Have Fuji fixed the lens mount wiggling problem on XE2 and XT1?
Started Apr 26, 2014 | Discussions
nofumble Senior Member • Posts: 1,511
The problem is in my X-E1, the lens does not fit solidly tight like other camera brand, but wiggle a bit.
When I mount a longer and heavy lens via adapter, the wiggling become very noticeable.
Fujifilm X-E1 Fujifilm X-E2 Fujifilm X-T1
Dorkington Regular Member • Posts: 355
Re: Have Fuji fixed the lens mount wiggling problem on XE2 and XT1?
I own an X-E2 and X-Pro1, and used to own an X-E1.... I've never had this problem. Might want to send your camera or adapter in to be adjusted.
 Dorkington's gear list:Dorkington's gear list
Fujifilm X-E2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +2 more
proque Forum Member • Posts: 54
Yes. I have the same issue with my X-E1. But with my X-T1 all my XF lens are tight and no wiggling at all.
Just to add, the wiggling issue on my X-E1 is without an adapter.
 proque's gear list:proque's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +2 more
dmaclau Senior Member • Posts: 2,072
just bought an X-M1...lens wobbles
 dmaclau's gear list:dmaclau's gear list
Fujifilm FinePix X100 Fujifilm X-M1 Fujifilm X-Pro2 Samyang 8mm F2.8 UMC Fisheye
Conrad567 Regular Member • Posts: 493
I own both a Fuji X-Pro1 and X-T1, neither wobbles, however they are both all metal camera with very few plastic parts, I wonder if the frames of the lower end cameras have the problem.
 Conrad567's gear list:Conrad567's gear list
Canon EOS 5D Mark III Fujifilm X-T1 Canon EF 35mm f/1.4L USM Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +10 more
nofumble OP Senior Member • Posts: 1,511
It's the clearance between the locking pin and the slot in the lens mount
If you grab the lens, rotate it back and forth, and you will feel the wiggle
No other brand has this problem. Somehow Fuji-san thinks they need to have a wider slot to make sure they all fit. (Come on, fix the quality).
You don't notice this problem with a lighter lens, but if you put an adapter and mount a heavy lens like a 200mm tele, you will notice the wiggling.
I have used all kind of adapters on Canon and Sony, no such problem. Just Fuji.
newtoy Regular Member • Posts: 391
Re: It's the clearance between the locking pin and the slot in the lens mount
This also happen in all my Nikon gears!
Provided that it doesn't affect the lens electronic contacts and there is only a planar movement, then its OK and will not affect your image quality.
 newtoy's gear list:newtoy's gear list
Nikon D70 Nikon 1 V2 Fujifilm X-T1 Nikon D810 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +23 more
Wheatfield7
Wheatfield7 Senior Member • Posts: 1,189
When you mount a long heavy lens you should be supporting the lens, not the camera body.
(unknown member) Senior Member • Posts: 1,321
I Guess So, None of My Seven Lenses Wiggle (XT-1) NT
No text.
 wchutt's gear list:wchutt's gear list
Fujifilm X-Pro1 Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +20 more
nick_webster
nick_webster Veteran Member • Posts: 5,534
What lens mount problem ?
8
I've got an X-E1 and I can mount a 300mm f2.8 lens with cheap adapter and there's no wiggle, jsut as there isn't with my X-T1.
It's a bit disingenuous to suggest that just because your camera has this (non) issue that all X-E1s have it.
Nick
Jim King
Jim King Veteran Member • Posts: 8,109
Re: What lens mount problem ?
Nick
+1.  The phrasing of the OP is akin to "When did you stop beating your wife."  No need for such a provocative title.
Jim King - Retired Colormonger - Suburban Detroit, Michigan, USA; GMT -4h (EDT)
Pentaxian for over 50 years.
There is hardly anything in the world that some man cannot make a little worse and sell a little cheaper, and the people who consider price only are this man's lawful prey.
- John Ruskin
A fanatic is one who can't change his mind and won't change the subject.
- Sir Winston Churchill
The difference between genius and stupidity is that genius has its limits.
- Albert Einstein
 Jim King's gear list:Jim King's gear list
Leica M Typ 240 Pentax K-3 Pentax MX-1 Fujifilm X30 Leica M9 +68 more
57LowRider Senior Member • Posts: 3,765
My 18-55 does it, and the Oly adapter to a lesser extent, but all the others are ok on the X-E1. I've only used the 56 and 23 on the X-T1 so far, no wiggle.
I don't rate it as a problem, though. No cute kittens die and the images are perfectly fine.
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +10 more
Sal Baker Veteran Member • Posts: 9,441
No lens wiggles with the X-E2.  I have the kit zoom and 23mm f/1.4 prime.  All are solid so far.
Sal
 Sal Baker's gear list:Sal Baker's gear list
Ricoh GR Canon EOS 5D Mark II Fujifilm X-E2 Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM +7 more
IslandTractor Contributing Member • Posts: 583
My X-E1 wobbles with the 18-55 zoom and with the 55-200.  Doesn't seem to affect function/quality however.  I personally find the wobbling and rattling of the 18-55 lens cap to be more annoying.  And nothing beats the annoyance level of the crappy lens caps provided by Fuji.
Great cameras but they do have some quirks.  Luckily none seems to affect image quality or function.
 IslandTractor's gear list:IslandTractor's gear list
Fujifilm X100S Ricoh GR Fujifilm X-E1 Fujifilm X-T1 Voigtlander 15mm F4.5 Super Wide Heliar +7 more
AlbieSky Veteran Member • Posts: 3,333
My 18-55 lens does wiggle very slightly on my XT-1.
 AlbieSky's gear list:AlbieSky's gear list
Nikon 1 J1 Nikon 1 V2 Fujifilm X-T1 Nikon AF-S Nikkor 85mm f/1.4G Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR +10 more
hellocrowley Senior Member • Posts: 1,271
Both the 35 and the 18 wiggle on my Xpro1.
Yeah, sorry but I have mounted all of my lenses to both bodies to be sure, neither wiggles at all.  Tight as a drum!  Don't know what to tell you all.
pxchoi Regular Member • Posts: 360
This is an interesting thread... I'm finding that my 1024 wiggles and my lens gets spastic has a result and sometimes ends in a lens error. Very annoying, but no problems with my 1855 lens.
This is the second lens that I am sending back...
www.patrickchoi.com
www.flickr.com/patrick_choi
 pxchoi's gear list:pxchoi's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 Olympus 12-40mm F2.8 Olympus 7-14mm F2.8 Pro
Ollie 2 Senior Member • Posts: 1,530
I have this issue with 2 out of 5 Fuji lenses on my XP1.
I've owned about 20 lenses on two different m43 kits and never encountered this before.
Not good.
 Ollie 2's gear list:Ollie 2's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Olympus PEN E-P2 Fujifilm X-Pro1 +19 more
Edward Chatlos Veteran Member • Posts: 3,213
Let me ask. This Wiggle you are asking about is it a up/down/left/right movement or are you talking about a slight rotational movement once the lens is locked onto the mount?
If a rotational movement that is perfectly normal and every camera I have ever owned does this.
If it is a up/down/left/right movement then the spring system that holds the lens to the body is weak.
 Edward Chatlos's gear list:Edward Chatlos's gear list
Fujifilm X-E2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +2 more
