/nikon-black-rapid-quick-draw-strap94007/
ngtszhodavid
Yea i've been deciding on the optech (which i had prevoiusly with my D700) or whether to try out those black rapid straps.  Have you personally tried the Nikon one? is it safe?
1KIND
1KIND Regular Member • Posts: 178
A slew of hand strap and camera straps that I reviewed - http://www.1kindphotography.com/p/reviews_2.html
Currently, my favorite is the Custom SLR Air Strap and Hand Strap. I switch on and off between the Luma Labs Cinch and Peak Design Leash.
I use the Peak Design Cuff for my point and shoot.
www.1kindphotography.com - Reviews
Equipment: Gripped Canon 5D Mark III | Canon G1 X Mark II
Lens: Canon 24-70mm f2.8L II | 50mm f1.4
Gear: Canon 600EX-RT; ST-E3-RT | Custom SLR M-Plate; Hand Strap; Air Strap | Peak Design CapturePRO; Leash | Spider Holster
 1KIND's gear list:1KIND's gear list
Canon PowerShot G1 X II Canon EOS 5D Mark III Canon EF 24-70mm f/2.8L II USM Canon EF 50mm f/1.4 USM
overniteman
Crumpler Industry Disgrace.
