A6000- Just picked it up. Question on focus
Started Apr 26, 2014 | Discussions
starstreak Regular Member • Posts: 299
Ok, excited to get the camera today (Best Buy pre-order came in yesterday) and I'm shooting a stationary object with the default lens.  I have manual focus point on the object, I'm shooting in A mode at f10 @1/10 and it's about 1.5ft away.  I have anti-shake off, and camera is on the table as I push the shutter.
I HAD a 5n until the screen cracked I could do that same shot and it would be in focus.  I prefocus then click the shot.  The object is slightly blurry.  I tried a few shots and one of 3 shots came out sharp.  I went to F8 and still having same issue.  Am I doing something wrong or forgetting to turn off something?
I make spelling errors. Ignore it. You're not my spelling teacher.
Sony a6000
ryan92084
ryan92084 Contributing Member • Posts: 521
Re: A6000- Just picked it up. Question on focus
you say your are using a manual focus point does that mean you are using flexible spot autofocus or manual focus?
assuming the former a few have reported AF-s is less accurate than AF-C for focus (even though it should be the opposite) so give that a try.
 ryan92084's gear list:ryan92084's gear list
Sony a6000 Sony E 16-50mm F3.5-5.6 PZ OSS +3 more
starstreak OP Regular Member • Posts: 299
I'm using the flexi-spot where you can pick a spot to auto focus. I'll mess with the AF-C/AF-S. Not sure what I have it to.
NeilJones
NeilJones Veteran Member • Posts: 5,421
1/10 shutter speed. Are you for real? Or is this a joke?
" All you need is love"
Neil- I think that's what the shutter speed was. ISO was 400. At the moment it was just to see how the focus was. Not so much for brightness or subject matter.
ryan92084
What I think he's trying to get at (and a point I would have made if I had noticed) is that 1/10 isn't a particularly reasonable shutter speed to hand hold without at least some bursting to get one of the shots without motion blur from your own movement.  OSS helps but it doesn't mean you can shoot that slow and expect perfect shots.
dquangt Senior Member • Posts: 1,690
As Neil pointed out 1/10 is really slow. I didn't see you mention that you are using the timer. I don't think the focus is the issue assuming you focused correctly, it's more like camera shake as you are pushing down the shutter button. Try to use 2 second timer, then get back to us.
ryan92084
Bah, my reading skills are way down tonight I didn't notice or just forgot about the table.  I'd edit or withdraw this post if I could but the time limits on this forum are really tight.
Anyway you used a table for the 1/10 which may or may not work depending on the stability of the table and the environment you are in.  Also, as another poster mentioned, use a timer otherwise your shutter press is moving the camera.
Good luck and sorry for sounding like a doofus in my quoted post.
As i mention,I turned off the OSS. And the camera is sitting on the table. ALSO, I'm putting slight pressure down either one hand and pushing the shutter with other hand so I don't move the camera.
I replied to your previous post. Lol. But the table doesn't move. It's mounted to the wall.
Btw, camera was set to AF-A. When I get back to work tomorrow, I'll try setting it to AF-S. Maybe it was trying to re-focus as I pushed the shutter down completely?
Bart Hickman Veteran Member • Posts: 7,256
This blows my mind.  I've been doing a lot of precious AF-S accuracy testing and it is absolutely bullet-proof perfect.  I can do macro shots that were previously impossible with my NEX-6.
Bart
 Bart Hickman's gear list:Bart Hickman's gear list
Sony Alpha NEX-6 Sony a6000 Pentax smc FA 50mm F1.4 Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS +10 more
ryan92084
Bart
I've seen two fairly solid tests (one here and one on a French forum) showing it with the 18-200.  The user who reported it here also says they have it on some other lenses.  Can't say I've noticed it myself but I don't have an 18-200 to test.
ryan92084 wrote:
Bart
Interesting.  I only have the "trio"--10-18, 16-50, and 55-210.  All perfect.  Maybe there's some lens or camera bug pertaining to some lenses.
Bart
Ok, I set it to AF-S (single focus).  I think it was AF-A(it chooses if its on a stationary or moving object).  And now it focuses correctly.  5 shots are clear.  When I had it on AF-A, 2 of 5 shots was slightly out of focus.
Unless someone has found a good use for it (I haven't), it's best to just avoid AF-A IMO.
Bart
