Software on an Apple
Started Apr 26, 2014 | Discussions
bjzwaan
Contributing MemberPosts: 764
Apr 26, 2014
Hi all,
i recently acquired a X100 and am use a MacBook pro with OS Maverick runnend on it. leikleur to import the files  into the computer with a programme that allows me to  look at the camera and Jpeg settings. The Fuji viewer  does not run under my OS, so is there a (free) alternative? I have photoninja, but the Fuji settings are not visible here.
Thanks for your thoughts and time,
Bas
Fujifilm FinePix X100
BlueJakester
Senior MemberPosts: 2,031Gear list
Re: Software on an Apple
In reply to bjzwaan, Apr 26, 2014
iPhoto will provide some EXIF when you click on the Info icon. It's already on your Mac.
iPhoto Info panel
Edward Chatlos
Veteran MemberPosts: 3,210Gear list
Fuji's MyFinePix certainly does run under OS X.
Look here.
http://www.fujifilm.com/support/digital_cameras/software/#viewer
 Edward Chatlos's gear list:Edward Chatlos's gear list
Fujifilm X-E2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +2 more
Edward Chatlos
I also suggest you stay away from Apple's iPhoto software.
That is if you like to keep the images you take. IMHO iPhoto, along with a lot of other Apple branded software, is some of the worst software available.
ScottD1964
Senior MemberPosts: 1,263Gear list
In reply to Edward Chatlos, Apr 26, 2014
Huh?  I've used iPhoto for years for basic manipulations and never lost a single original image. If you import (drag and drop) a file into the program the original is always left in its original folder. Don't tell me you direct import from your camera into iPhoto, work and save the original, losing the original?  How is that Apple's fault?
 ScottD1964's gear list:ScottD1964's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +3 more
uniball
Senior MemberPosts: 1,366Gear list
I, along with millions of other people, use iPhoto extensively, with no issues. It's been my only archival/slideshow/media server app since it was first introduced. Library has been up to 50,000+ images.  Originally managed, now referenced. My wife uses it for editing, I use Aperture and Lightzone for edits. In all that time I cannot recall a single issue with the app.
Perhaps you could enlighten us about just what problems it has?
uniball
If you want to get into the bowels of exif info, EXIF Viewer is free. The install requires Terminal but it's simple.
A more elegant approach is GraphicConverter. It has EXIF Viewer built in and allows you to customize what info is displayed. I've used GC as a browser for years. It's easy to use, fast once launched and has superb tools to compare or catalog images. It's my front-end before anything gets imported into Aperture. Also has a decent editing module based on DCRAW for renders. The DCRAW version can be updated if need be, another hack but simple.
Joytx4u
Forum MemberPosts: 91
In reply to uniball, Apr 26, 2014
Very true uniball, I stand by your words because I too, use iPhoto. Never had any issues with it in fact I love using it.
joytx4u
Chikubi
Senior MemberPosts: 1,086
You can open images in Preview and then use the Inspector(command-I) to view the EXIF info. I use this all the time when I'm teaching and displaying students' photos on the projector.
Jim King
Veteran MemberPosts: 8,024Gear list
+1.  GraphicConverter is a very useful shareware program and it is updated with new features/bugfixes on a regular basis. I use it the same way you do.
Jim King - Retired Colormonger - Suburban Detroit, Michigan, USA; GMT -4h (EDT)
Pentaxian for over 50 years.
There is hardly anything in the world that some man cannot make a little worse and sell a little cheaper, and the people who consider price only are this man's lawful prey.
- John Ruskin
A fanatic is one who can't change his mind and won't change the subject.
- Sir Winston Churchill
The difference between genius and stupidity is that genius has its limits.
- Albert Einstein
 Jim King's gear list:Jim King's gear list
Leica M Typ 240 Pentax K-3 Pentax MX-1 Sony Cyber-shot DSC-RX100 III Fujifilm X30 +69 more
BlueJakester
In reply to Chikubi, Apr 26, 2014
Great tip! Thanks.
RetiringGuy
Regular MemberPosts: 106
bjzwaan wrote:
Hi all,
Bas
If you are happy to use the Terminal try using ExifTool ( http://www.sno.phy.queensu.ca/~phil/exiftool/ ).
It is very comprehensive and even allows you to change Exif settings.
RG
bjzwaan
bjzwaan OP
Look here.
Is that true?  Because then my problem world be solved.
I probably wasn't clearing enough, but I was aiming at the information for the camera settings, not the more universal exif  information. For that I guess I need Fuji software.
Bas
Edward Chatlos
Look here.
Bas
Not sure you will get the actual camera settings you used for each shot even with the Fuji MyFinePix studio software installed.
I just opened it on my Win 7 PC and I don't even get the EXIF data.
What settings are you looking for? this is what I get in LR and Bridge.
dmaclau
Senior MemberPosts: 1,961Gear list
The Apple OS will read much of the info you are asking about.
I use Aperture.  In my opinion it's excellent, better to me than any of it's imitators, and I've tried most.  It's not free but from the App store it's about $80.  A bargain.  It shows camera settings (ISO, f-stop, shutter speed, +- EV.
 dmaclau's gear list:dmaclau's gear list
Fujifilm FinePix X100 Sigma DP3 Merrill Fujifilm X-M1 Samyang 8mm F2.8 UMC Fisheye
Chris Dodkin
Veteran MemberPosts: 6,590Gear list
MOD Note: Please keep it on topic
In reply to bjzwaan, Apr 27, 2014
Everyone - Product bashing is OT, and goes against forum rules
Please keep it OT, and don't derail a useful thread
Thx.
http://f-sunny.com
The future is just a click away...
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm FinePix X100 Canon EOS-1D Canon EOS-1D Mark II Canon EOS 5D Mark II Canon EOS 30D +34 more
bs1946
Senior MemberPosts: 2,993Gear list
Maverick is OSX 10.9. If you look at the Fuji site carefully, their software only supports OSX up to OSX 10.6. I have the same problem with PC AutoSave that supports WiFi on my X-A1. Will not work with OSX 10.9.
 bs1946's gear list:bs1946's gear list
Fujifilm X-E2 Rokinon 8mm f/2.8 UMC Aspherical Fisheye Carl Zeiss Touit 1.8/32 Samyang 12mm 1:2.0 NCS CS Fujifilm XF 60mm F2.4 R Macro +2 more
bjzwaan
bjzwaan OP
In reply to Edward Chatlos, Apr 27, 2014
Look here.
Bas
Thanks for the feedback. What I am looking for are the settings such as colour mode, highlight and shadow etc. It is important for me to learn what the effects are in the image. Silly of Fuji not to keep their software up to date.
Cheers, Bas
Edward Chatlos
Look here.
Bas
Cheers, Bas
Not sure you will ever see those things you list. They are In Camera adjustment for Jpeg only.
When using RAW image data all those things can be changed in post.
